Toshiba 30HF84
  • luke9511
    • Jul 2009
    • 101
    Re: Toshiba 30HF84
    ok i went online and looked up how to test these transistors with my meter and the HOT tested fine so thats not it, however i tested Q504 which im not sure what it is yet, but anyway i tested one leg and got a reading and then i tested the other and didnt get anything at all, im thinking whatever Q504 is, its bad and needs to be replaced, now i just need to find a diagram and find out what it is
    • luke9511
      • Jul 2009
      • 101
      Re: Toshiba 30HF84
      for some reason i cannot edit my post above, but i desolder the part and using a magnifying glass i got the following off of it
      ST w3s428
      p15nk507
      • R_J
        • 9588
        Re: Toshiba 30HF84
        Q504 is a fet in the power supply, its not bad, if it was the tv would not come on at all. You either have a weak capacitor in the power supply or in the deflection circuit.
        • luke9511
          • Jul 2009
          • 101
          Re: Toshiba 30HF84
          something around where its at is causing that sound and this is the only thing that i can think of, im going to replace it anyway as i messed it up some trying to remove it, i will also add some pictures of the board
          • luke9511
            • Jul 2009
            • 101
            Re: Toshiba 30HF84
            does anyone know of a alternative to this part?
            AE004387
            • R_J
              • 9588
              Re: Toshiba 30HF84
              Stp15nk50zfp
              Digikey 497-12055-5-ND
              If you type that toshiba part number into google you will get the original number of the fet. now search for the original number and find a source. I found it at digikey and others.
              • luke9511
                • Jul 2009
                • 101
                #27
                Re: Toshiba 30HF84
                Originally posted by R_J
                Stp15nk50zfp
                thank you very very much, i did try searching but i could not find anything i may have been looking in the wrong places, but i have ordered one and it did arrive but i have not soldered it in yet, once some other stuff comes in the mail i will do it then and report back
                • luke9511
                  • Jul 2009
                  • 101
                  #28
                  Re: Toshiba 30HF84
                  ok sorry for not posting back, i got the part a while back and put it in and that was not it, if anyone has any other ideas please let me know
                  • kasfamily
                    • Aug 2014
                    • 774
                    • Russia
                    #29
                    Re: Toshiba 30HF84
                    Show photo main board top and bottom
                    • luke9511
                      • Jul 2009
                      • 101
                      #30
                      Re: Toshiba 30HF84
                      there ya go let me know if you want any close ups
                      • kasfamily
                        • Aug 2014
                        • 774
                        • Russia
                        #31
                        Re: Toshiba 30HF84
                        Please foto this place and the name of this chip
                        • luke9511
                          • Jul 2009
                          • 101
                          #32
                          Re: Toshiba 30HF84
                          here ya go it is a Toshiba TA1360 ANG
                          JAPAN 440KA1
                          • kasfamily
                            • Aug 2014
                            • 774
                            • Russia
                            #33
                            Re: Toshiba 30HF84
                            Need soldered well X603
                            • luke9511
                              • Jul 2009
                              • 101
                              #34
                              Re: Toshiba 30HF84
                              solder joints are fine, but here is the part from the service manual and the part number from the part itself
                              X603 AE004348 1002R01502 CERAMIC OSCILLATOR CSBLA503KECZF30-B0
                              B503 F 30
                              • kasfamily
                                • Aug 2014
                                • 774
                                • Russia
                                #35
                                Re: Toshiba 30HF84
                                I know. Still need to solder
                                • luke9511
                                  • Jul 2009
                                  • 101
                                  #36
                                  Re: Toshiba 30HF84
                                  you mean replace it with a new one or just resolder the solder joints?
                                  • kasfamily
                                    • Aug 2014
                                    • 774
                                    • Russia
                                    #37
                                    Re: Toshiba 30HF84
                                    Usually changes
                                    • luke9511
                                      • Jul 2009
                                      • 101
                                      #38
                                      Re: Toshiba 30HF84
                                      Usually changes
                                      im going to guess and say replace it only issue is I can't find a replacement
                                      • kasfamily
                                        • Aug 2014
                                        • 774
                                        • Russia
                                        #39
                                        Re: Toshiba 30HF84
                                        http://www.alibaba.com/trade/search?...hText=ztb503f2
                                        • luke9511
                                          • Jul 2009
                                          • 101
                                          #40
                                          Re: Toshiba 30HF84
                                          nvm im stupid
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            09-06-2024, 05:33 AM
