32" Dynex DXL3210A Won't Power On
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: 32" Dynex DXL3210A Won't Power On
    Originally posted by tieny
    Nope, there's still no response.
    What are the markings on these 3 chips? Just peel off the paper label that is on one of them.
    Muh-soggy-knee
    • tieny
      • Feb 2012
      • 478
      Heres each IC chip going from left to right. I couldn't make out the middle one with paper peeled off.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        The first one is a headphone amp.
        The second one, I cant read the text on it either.
        And the third one, I cant find any info on it.
        Try getting a bright flashlight and putting up to the chip, and move around and see if you can make them out.
        Muh-soggy-knee
          Second one is probably serial FLASH due to its size.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Thats what I am thinking, its hard to figure out the marking codes for them.
            Muh-soggy-knee
            • tieny
              • Feb 2012
              • 478
              Eh no luck, i can't seem to make any of it out, my eyes are going =/
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Did you try a magnifying glass? ;D
                Muh-soggy-knee
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #148
                  You could try Tom66's chalk trick
                  https://www.badcaps.net/forum/showpo...1&postcount=43
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Originally posted by selldoor
                    OMG so smart!!!
                    Whoever invented that should get a cookie!
                    That sure is a fine little tip! Ofc I have no problem reading the text on chips, but sometimes the text is extremely light.
                    Muh-soggy-knee
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #150
                      Is the last one not a 4803a
                      http://www.digikey.com/scripts/DkSea...O4803A&cur=USD
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        It sure is! The symbol is the symbol for Alpha & Omega too.
                        Tieny, whats the voltage on pin 5 of the AO4803A?
                        Muh-soggy-knee
                          Not my trick... Thank Daniel Grillo, the author of that post.
                          • tieny
                            • Feb 2012
                            • 478
                            If only I had some chalk. On pin 5 I get 0v
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              What voltage do you get on pins 2 and 4?
                              Muh-soggy-knee
                              • tieny
                                • Feb 2012
                                • 478
                                Both pins I get 11.34V
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  So that chip must be ok, and its powering something.
                                  We should figure out what that other chip says on it.
                                  Try taking a few more pics to see if you can make out what is written on it, and try it with flash a few times too.
                                  Muh-soggy-knee
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    I didn't have chalk so I used baby powder instead, I can kinda of make out the numbers now more than before.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #158
                                      That middle chip - is it the one that had the label on- what did the label say.
                                      Also it may just be glue obscuring the lettering even if you havent any chalk
                                      try cleaning it with alcohol.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        I just figured it out, its a MAX120 ADC chip.
                                        EDIT: Turns out its NOT a MAX120, I don't know what it is.
                                        Muh-soggy-knee
                                        • ben7
                                          Capaholic
                                          • Jan 2011
                                          • 4059
                                          Tieny, you said you found 6 voltage regulators on the board back in post 38.
                                          I see two more chips that I think could be voltage regulators.
                                          They are both near inductors and capacitors, so I'm guessing they are buck-regulators.
                                          What are their chip numbers?
                                          Muh-soggy-knee
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • redbaron1007
                                            Yamaha HTR-3065 No power/No Standby
                                            by redbaron1007
                                            I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                            S9 13.7V
                                            Pwr Ry 0V
                                            AC Det 9.1V
                                            Mgnd 0V GND
                                            The two pins on the transformer for the operation...
                                            09-12-2024, 03:04 PM
