Philips 32PFL9603
  • polino
    • Aug 2012
    • 9
    • Spain
    Philips 32PFL9603
    Hi.
    I have a Philips 32PFL9603 with backlight.
    When I plug the Tv LED blink three times and nothing occurs.
    I looked for the service manual but I can't find it.
    The PSU model is DPS-230MP A.
    Capacitors its seem ok visually.
    May be capacitors but they are well?
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 32PFL9603
    SM may be same as this
    • polino
      • Aug 2012
      • 9
      • Spain
      Hello selldoor.
      Thanks for the link.
      I changed a couple of capacitors suspects but the thing remains the same.
      The relay switch is activated and then activates the relay protection.
      Any idea what might be going?
      • selldoor
        Slow Learner
        • 7870
        Does the service manual say what 3 blinks means?
        We can usually help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...1&d=1290283049
        https://www.badcaps.net/forum/attach...7&d=1280167246
        • pacmyc
          • Aug 2012
          • 41
          • Sweden
          I guess you then have the same PSU board as I?
          Part number 310432852762 or 310432852761.
          Maybe we can help each other out. See my thread.
          • polino
            • Aug 2012
            • 9
            • Spain
            Hi.
            selldoor according the service manual three blikns means 12V supply.
            I tried to messure the voltage and before swiching the protection it apperars but after obviously it isn't.
            pymic my PSU isn't exactily like yours.
            I attached images, sorry for the quality, I have no camera with higher resolution
            • pacmyc
              • Aug 2012
              • 41
              • Sweden
              Originally posted by polino
              Hi.
              Have you tried with the back-cover fitted on the TV?
              (I read somewhere in that when the speakers are not connected they could trigger protection. On my set the speakers are mounted to the backside of the TV)
              It makes it a lot harder troubleshooting..
              • polino
                • Aug 2012
                • 9
                • Spain
                Yes, I tried with all connected and the trouble continue.
                I think the problem is in the PSU, but I can't find it.
                • t.j.
                  • Apr 2010
                  • 383
                  • canada
                  the big cap that is sideways in pic 4, did it come like that or is that a replacement!
                  • polino
                    • Aug 2012
                    • 9
                    • Spain
                    Hello.
                    This is the original, but I put another new identical and the problem persisted.
                      That cap is in the Line side of the circuits, I do not believe it comes like that from factory, no way it will pass UL/CSA/TuV/ETL/CE testing.
                      • polino
                        • Aug 2012
                        • 9
                        • Spain
                        Obviously, it's the same but I have it out for testing.
                        • t.j.
                          • Apr 2010
                          • 383
                          • canada
                          a funky set up! could some one been in there before you?
                            Can we get closed up pictures of the connectors on the power supply board so we can see the labels on them and figure out what the pins are? Good bottom size of the board in hi res picures are needed too.
                            • polino
                              • Aug 2012
                              • 9
                              • Spain
                              Hi.
                              t.j. No, no one have open it before.
                              budm: I attached the back side (I've scanned it), the top side I send it as soon I get a high resolution camera.
                              Thanks again.
                              • selldoor
                                Slow Learner
                                • 7870
                                What voltage do you get when you measure across the BIG Cap.
                                Care High Voltage - meter on 600vDC red probe on positive black probe on negative.
                                If you can get help try to measure when a) set is plugged in b) when power button is pressed
                                In Pic 5 there are 3 grey resistors which I think may be fusable - can you test them
                                • polino
                                  • Aug 2012
                                  • 9
                                  • Spain
                                  selldoor:
                                  The voltage on big cap is 400V when I plug it and then entering protection begins to fall until it reaches 0 volts.
                                  If I press the power button nothing happends.
                                  About the 3 grey resistors I mesured it and are ok.
                                  • polino
                                    • Aug 2012
                                    • 9
                                    • Spain
                                    Hi.
                                    I attached new pictures with more resolution.
                                    • CoinCoin88
                                      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                      by CoinCoin88
                                      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                      09-15-2025, 03:36 AM
                                    • JuniperSprouts
                                      Deep Well Pump Control Box - Start & Run Capacitors & Relay - CB20412CR
                                      by JuniperSprouts
                                      Trying to help a small hospital in Haiti...
                                      Is it possible to test the relay without it being hooked up to the pump motor? It is the normal 5-1-2 configuration, as far as I understand it.
                                      Any tips for testing large start/run capacitors of this size and nature?...
                                      02-22-2023, 08:48 AM
                                    • valvashon
                                      Repair Success! Middle Atlantic UPS2200R-IP
                                      by valvashon
                                      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                      02-06-2024, 12:54 PM
                                    • dragon3x
                                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                      by dragon3x
                                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                      power on.
                                      Here are some examples :
                                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                      switching supply area).
                                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                      than 6.3 V.)
                                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                      I replaced capacitors with aluminum-polymer.
                                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                      03-21-2025, 02:46 PM
                                    • CuriousJohn
                                      Burco boiler power problem
                                      by CuriousJohn
                                      Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                      Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                      This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                      12-22-2024, 10:25 AM
