RCA l37wd12 solid red light
  • eagle00799
    • May 2012
    • 322
    I have read the other posts about this tv but my problem is a bit different than the others. When i plug it in i get a solid red light with no responce at the buttons or remote and when i check the voltage from 1w board i get 120v in,120v out to the p/s and on the 3 prone plug connector from left to right i get -33.3mv,-16.0mv,4.3v. Sometimes when i have it plugged in for a while it will click and the voltages will go up to 2.9v,i forgot the middle one,4.6v. Does anyone have any idea? I replaced 6 bad caps on the P/S and i have the same problem.
  • eagle00799
    • May 2012
    • 322
    Re: RCA l37wd12 solid red light
    Anyone?? If i unplug the 3 wire connector and check voltage at the 1w board all readings are in motion rising up and down. Correct me if i am wrong, the 1w is supposed to send 5volts and 3.3volts to the signal board which then sends 5volts to the P/S unit which would turn it on and then the 12v and 24v would activate?
      Please look at post 77
      https://www.badcaps.net/forum/showth...l37wd12&page=4
      • selldoor
        Slow Learner
        • 7870
        Hi - I hate jumping from one thread to another and looking at out of focus pictures where I cant read the board descriptions. On pic1 can you label the boards with what you are calling them.
        Pic 2 is out of focus can you retake it, what is the connector number at the top of the pic with 1 red and 2 cream? wires. What voltage do you get at those pins?
        Pic 4 and 5 is two halves of a board that would have gone on one picture?
        Pic 6 is mainly out of focus - can you get a better shot of it. There are numerous components which look to be voltage regulators- you will have to list and test them at some stage so start trying to get the part numbers off them.
        Pic7 Not a bad pic but not very interesting.
        We also need to see the backs of the board but only clear and in focus - and without flash.- get them the same orientation as the fronts
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Because you say it will start up sometimes after a few min, I snuggest replacing the rest of the caps on the PSU except for the really big filter cap.
          Muh-soggy-knee
            The user on the above thread mentioned that replacing the main board solved the issue. It may be a lead-free BGA failure, again.
            • cliff_hootarski
              • Jul 2006
              • 411
              Fixed the exact same set today. Symptoms....Set dead, No picture, No sound, No standby red L.E.D. light on front.
              I replaced all six secondary caps, 3 - 1000uf 16v caps, 3 - 1000uf 35v caps. on the main SMPS. Obviously bad (bulged/leaking).
              Also replaced 470 uf 16v cap on the "1W" standby power supply board (secondary side). No outward signs of being bad, used ESR meter to determine that it was bad.
              • coreyand
                • Nov 2014
                • 88
                I just fixed the same set, I only replaced the 3 1000uf 16v they were bulging and tested bad, the other 3 1000uf 35v all tested good. Still not fixed after that until I read this, turns out it was the 470uf 16v on the "1w" standby power supply board (secondary side). Mine too showed no visual signs of being bad. After reading your post I tested it and yep it was bad. Replaced it and everything is working fine now.
                Thanks for all the info. I was afraid after reading this thread it would be the main board or something major.
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  just found a RCA L37wd12 set and exact same issue - replaced 6 1000uf caps (bulged BAD) and 47uf cap (tested bad) on standby board and tv works great - thanks
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                    Lithonia Lighting versus Light of America Compact Fluorescent product quality
                    by sam_sam_sam
                    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                    I also have back when Light of America had these light bulbs available for yard lights
                    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                    While the Lithonia lighting fixture has all most certain bulb failure
                    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                    I have only had this light fixture for not more than a year if it...
                    07-02-2023, 03:45 PM
                    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 03:40 AM
                    LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 09:10 PM
                    09-06-2024, 08:40 PM
