Vizio VO42L question
  • tibimakai
    • Jan 2012
    • 3680
    I'm working on this Vizio and I'm puzzled that what it's wrong with it.
    Usually the slave inverter it's the problem, but this time the 8.5K values at the fet transistors were there and the chip looked OK. One of the caps was bulged, which I have replaced.
    I have found a low value on one of the fet transistors on the master inverter(even after removal).
    Replaced the fet and the value it was still low, it got a bit higher, but it was still very low(76 ohm), so I have replaced the chip and it became 8.5K.
    I have done the bulb test on the power supply and check out OK.
    The voltages are there and still no sign of back light(at least).
    The blue LED comes on for like three seconds on the master inverter board, the Vizio logo works as it should, with the buttons.
    What else can I check?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio VO42L question
    I have measured the 2 big capacitors on both inverter boards in circuit and all of them show E=0.00 and respectively C=2650(most likely they are in parallel, they are 680uf) on the ESR meter.
    One of them it's a new capacitor and that one shows E=0.00.
    • retiredcaps
      • Apr 2010
      • 9271
      As usual, a picture of your boards would help.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        1) Does BL_ON or equivalent go to > 3V DC and stay there?
        2) Did you check all the voltage regulators on the main board?
        • tibimakai
          • Jan 2012
          • 3680
          The 3.3V is there as all the other voltages on the power supply.
          The TV can be turned on and off, there is no problem there, in fact the TV acts as everything it's OK. But there is no sign of life from the panel.
          Vizio logo turns white or orange if I turn it off.
          The voltages are there, the blue LED turns on and then off on the master inverter.
          I'm trying to see a picture with a flash light, but I can't see any.
          Usually on these TVs the slave board has issues, but this time I had problem on the master inverter.
          How can I check if the BD ICs on the inverters are working?
          I have replaced the master IC since after replacing a shorted FET it was still reading very low.
          Now all the FETs on both boards are showing 8.49-8.51 KOHM.
          After checking with a lupe my soldering job, I have found a leg not soldered to the PCB tab. Do you think that it's possible that the IC it's not working properly because of this?
          Another question, how do I know if the slave IC it's working properly or not?
          Do you think that it's worth checking the regulators on the mainboard since the TV turns off properly?
          • retiredcaps
            • Apr 2010
            • 9271
            Fix your soldering first and retest.
            For Vizio TVs in general, regardless of age, I think it is mandatory to check all the regulators on the main board. About 75% of the problems with Vizios comes down to those components. It only takes 5 minutes to rule them out so why not?
            • tibimakai
              • Jan 2012
              • 3680
              The IC it's soldered now, but it's no change. What I meant is the IC can't be damaged because one pin wasn't soldered?
              I will check all the regulators tomorrow, and I will let you know.
              • tibimakai
                • Jan 2012
                • 3680
                Something went wrong, but not sure what happened.
                I had a bit of time to check the regulators on the mainboard and this time the TV did not turn on anymore.
                There is no PS_ON, 12V or 24V with everything connected.
                If I test the PS, it's all good, but it seems that I have a problem with the PS_ON voltage.
                I have found only one regulator (if I remember correctly is the U22)with 5.2V, 3.3V and 2.09V.
                Not sure what happened.
                I will have to take much better pictures.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Not sure what happened, but it is back in the same stage as before, after removing the mainboard for taking pictures.
                  I have all the voltages at the PS connectors. The blue LED comes on on the master inverter board and the Vizio logo turns white or turns orange when turned off.
                  I have checked all the regulators and here are the voltages.
                  U16: 11.84V/0.00V/5.02V
                  U44: 11.84V/9.59V/8.35V
                  U22: 5.12V/3.35V/2.10V
                  U17: 5.07V/3.36V/2.10V
                  U21: 2.54V/1.16V/0.00V
                  U??: 5.07V/2.54V/1.27V
                  U20: 3.30V/1.81V/0.56V
                  STBY: 5.52V
                  PSON: 3.30V
                  A: 2.58V
                  B: 5.07V
                  12V: 11.88V
                  24V: 25.05V
                  Next I will be uploading the pictures.
                  I have a question until then, how do I know if the BD9897FS are OK?
                  If the FET transistors have the 8.5Kohm, then they should be OK?
                  I have received the shipment from Digikey, so I will be replacing the four capacitors on the inverter boards.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Replaced the inverter capacitors and still no change.
                    Here is the mainboard picture:
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I think U21 is bad. If the top tab is "up" or north, it looks like you are numbering the pins right to left.
                      From your pic, it looks like the part number is AMC1117 which is an adjustable voltage regulator. I just wrote about this, again, 2 minutes ago, so I will cut & paste from
                      https://www.badcaps.net/forum/showpo...7&postcount=50
                      The correct output for pin 2 (middle) is based on this calculation:
                      DC V of pin 1 + 1.25V = output of pin 2.
                      So 0 + 1.25 should be the "correct" output. You have 1.16V. Most specifications for regulators are +/- 1%.
                      At 1.16, it is (1.25-1.16)/1.25 = 7.2% out of spec (see post #6 last paragraph).
                      The same above URL gives a replacement part number.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        PS. There is little to NO chance that your brand new Fluke 87V is incorrect either when measuring U21.
                        It is 0.05% DC V accuracy +1 count.
                        For fun, you can put it into 20,000 count mode by holding down the backlight button for 2 seconds and then retake the reading on pin 2.
                        It should give you 5 digits. Something like
                        1.1632
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Thank you, I will check it tomorrow.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I'm an idiot, I have re-checked my notes and it's 1.26V, so it's OK.
                            How do I know if the inverter ICs are OK or not? The FET transistors have the right 8.5Kohm. But you are right that it's very possible to have something on the mainboard also. I should see something on the screen if only the inverters would be the problem.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              So any input?
                              Should I replace the IC on the slave board?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                You can try to replace the IC. The voltage regulators all look good now that you provided the correct info.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I should see a picture with the flashlight?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Some members see a picture, others don't. It might depend on the screen, type of glass, flashlight lumens, etc.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I have replaced the IC on the slave inverter and there is no change.
                                      Panel seems dead.
                                      How do I know that the inverters are working?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        I guess you can measure the voltage on the FETs and see if there is any voltage on the Gate, Drain and Source.
