Sanyo DP42848 Has Sound but No Display
  • kocher
    • Aug 2012
    My issue is similar to the thread https://www.badcaps.net/forum/showthread.php?t=21752 but not the same, and I didn't want to hijack it so I made my own thread.
    I am looking at a friends DP42848. When turning on the unit it will display picture for a second or two and then go black.
    I first tried doing a factory reset, aka holding Vol- while powering on the tv. When I did this, instead of being static when it showed the screen it was all blue and still powered off. I pushed the power button again after it powered off to turn it back on and the unit stayed on.
    I power cycled the unit several times and it worked fine every time, however had humming coming from the bulbs for the first 20 seconds or so until it got warm, then the humming goes away.
    I tried letting the TV on using different inputs for several hours and it worked fine, turned the unit off and let it cool down for 6 or so hours. Turned it back on and still worked fine. I took the tv back to my friends figuring it just needed a reset and was fine now as I couldn't get the issue to resurface.
    Within the day he had the same issue with it getting the 2 seconds to black.
    I have the TV at my house again and first thing I did was to do another reset with vol-. Same result, it 2 second to blacked but with a blue screen instead of static. Then when powered back on worked perfectly fine.
    I've now had the unit for almost a week. I've power cycled it probably 100+ times and works every time. I've let it play for hours then tried power cycling and worked. I've let it play for hours, let it cool then power cycled and it worked. Left it unplugged completely for several hours then plugged it back in and it works fine. I cannot get the issue to resurface to do more testing.
    So now to my questions.
    I have it plugged direct into a wall outlet, while I know he uses a rather old surge protector. Is it possible his surge protector is sending a bad charge and its being stored in the unit until it's reset?
    The only other thing I can think of that would cause this would be if the caps are starting to go bad? But I'm not even sure if this would cause the issue.
    I have tried wiggling all wires and connectors while the unit is on, and while it is off tring to see if its a loose connection and still haven't had a problem.
    Should I replace the caps on the inverter boards and power board, or simply have him plug direct to a wall outlet for a while? Or what else could be tried/tested while it’s working without the issue?
    I assume there is something with the bulbs/wiring/inverter boards since they hum until warm, but Don't know that I can test anything while it's working?
    My wife is currently out of town with our camera, she should be back later tonight and I will be able to post pictures then if needed.
    Thanks for any help/ideas,
    Darryl
  • RobSc
    • Sep 2012
    Re: Sanyo DP42848 Has Sound but No Display
    I doubt that it would be the surge protector. Most it would do is to lower the input voltage and these are rated to go quite a bit below the 110VAC. I would suggest looking at the 24V from power supply board to inverters. Maybe try hitting a few components with freeze spay (duster can sprayed upside down works well) if you suspect it to be a heat related issue.
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
    • nobbnobb1
      Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
      by nobbnobb1
      Hi guys,
      Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
      When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
      02-03-2022, 11:14 AM
    • Gjackson
      Air-conditioning unit power supply failing to power up
      by Gjackson
      Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
      01-08-2022, 09:24 AM
    • cj_reha
      Mystery 80s Sanyo cap - perhaps polymer?
      by cj_reha
      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
      01-06-2023, 09:24 AM
    • edugimeno
      Thermozyklus ZE5 Heating Controller. Bus error
      by edugimeno
      Hi! I was given this board. Its supposed to be a heating controller. It can be programmed over othernet from a computer, and can manage different outputs via a "BUS" connector (there's suppossedly an external module where this BUS wires enter with some relay outputs that power on/off heating valves for different rooms
      The owner stated something like "I reversed the polarity and although the manual states that's its made to withstand reverse polarity, and would wanr the used onscreen, it ended up broken and would say "shortcut in output" all the time, or something...
      03-16-2024, 04:33 PM
