Vizio E321VL - turn logo off?
  • cnymike
    • Aug 2012
    I've got two E321VL's. Been reading all the horror stories about them dying an early death due to bad eprom. Mine are fine... so far. So I'm holding my breath and considering purchasing a 5 year extended warranty.
    My only complaint with the E321VL has to do with the logo which is always "on" whether the HDTV is on or off. Since I have one of these in my bedroom, it's very bothersome to have the darn logo on all the time. Other than covering it with electrical tape, or opening the set and unplugging the wire harness to the light, I was wondering if anyone knew whether there was a method to deactivate the light other than what I've already mentioned.
    Thanks in advance for any info on this. I'll probably try calling Vizio tech support to find out as well although many times they are clueless.
  • killian6pk
    • Apr 2010
    • 502
    Re: Vizio E321VL - turn logo off?
    I think the only way to stop the light (other than covering it up) is to unplug the LED on the front. Lay the tv on its face on soft surface. Watch around the RCA inputs there are 2 or 3 small screws that need to be removed. When you open the back at the bottom in the center you will see two wires running under the screen toward the front bezel. That is the led light wire. Be careful because there are several wires running from the speakers and Remote control IR board. Those are taped down and can be pulled from their socket.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    • tibimakai
      • Jan 2012
      • 3680
      How about using a black marker, maybe it will show like smoked out tailights?
      • cnymike
        • Aug 2012
        I did call Vizio and as I surmised the person I talked to wasn's quite sure but said that some models have the ability to turn the logo off while others do not. I have the others. So I guess I'll be voiding my warranty and opening it up to remove the leads. Thanks for the input.
        • Bob1394
          Vizio M65-C1 | Logo appears for 10 seconds then off
          by Bob1394
          I have used the search, and am stumped.
          My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
          I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
          https://www.badcaps.net/forum/showthread.php?t=81088
          https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
          Observations
          1) [Interaction] Power turned on via TV button (or remote)...
          02-08-2023, 01:03 PM
        • Super360
          Vizio E701i-A3 Vizio logo flashing then turns off
          by Super360
          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
          07-25-2024, 07:06 PM
        • Mulp
          VIZIO M65-C1 Does Not Turn On
          by Mulp
          Hi All,
          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
          01-13-2024, 09:57 PM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
