LG 50PC3d-ud blown fuse and power mosfet
  • nswizdum
    • Jan 2011
    • 18
    I posted here a little over a year ago when I first got this TV. The original issue was blown mosfets on the power board, and a bad IPM on the Z-sustain and y-Sustain boards. I had the y-sus and z-sus boards repaired by a reputable company. I bought a "refurbished" power supply board off of eBay. That fixed the problem, although the TV would still refuse to turn on if it had just been turned off. The screen would brighten a little (if it was an LCD, I would describe this as the backlight turning on) and the power LED would blink 5 or so times.
    A couple of weeks ago the TV again refused to turn on, although this time the power LED would only flash 3 times. I took the back off and checked for leaking caps, no problems there, but I did find one shorted mosfet on the power supply board. I replaced it, but when I attempted to power the TV back on, it powered up once (heard the relays click), then immediately shut off. I tried to start it up again, but I get no response. No relay clicks, no LEDs, nothing. I tested the "main" fuse (the one that is right where the 110v AC comes into the TV), and it is showing infinite resistance, so I assume it is blown.
    I wanted to post here for ideas on where I should head next, before I do any more damage.
    Is it possible that the shorted mosfet caused the fuse to be partially damaged, so it failed when I attempted to power it up after the repair? I checked the power supply board again, and found no more bad mosfets. All the caps look fine visually. I heard no loud "pop" like I did previously, when the IPMs blew.
    The model number on the panel is PDP50X30010.DDDRBAB, and I did have 5v standby voltage when the TV was plugged in, before I swapped out the mosfet.
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • Babbar
    by Babbar
    04-12-2024, 01:12 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
