Vizio VW42LFHDTV10A
+ More Options
Posts
  • Chancey
    • Aug 2012
    • 25
    Re: Vizio VW42LFHDTV10A
    A1 goes through something similar but with a lot more electrolytics and only one transistor. The RO told me to hold off and wants me to wait on modification. Other than charging for board replacement...IDK man. I learned A LOT in this short time. Mainly, steer clear of Vizio ;-)
    • Chancey
      • Aug 2012
      • 25
      New problem...built the circuit, works 100%!! However, fix one problem to find two more. No HDMI's works on the main board. The RCA connector's for AV1 & 2, they work...however, I get somewhat of a fizzle pop every so often and it makes the screen go black. Something to do with the top inverter, seems to stop the longer the TV is on. I swear!! Finally get around to fixing it, after RO said to keep it, LOL...I'm batting 1 and 1000.
      But just to let others know, that have read this post...Bud's design DOES indeed work for the delay.
      • Devonavar
        Vizio M43-C1 - How closely do I need to match the mainboard number?
        by Devonavar
        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
        So, I've ruled out the PSU for now.
        The reboot loop...
        08-14-2022, 08:46 PM
      • maricm
        Vizio P65 with P55 mainboard
        by maricm
        IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
        Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
        And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
        04-23-2024, 08:25 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
