Sharp LC-40LE810UN question
    replied
    Re: Sharp LC-40LE810UN question
    Darn, they have to make it so complicated. Why can't they put a simple clear button to clear out the garbage from the chip, but then they cannot sell more TV, I guess.
  • olegi
    replied
    In this particular board you have tree eproms .First with firmware is on top side on the board (left side on heat sink on post 129 ic3401 if i see correct from picture) Second for settings (channels , brightness ...) it is 64kbit .
    Third is it 4kbit .That chip you have to erase.For programmer go to google and search for ( 24c04 programmer )
  • tibimakai
    replied
    I don't have a programmer.
    replied
    Does this chip also store firmware? I am trying to understand how it works if it is blank.
  • olegi
    replied
    You have to desolder this chip,erase it with eprom programmer and soldered back.You can use brand new chip too.
  • tibimakai
    replied
    How you do that, since the Tv doesn't turn on?
  • olegi
    replied
    On your main board there is eprom (chip finish with 04) on the backside of the board You have to erase it (blank it).Inside this chip is store a lot errors . you can find this chip on picture on post 129 on the bottom .I had 52 " sharp same blinking code .After erase this
    chip ,tv is working again .Don't forget to hit factory settings. Hope this helps
    Post your results.
  • tibimakai
    replied
    2 slow and 5 fast.
  • olegi
    replied
    Hi tibimakai. Do you still have this blinking code in front of tv, if it is yes what is the sequence.
  • tibimakai
    replied
    With the original board back in the TV, I have measured the voltages before the feedback kicks in.
    This is what I'm getting:
    Pin#--Designation---Volts
    1-----13.2V-------= 13.02V
    2-----13.2V-------= 13.03V
    3-----SGND-------= 0
    4-----SGND-------= 0
    5-----SGND-------= 0
    6-----SGND-------= 0
    7-----SGND-------= 0
    8-----SGND-------= 0
    9-----AC-DET-----= 3.12V
    10----PS-ON------= 3.03V
    11----BU5V-------= 5.017V
    12----PNL-POW---= 0.12V
    So, the mainboard it's OK too?
    When I turn on the TV there is a very-very tiny buzz.
    Can I measure the LED transformer outputs? They should be like 90V or more?
  • tibimakai
    replied
    I got frustrated because sometimes I had voltages and sometimes were all gone.
    Hopefully they will take it back.
    replied
    You are not getting PSON so why did you replace the power supply? Sorry - missed this thread.
  • tibimakai
    replied
    What should I do next? I don't see conventional VDOs on the mainboard to check.
    Since the replacement power supply acts the same way as the original board, I assume that it's not the power source is the problem.
    I don't understand why there is no voltage at the connector(only 4.7V stby).
    Special order mainboard at partstore is $155.
  • tibimakai
    replied
    Power supply/Inverter board arrived. I have installed it and it's exactly as with the original board. Still blinking a code. Board ordered from partstore.com.
    So, it looks like it's the mainboard is the problem. Not receiving any voltages other then the STBY voltage.
  • tibimakai
    replied
    I will let you know. I'm using a WDTV Live streaming player now. It's hard to believe that it could be better then that.
    replied
    Probably the component responsible for providing panel power is dead. The corrosion could have killed it.
    You will have to let us know how smart the smart TV seems! I have always found them annoyingly slow.
  • tibimakai
    replied
    I have just noticed that actually the LEDs are on an blinking while I have the voltages. I haven't notice them before, since they were up side down.
    The code that flashes is 2 slow and 5 fast blinks which in the manual says that it's:
    -Power PWB failure (Power failure, etc.); Panel power supply error.
    -PANEL_POW; Panel 12V failure; Flashes fast 5 times; DET_PNL12V(35pin) failure (L). Panel power is not applied.
    Detection is started after turning on the panel power and receiving command; the power is turned off by polling.
    It would be nice if we could fix this board also. I would have a good board.
    The new one from partstore is in it's way.
  • tibimakai
    replied
    ..and it's a smart TV too!
    Today before I left to work, I have checked it again and the voltages were there at the two capacitors.
    It seems that all the voltages have to drain out of the TV before I have the voltages back.
    I may have some short in the secondary side of the PS?
    The FET and that double diode(not sure how is called, looks like a FET) under the black heatsink has voltages at there pins.
    Not sure what happens between these and the connector.
    Man I don't like to give up, and I hate myself that I have purchased that board.
    replied
    I never trust people when I pick up a TV .
    I didn't realise you were having so much difficulty with the PSU. I hope the replacement works.
    I want a nice Sharp 40" LED set to work on soon .
  • tibimakai
    replied
    I was trying to fix this power supply for over a month with no success.
    I have waited for two ICs(same) and when I install one it runs for a bit and then it quits, replaced the second one and the same thing happened.
    Now I will have to order two more($15 shipped=total $30), wait another three weeks.....
    Last couple of days I didn't get any real help, plus the frustration and I have just pulled the trigger. It wasn't easy to give up.
    It was less then $78 shipped.
    The back cover of the TV is Aluminum(!) and that one too has some white spots, not sure if it's water or oxidation of the Aluminum exposed to the elements
    The guy from whom I picked it up he said that it was his own TV, but then he has a company which installs TVs on the wall.
    I'm guessing that he lied and this TV it was installed at an outdoor place most likely.
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-06-2024, 08:10 PM
