32" Dynex DXL3210A Won't Power On
    Re: 32" Dynex DXL3210A Won't Power On
    It is my guess since fixed regulator will usually has 1.2, 1.8, 2.5, 3.3V
    That 1122 is what makes me think it is the 1.2V reg.
    I think it is the same as this one:
    http://www.mouser.com/Search/Product...4GeXac6g%3D%3D
    The other one I found with 1122 series regulator are these, but they have 5 pins.
    • tieny
      • Feb 2012
      • 478
      So would the problem still be in the main board or the power supply?
      Also, how do you test if a transistor or a mosfet is defective?
        It looks like the main board problem since it consatnly sedn out the PS_ON signal to turn on the power supply even when the TV is not turn on.
        Transistor can be test with meter that has Diode test function.
        MOSFET is normally open connection device, you can check for short but cannot tell if it has bown open circuits, you will need to build a tester for that.
        Unless anyone else here has seen this problem before with this model, you may want to wait and see if anyone else can chime in.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          Originally posted by tieny
          I removed the fuse from the inverter board, and measuring it now gives me 4.2 Ohms, may be a bad fuse? Do you know the specs of this fuse? Photo below.
          This looks like it may be a golden king resettable fuse so normal test does not apply? cant see a data sheet.
          http://www.tradevv.com/chinasuppliers/goldenkinghk
          To test mosfets/transistors for shorts see retiredcaps' guide
          https://www.badcaps.net/forum/showthread.php?t=10419
          Start at post 19 - whole thing is worth reading if you have not read it.
          • tieny
            • Feb 2012
            • 478
            Does anyone happen to have a service manual for this set?
            • tieny
              • Feb 2012
              • 478
              Just received my esr meter, checked all the caps and none seem to be bad.
              So far the fuses on each board are working, caps are working, regulators on main are in spec, and the voltages on the ps output connector are there. Except the run power and power_on voltage is present constantly before the power button is pressed.
              Originally posted by ben7
              Can you [carefully] measure the voltage on the large rubycon capacitor in the power supply? It should be about 160v.
              Does what happens with the standby supply voltage when you press the power button?
              There's no reading on this capacitor, should it be there during standby?
              There doesn't seem to be much voltage measurement on the primary side of the ps.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #47
                What voltage do you get at the mains fuse- the cap must have worked at some time post six
                you had a picture.
                • tieny
                  • Feb 2012
                  • 478
                  When I meant no reading I meant measurements near 0V on the largest cap. On th main board, the fuse measures 5.27V on both ends of the fuse
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #49
                    Sorry I meant the Mains fuse the glass one where the power lead comes in.
                    Measure with care meter on AC600v should be 120v?
                    • tieny
                      • Feb 2012
                      • 478
                      oh how do you measure AC voltage?
                      Also when measuring the capacitance of a cap, what measurement would it be considered bad?
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #51
                        If it was me doing it Id set my meter on 600vAC You might have 200vAC
                        and that will do as in US. Black probe on the N mains lead pin -( you can see it on the board) then with the red probe touch each end of the fuse and report the result.
                        Someone else may have to advise as I dont have an esr meter. It can vary
                        depending on the cap a 100uf 5% could be 96 - 104
                        a 100uf 10% could be 91 - 109. But the cap may still be faulty which is why you are measuring the esr - didnt you get any instructions with it?
                        • tieny
                          • Feb 2012
                          • 478
                          I'm getting about 119.0v on both ends of the fuse.
                          All the caps I've measured give 0.10 ohms or less esr, but some of the capacitance seems off. 1000uf cap I measured about 820uf, and 2200uf cap measured about 2020uf, so not sure if it's faulty or not.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #53
                            Good - I have been looking for the picture of the back of the power supply
                            so I could verify where you are checking the voltage on the BIG Cap.
                            I cant see one - can you post one - its unusual to get to page3 without?
                            • tieny
                              • Feb 2012
                              • 478
                              heres the back of the power supply board.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #55
                                Ok so to test the Voltage on the BIG cap Meter on 600vDC
                                the two pins are on the back fo the powerboard - in your picture if you look at the top it says bottom between A and C. Straight below where it says bottom there are two big joints- The top one has a + beside it. (is that where you have been testing?)
                                Apply power to the board and very carefully put your black probe on the lower joint and the red probe on the upper joint with the + beside it.
                                  The main power supply must be working, otherwise you will not have 24vDC OUTPUT.
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Okay I got it, it reads 160.2v I was measuring relative to ground before that's why.
                                    Well if it is the main board I'm completely stumped, trying to look for a component that prevents the PON until turned on. Sounds like a short somewhere but don't know where to start. All the regulators are within spec on the main board.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #58
                                      Hi - Couple of things to check - any caps you replaced check that they are the right way round (I Know they should be as in post11 the set came on) and check your soldering -wiggle the cap on the top and look at the joint underneath.
                                      When you repaired a ground pin was that on the power board
                                      or the main board - perhaps you could mark the underside pics of the psu and main board showing which are the Pon and Bon pins -and which pin you repaired. I see there are two similar connectors with a Bon do they both have leads and where do they go to.
                                      If the set is together an overall picture showing the boards in position and the leads might help us.
                                      I know its old ground but seem to be running out of ideas.
                                      Having said that I cant see that any diodes have been checked?
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        The Ground Pin i reflowed was on the PSU. After the TV went off and wouldn't turn on, I reflowed the rest of the connecting pins and almost all the joints on the Secondary side of the PSU.
                                        I did check some diodes and they appear good, but i'll remove them and check them out of circuit just to make sure.
                                        Here are some photos of all the connectors on the PSU and mainboard.
                                        • tieny
                                          • Feb 2012
                                          • 478
                                          What components on the main board are simple to test?
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • redbaron1007
                                            Yamaha HTR-3065 No power/No Standby
                                            by redbaron1007
                                            I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                            S9 13.7V
                                            Pwr Ry 0V
                                            AC Det 9.1V
                                            Mgnd 0V GND
                                            The two pins on the transformer for the operation...
                                            09-12-2024, 03:04 PM
