32" Dynex DXL3210A Won't Power On
    Re: 32" Dynex DXL3210A Won't Power On
    Peak Electronic Design model ESR60 does me well but a bit pricey at ~£70.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Originally posted by tieny
      Oh those rubycons were just spares I just swapped since I had a few extra with the same specs.
      How would I go about checking the inverters? Wouldnt the TV turn on (blue led) but just with no picture then?
      Does the psu make multiple click sounds (like tic,tic,tic,tic,tic..) when you try to turn it on?
      Try unplugging the inverter board and try powering the TV on, if it still won't come on then the issue is either on the mainboard, or the psu.
      Can we have some pics of the mainboard too?
      Muh-soggy-knee
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        "So far only checked the fuse, but it doesn't seem open"
        There are at least 2 fuses on the inverter. Check them and also check what voltage
        you get at each side of each fuse.
        Are you getting the correct voltages at the connector on the main board - looks like they are listed one looks like it should should be 24v?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Isnt that it in post 1? or do you mean the backs of the boards?
          • tieny
            • Feb 2012
            • 478
            I was looking at the altas ESR70, whats the difference between the ESR60 and ESR70?
            The PSU doesn't make any sounds at all when I click the power button. I tried unplugging the inverter from the PSU, but the TV still has no response when I press the power button (red LED is still on though)
            I checked the larger white fuse, and the smaller blue fuse on the inverter board. Both ends of each fuse read 24.6V, however when I measured the resistance on the blue fuse I got 2.5 ohms and the white fuse reads 0.4 ohms. The blue fuse resistance seems high but I don't know if its just the specs of the fuse.
            I checked the voltages from the 24V pin output on the PSU and both read 24.3V coming out of the PSU.
            • tieny
              • Feb 2012
              • 478
              photos of the back of the main board, The fuse was checked and not opened.
                The PON should be there when the the power switch is activated. We need that first.
                • tieny
                  • Feb 2012
                  • 478
                  When plugged in, measuring the PON pin gives me a reading of 3.06V but every now and then the reading would drop and rise back up to 3.06V quickly.
                    And the standby 5.1V is at xxxV?
                    • tieny
                      • Feb 2012
                      • 478
                      They read, 5.30v and 5.27V
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Can you [carefully] measure the voltage on the large rubycon capacitor in the power supply? It should be about 160v.
                        Does what happens with the standby supply voltage when you press the power button?
                        Muh-soggy-knee
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          2.5 ohms? seems suspicious. Take the fuse off the board and measure its resistance again. It should be less than an ohm if its good.
                          Muh-soggy-knee
                            OK, the standby 5.1V power supply is working, and you also get the 24Vdc power supply when power switch is activated (but the red LED is still on) is working, so that means the PS_ON is working, otherwise you will not get the 24Vdc. On the connector, there is a pin "BON" for backlights on, what do you get there?
                            • tieny
                              • Feb 2012
                              • 478
                              Measuring the largest capacitor, the postive and negative pin read 0V. There is no response with both 5V1 or PON pin voltages when I press the Power button.
                              I removed the fuse from the inverter board, and measuring it now gives me 4.2 Ohms, may be a bad fuse? Do you know the specs of this fuse? Photo below.
                              The BON pin read near 0V or more accurately it measures 0.018V on standby.
                                "There is no response with both 5V1 or PON pin voltages when I press the Power button."
                                So you mean the 5.1V is always around 5v which that is how it should be since it is the standby voltage which should be there when you plug the TV into an outlet. The PON (from the Main board) should go from 0v to around 3v or higher when power switch is turn on, this PON will turn on the 24V for the backlights inverter board. Once the TV finished self test, the main board will send the BON to turn on the backlights, and also the panel on to turn on the T-CON board.
                                So right now you do not have the BON, but do you have the PON and the 24Vdc?
                                • tieny
                                  • Feb 2012
                                  • 478
                                  Yes, once I plug in the tv, PON and 24V are already present without me pressing the power on yet and BON is not present.
                                    That means the main board is not working right. You will have to start checking the voltage regulators on the main board.
                                    • tieny
                                      • Feb 2012
                                      • 478
                                      I found 6 voltages regulators on the main board, how would I know if the regulator is defective? Do regulators usually have one ground pin that is suppose to read 0V?
                                      N603
                                      AZ1117D 8.3E1 B89N70
                                      pin1-0v
                                      pin2-3.31v
                                      pin3-5.27v
                                      N602
                                      8JH 1117H
                                      pin1-2.07v
                                      pin2-3.32v
                                      pin3-5.31v
                                      N604
                                      8JH 1117H
                                      pin1-0.58v
                                      pin2-1.84v
                                      pin3-3.32v
                                      N606A
                                      1122 0730B
                                      pin1-0v
                                      pin2-1.20v
                                      pin3-3.31v
                                      N605
                                      pin1-0v
                                      pin2-3.31v
                                      pin3-5.25v
                                      N611 (Largest one)
                                      AZI0845 ADJEI 829J43
                                      pin1-3.84v
                                      pin2-5.11v
                                      pin3-8.37v
                                        You can tell if the Regulator is a fixed regulator by observe the followings:notes, we will look at the body of the regulator with 3 bottom pins pointing toward you, lets make left pin to be pin1, middle pin will be pin 2, right pin will be pin3.
                                        Fixed regulator, pin1 will be tied to ground, pin2 will be output pin, pin 3 is an input pin.The numbering on the regulator will indicate the output voltage. I.E. AZ117D 3.3 (or 33 on other brand) = 3.3V regulator. Notes: I think you misread the 3 as an 8. The output should be within +/-2%.
                                        Adjustable regulator, there will be one resistor connected between pin1 and pin2, and there is another between pin1 and ground. There is a formula to calculate the output voltage which is set by the two resistors. The main thing on the adjustable regulator is that the voltage between pin1 and pin2 will always and HAS to be 1.25V, if you do not have this, then the regulator is bad. Second thing is that the voltage between pin1 and pin2 (1.25V) + the voltage between pin 1 and ground = output voltage. I.E. Pin1&2 = 1.25 + 1.25 pin1 and ground, then the output will be 2.5V +/- 2%.
                                        N603: This is 3.3V fixed regulator. OK
                                        AZ1117D 8.3E1 B89N70: more likely to be AZ1117D 3.3E1 B89N70
                                        pin1-0v
                                        pin2-3.31v
                                        pin3-5.27v
                                        N602
                                        8JH 1117H: Adjustable: 1.25 + 2.07 = 3.32V, OK.
                                        pin1-2.07v
                                        pin2-3.32v
                                        pin3-5.31v
                                        N604
                                        8JH 1117H: Adjustable 1.25 + 0.58 = 1.83V, OK.
                                        pin1-0.58v
                                        pin2-1.84v
                                        pin3-3.32v
                                        N606A
                                        1122 0730B: Fixed regulator: 1.20V, OK.
                                        pin1-0v
                                        pin2-1.20v
                                        pin3-3.31v
                                        N605
                                        AZ1117D 8.3E1 B89N70: Fixed regulator, 3.3V, OK.
                                        pin1-0v
                                        pin2-3.31v
                                        pin3-5.25v
                                        N611 (Largest one)
                                        AZI0845 ADJEI 829J43: Adjustable, 1.25 +3.84 = 5.09V, OK.
                                        pin1-3.84v
                                        pin2-5.11v
                                        pin3-8.37v
                                        • tieny
                                          • Feb 2012
                                          • 478
                                          If the numbering on the fixed regulator is 1122 0730B, how do you know that the output voltage is 1.20V?
                                          All the regulators on the main board are working perfectly then, I'm still stumped on this.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • redbaron1007
                                            Yamaha HTR-3065 No power/No Standby
                                            by redbaron1007
                                            I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                            S9 13.7V
                                            Pwr Ry 0V
                                            AC Det 9.1V
                                            Mgnd 0V GND
                                            The two pins on the transformer for the operation...
                                            09-12-2024, 03:04 PM
