philips 42pfl5432d got sound no backlight
  • retiredcaps
    • Apr 2010
    • 9271
    Re: philips 42pfl5432d got sound no backlight
    Originally posted by budm
    OK, I look at the INVERTER ON/OFF picture in post11, you do have BL_ON (>3.3V = ON) signal correctly feeding your inverter board, please see my explanation in the picture.
    Hmm, that is what I thought as per post #9, but then that other screenshot threw me totally off.
    --- begin sig file ---
    --- end sig file ---
      Look for little black fuse as shown in the picture, very hard to locate on the board because it looks like resistor. CHI-MEI uses this kind of fuse a lot for supplying the voltage to the inverter PWM IC.
      • retiredcaps
        • Apr 2010
        • 9271
        Ahh, I found it thanks to budm's knowledge. I'm sure if selldoor wasn't missing from this thread, he would have already suggested it.
        Myself, I have neither the experience or eyesight.
        The insistence of clear focused photographs comes through again.
          I know selldoor has real good set of eyes. The picture is an example only, I cannot see it in the pictures in post 1 because they are really out off focus, he will need to look at both inverter boards.
          The inverter boards are really cheap!
          • retiredcaps
            • Apr 2010
            • 9271
            I took allsmith's picture #2 in post #2 and circled the fuse and uploaded to post #23. Allsmith's is a F1 with a 30 on it. A 1.5A/76V fuse.
            It is funny because that is the picture I used to see BLON was pin 14. If I would have looked a bit closer, I would have noticed the F1 fuse right away. But, I'm not selldoor!!
              Ahh, I did not see picture in post2, now it is nice and clear! It still amazed me that shojimmy can sell both boards for $50, all the transformers on the board worth more than 50 bucks.
              Follow-up, he did check this tiny fuse already in post 6:
              "Also there is one more fuse on master board.its a 15a 76 v tested 0.6 ohms meter set to 200 ohms in circuit. Its tiny!!"
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Well, that proves it. I'm dead tired and off to bed now.
                One of my best friends is getting married tomorrow so I have been a little distracted the last few days.
                • allsmith
                  • Aug 2012
                  • 179
                  Ok sorry about not posting the inverter test numbers ,i'll post a pic with all the #'s
                  just so you know my dmm is a very cheap one but its new.
                  The tests where done with the dmm set to 20k setting.
                  Also blon does pass through the power supply board,
                  it comes through from the connector that comes from the main board(red in pic) through the power supply over to the two inverter connectors(blue in pic)
                  sorry about the bad pics,I just bought a new 14 mp camera for this stuff and not getting the hang of it yet, The camera on my razr smart phone still seems better???
                  • allsmith
                    • Aug 2012
                    • 179
                    I did check the 15a 76 v fuse..tested 0.6 ohms meter set to 200 ohms in circuit.
                    I did not check to see if there is voltage on each side of it in fear of slipping and shorting something! but i can if you guys think i should.
                    Also i dont think this matters but sombody else worked on power supply before i got the tv, The two connectors that go to the inverters can be plugged in to either port.Maybe they got them backwards??
                    I marked them the way i found them.
                    looking at pin out screenshot looks to me like it wouldnt matter,but im not sure.
                      The two 24V connectors in parallel are normal, they do that all the time to allow to use the power supply for TV with single inverter or TV with two inverters. They route the BL_ON, Dimming signals through the power supply board so the wiring bundle will be cleaner, very normal practice.
                      Do you get any DC voltage on the IC's on the Inverter board? That very small fuse supply the voltage to the IC's, it may goes through some regulator of some sort to drop the 24V down for the PWM IC, that will be the next thing to check.
                      • allsmith
                        • Aug 2012
                        • 179
                        I checked the fuse,it has 24v on both sides.
                        Not sure what Ic's you want me to check,i'll post some pics if you want to point them out.
                        Also double checked voltage on Blon and its 3.2v not 3.3v like i first thought,dont know if that would make any difference.
                        Also the only thing i can think of,not sure if it would matter or not,is the general purpose caps that the original owner put in the power supply before i got the tv.
                        Could the voltage be unstable do to the illinois capacitors ckh series??
                        Thanks!!
                          3.2~3.3VDC should be more than enough to turn on the inverter, you can verify that by looking up the spec of the LCD panel, it will give you the details spec of the T-CON, INVERTER boards voltages spec.
                          As far as the IC voltages are concern, there should be voltages on at least one pin for the VCC for it to run.
                          U1 looks like a 5V regulator, then check U2, U3 next to it to see if it has 5v feeding them, and then the U31, U4 also. You can look up the spec to see which pin is the VCC pin.
                          • allsmith
                            • Aug 2012
                            • 179
                            [QUOTE=budm;261108]3.2~3.3VDC should be more than enough to turn on the inverter, you can verify that by looking up the spec of the LCD panel, it will give you the details spec of the T-CON, INVERTER boards voltages spec.
                            U1 looks like a 5V regulator, then check U2, U3 next to it to see if it has 5v feeding them, and then the U31, U4 also. You can look up the spec to see which pin is the VCC pin.[/QUOTe
                            Remember im a newbie here lol,And this tiny stuff has me a bit worried i will short something out with my test probe,But i'll give it a go.
                            So u1 should be the first one i check?
                            should i look up the part number first to see what pin to test?
                            u1 i feel a little more comfortable with as its pins are decent size,but the other Ic's! man how do you only touch one pin at a time? microscope!!lol
                            If you can help me test u1 here first,then we can go from there to the IC's
                            I really appreciate your time!!! And expertise!!! thank you!!!
                              We can start with that regulator U1 first since it is big. It has 3 connection, with black probe to ground, then use Red probe to read each pins, label the pin as 1, 2, 3 and report the reading.
                              • allsmith
                                • Aug 2012
                                • 179
                                pin 1= 24.4v
                                pin2=4.9v
                                pin3=00.0v
                                I,ll start looking up part#'s for the IC data sheets
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Originally posted by allsmith
                                  pin 1= 24.4v
                                  pin2=4.9v
                                  pin3=00.0v
                                  U1 is working fine. It is 78M05.
                                  Max input is 35V and obviously output is 5.0V. At 4.9V, it is 2% off spec, but the datasheet it can be between 4.8 and 5.2V.
                                  Are there more digits after 4.9? Resolution (the number of digits) matters.
                                  Move onto the next set of ICs.
                                  • allsmith
                                    • Aug 2012
                                    • 179
                                    U3 IC pinout
                                    I was hoping just the candle in the back blew out and it just needed relit!!LOL
                                    • allsmith
                                      • Aug 2012
                                      • 179
                                      Originally posted by retiredcaps
                                      u1 is working fine. It is 78m05.
                                      max input is 35v and obviously output is 5.0v. At 4.9v, it is 2% off spec, but the datasheet it can be between 4.8 and 5.2v.
                                      Move onto the next set of ics.
                                      pin 2=4.98
                                      • allsmith
                                        • Aug 2012
                                        • 179
                                        Also i can here a tiny click around the IC's when i hit the power button
                                          Clicking sound?
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Kartowl
                                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                                            by Kartowl
                                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                            04-23-2024, 12:57 AM
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
