Sylvania LC320SLX No Power-Dead
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: Sylvania LC320SLX No Power-Dead
    Originally posted by kevinm34232
    You said I should be getting 135v is something wrong if Im getting around 165v which is what Im getting off of large cap?
    No - nothing wrong -I think the earlier 135 may have been either a mis type or got the multiplier wrong and used 1.14.
    120 VAC rectified is 120* 1.41 = 160.2 VDC
    Your mains is likely less than 120 VAC so 165VDC is acceptable.
    • RON_CET
      • 217
      what your seeing @ that measurement @ this time of 165 volts DC is complete source voltage derived from your bridge rectifier network,once Q601 and its associated circuit start its operations you should see that 165 volt reduce down close to the 135 volt
      Ron Driver,BSEE,CET,ISCET,NESDA
      • selldoor
        Slow Learner
        • 7870
        #43
        Originally posted by selldoor
        No - nothing wrong -..........
        120 VAC rectified is 120* 1.41 = 160.2 VDC WRONG
        Probably confused you even more - sorry
        Should be 120*1.41 = 169.2VDC
        • kevinm34232
          • May 2012
          • 1884
          Ok going to replace the bad resistor and see what happens well let you know what happens..
          • kevinm34232
            • May 2012
            • 1884
            Originally posted by RON_CET
            if no diodes are shorted ,then using pin 8 of T601 as ground read dc voltage @ Drain of Q601 should have 134 vols DC when set plug in if you do have the 134 v there then check for 5.3v on gate of Q601 those two voltages must be present to kick start Q601 into oscillation to get the power supply running
            I have not tested all the diodes yet but I replaced the one bad resistor and at Q601 I have 163v at drain and 2.0v at gate. Does that give any indication?
            • kevinm34232
              • May 2012
              • 1884
              I know this is first thing to check but I removed main filter cap which is a 470uF200wv, it measures 414uF, ESR 0.07. Is it bad?
              I've checked all resistors and diodes on the "hot" side of the board now all seem good.
              • RON_CET
                • 217
                did you use the same dvm you measure voltage with to measure the Capacitor? again how accurate is it? The 470uf most likely is rated @ +/-10% so if your reading 414uf i would replace the cap,the voltages on Q601 should be suffient to startup set if nothing else bad.I think you said in a prior post that Q601 gate had 0.00 volts due to a open R614 you replaced and now you have 2volts
                • kevinm34232
                  • May 2012
                  • 1884
                  I have a Peak Atlas cap meter that I used to test it. That A33 voltage we were talking about I have 7.7v now, is that supposed to be 33v or 3.3v? Right on Q601 but I think I had 0v when the fuse blew so I'm not sure if I had voltage there before that.
                  • kevinm34232
                    • May 2012
                    • 1884
                    OK so I will replace C605 (do you think this would be the cause of the TV not coming on, i.e. replace before continuing?)
                    And according to SM, that leaves Q601, Q602, and T601 to check?
                    • RON_CET
                      • 217
                      yes your al33v should be al33 if your getting 7volts thats to low and will not work your al33 volts comes from diode D638 also your al3.3 comes from IC631 pin 2
                      • RON_CET
                        • 217
                        no i don't think the C605 cap is keeping set from coming on,remember now since your on the secondary side of T601 for measurement make sure your using ground from secondary side like i post early i think it's pin 15
                        • kevinm34232
                          • May 2012
                          • 1884
                          OK should I check Q602 and T601 first and how?
                          • RON_CET
                            • 217
                            you can check Q602 for b-e short or e-c short also voltage from Q602 with using pin8 of T601 for ground as for t601 possible issue thats very low possibility now back over on secondary side @D638 source for al33v being thats low @7volt with set unplugged make sure you have no low resistance short from cathode which is band side of diode to pin 15 of T601
                            • kevinm34232
                              • May 2012
                              • 1884
                              OK so here's what happens, with my meter on 200k I put black probe to pin 15 of T601 and red probe to band side of D638 and the readings on the meter just keep going up until hits 200 then 0L.
                              FYI I have 3.3v on pin2 of IC631.
                              As for Q602 I have 2.0v on collector pin 2, 0.2v on emitter pin 1.
                              • RON_CET
                                • 217
                                D638 indicate no shorts now,using pin 15 ground of T601 go back to D638 cathode (band side) and reread your voltage there also since you have the 3.3volts on ic631 that now tells me things on primary side of T601 is working so when can forget now Q601,Q602 and associate circuit
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Hey Ron can look at page 37 of SM Block Diagram pin 2 of IC601 is 7.7v same as D638 also see a feedback circuit, any relevance?
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Same voltage reading using pin 15 and/or chassis and cathode/band side 7.7v.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      IC601 voltages
                                      Pin 1 - 6.6v
                                      Pin 2 - 7.6v
                                      Pin 3 - 0.6v
                                      Pin 4 - 0.2v
                                      Assume using ground from each side of IC?
                                      • RON_CET
                                        • 217
                                        ok something sucking up our voltage on cathode D638 we need to start eliminating things on that 33volt line thats killing our 33v
                                        located R661 lift one side then read voltage again @ D638 see if come up
                                          Since the T601 transformer is used to generate more than one output voltages (multi output windings), are other output voltages OK beside the 33V supply?
                                          • madan1
                                            Modding HPF filter
                                            by madan1
                                            Hi everyone.
                                            Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                                            Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                                            After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                                            09-24-2025, 02:06 PM
                                          • Francesc V.
                                            Christmas lights - Something I am doing wrong
                                            by Francesc V.
                                            Hi:
                                            i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                                            I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                                            If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                                            Could...
                                            03-11-2023, 07:38 AM
                                          • bialag
                                            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                            by bialag
                                            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                            03-25-2025, 05:56 PM
                                          • gabrielA7
                                            IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                                            by gabrielA7
                                            Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                                            I saw that the room LED lights up only when the screen is connected, so quiet.
                                            We have all the power supplies, even processor, 1.8V
                                            One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                                            I suspect that there may be some leak in the processor.
                                            Anyway, when I press the power, it...
                                            10-29-2024, 06:48 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
