LDL-46vl130 problem.
  • truep
    • Aug 2010
    • 373
    The symptom: when I first turn on the set, there are two thin (one pixtel wide separated by one pixtel normal) They are clearly visible on light screens, and fade in dark scenes. after about 10 min. they disappear and all is well until the set has been off for an hour so.
    The set has a samsung panel and is a 2007 model.
    Sound like tab bonds?
  • truep
    • Aug 2010
    • 373
    Re:kDL-46vl130 problem.
    The lines are green.
    • tibimakai
      • Jan 2012
      • 3680
      Re: LDL-46vl130 problem.
      check youtube.
      • Tiezane
        • Aug 2013
        • 98
        did you ever get an answer in this one, truep? I just picked one up for $35 that had what sounds like a similar issue, but I need to figure out what the previous owner did to it first. said he was taking the bezel off, put it back on, and says something shorted out. gotta figure that part out first.
          That can be tab bond or TFT drive IC (runs hot).
          • Tiezane
            • Aug 2013
            • 98
            tab bonds is what I was hoping. as soon as I get a chance to plug this thing in and get some better info, I'll start a new thread.
            • truep
              • Aug 2010
              • 373
              it was bad tab bonds. T fixed it by adding heat conductive foam above the bond between the bond and frame. It worked fine until I replaced it with a 60" LG and still works in the guest room.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
