need help to test inverter transformer
  • retiredcaps
    • Apr 2010
    • 9271
    Re: need help to test inverter transformer
    Originally posted by woaimi
    well, i got the fuses, soldered it in and it blown instantly, so I followed your suggestion. the rectifier is good but I couldn't confirm the mosfets (following your ohm method) as each time i try i get different result.
    Always post your actual readings from your multimeter. We have had people state something was "good" only to find out they are mis-interpreting their results.
    Also post your multimeter make and model so we know what you are using.
    --- begin sig file ---
    --- end sig file ---
    • woaimi
      • Sep 2005
      • 94
      • US
      I'm using a cheapy Craftsman model 82141. I changed battery, set to 200 ohm the screen read "1" in open position and 00.3 when probes together. When I check the mosfets at 200 ohm setting I get out of range problem so I switch to 2000 ohm setting instead. Here what I've got from testing multiple times.
      Referring to the photo that retiredcaps circled the mosfets
      The top one (by itself)
      S-G: with red probe on S = 528 Ohm, with red probe on G = 1032 Ohm
      G-D: with red probe on G = 1695 Ohm, with red probe on D = no reading
      S-D: with red probe on S = 400 Ohm, with red probe on D = no reading
      The pair below
      The left one
      S-G: with red probe on S = 22 Ohm, with red probe on G = 22 Ohm
      G-D: with red probe on G = 427 Ohm, with red probe on D = no reading
      S-D: with red probe on S = 403 Ohm, with red probe on D = no reading
      The right one
      G-D: with red probe on G = 425 Ohm, with red probe on D = no reading
      On the rectifier: meter was set at diode mode
      Between (+) and the 2nd leg with red probe on (+) = no reading, with black probe on (+) = 548
      Between the 2nd and 3rd leg = no reading
      Between the 3rd leg and the (-) with red probe on (-) = 547, with black probe on (-) = no reading
      • retiredcaps
        • Apr 2010
        • 9271
        The pair below
        The left one
        The right one
        1) Multimeter tutorial. I have written about this before several times and just last week.
        2) A multimeter always gives a reading. There is no such thing as "no reading". If your multimeter is displaying "1" on the left hand side of the lcd, it is telling you the measurement is "out of range".
        3) For finding a short, we are only interested if the reading is below 30 ohms. We don't care if the actual reading is 200 ohms, 2000ohms, or 2M ohms. So on the lowest scale (200 ohms), if the multimeter shows a "1" on the left hand side of the screen, it is telling you the reading is > 200 ohms. That is, not shorted.
        4) Most people understand green means go and red means stop. However, if I say green means don't stop and red means don't go, it messes people up. This is why #3 above is so hard for people to understand.
        5) The "pair below" are shorted S-G (22 ohms is shorted). Desolder both and retest out of circuit.
        6) For the bridge rectifier test, which I have written many times, I prefer to see this test. Number the bridge rectifier pins 1, 2, 3, and 4. Measure the resistance between pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. Report all readings.
        • woaimi
          • Sep 2005
          • 94
          • US
          please excuse my ignorant! I just wanted to make sure I get some real values other than 1 so I changed the mode setting. Anyhow, I got the mosfets desoldered will test them when i get home tonight.
          the rectifier resistance report, I start from left the right with 1 being the pin labeled with (-).
          1-2 = 453
          1-3 = 453
          1-4 = 453
          2-3 = 1.325M
          2-4 = 451
          3-4 = 453
          does that look right?
          many thanks
          • retiredcaps
            • Apr 2010
            • 9271
            1-2 = 453
            1-3 = 453
            1-4 = 453
            2-3 = 1.325M
            2-4 = 451
            3-4 = 453
            Those readings seem a bit strange. They indicate the rectifier is not shorted, but 5 of your readings are all 453 ohms. Desolder the mosfets first. With the mosfets out, retest the rectifier "in circuit" and report the readings again.
            • woaimi
              • Sep 2005
              • 94
              • US
              #26
              with the 2 suspected mosfets removed this is what I've got from the rectifier
              1-2 =33K
              1-3 = 34.5K
              1-4 = 33K
              2-3 = 1.36M
              2-4 = 34.5K
              3-4 = 34.6K
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                1-2 =33K
                1-3 = 34.5K
                1-4 = 33K
                2-3 = 1.36M
                2-4 = 34.5K
                3-4 = 34.6K
                The readings above suggest your bridge rectifier is NOT shorted.
                Retest the mosfets now that you have removed them and post the readings.
                • woaimi
                  • Sep 2005
                  • 94
                  • US
                  #28
                  should i be using the same "under 30 Ohm method" ?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Yes, measure the resistance between pins 1-2, 1-3, and 2-3.
                    • woaimi
                      • Sep 2005
                      • 94
                      • US
                      #30
                      mosfet #1
                      G-D = 1
                      G-S = 1
                      D-S = 265K
                      mosfet #2
                      G-D = 1
                      G-S = 1
                      D-S = 269K
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        mosfet #1
                        G-D = 1
                        G-S = 1
                        D-S = 265K
                        mosfet #2
                        G-D = 1
                        G-S = 1
                        D-S = 269K
                        If that is 1 ohm, then both mosfets are definitely shorted and bad. If it is out of range, then the mosfet is good. So which is it?
                        • woaimi
                          • Sep 2005
                          • 94
                          • US
                          #32
                          usually if something out of range I would be able to see the display flashes some value then go to 1. Not this case, number 1 remain the same as an open circuit. i'll probably replace them anyway. what's bad?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            You are not correct in your interpretation. I think you need to re-read post #23 again.
                            If my explanation isn't clear, then try
                            http://www.sparkfun.com/tutorials/202
                            • woaimi
                              • Sep 2005
                              • 94
                              • US
                              #34
                              sorry for my previous senseless comment, i was typing my own thoughts (like thinking out loud). It wasn't 1 ohm, it was the 1 on the left side of the screen.
                              thanks for that very useful tutorial
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Okay, so now that you understand the mosfets are not shorted, there are 4 other diodes in the primary section (as outlined on the pcb by the dotted line) that are suspects in causing the fuse to blow.
                                Test all 4 in circuit first using the diode test function on your multimeter. Report all your readings. Again you should have 2 readings per diode. If any of them look suspicious, then desolder them to verify out of circuit.
                                • woaimi
                                  • Sep 2005
                                  • 94
                                  • US
                                  #36
                                  got the measurements includes in the photo. there was 1 (the one with 597 &1) initially was 1 & 1 in both direction. I desoldered it, retested still 1 &1, 15 mins later before i post result i retested again, that's when it gave me 597 &1
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    The above is odd behaviour. I would retest that diode again out of circuit maybe every 15 minutes and check the results again.
                                    • woaimi
                                      • Sep 2005
                                      • 94
                                      • US
                                      #38
                                      done it many times since then and getting the same readings. there are only the caps and resistors are untested in the primary. Should those diodes (i think) on the secondary be concerned? These devices look like transistors with 3 leads but the board indicates with Dxxx.
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        done it many times since then and getting the same readings. .
                                        What same readings 1 and 1 or 1 and 597 ?
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #40
                                          Yes those are diodes some examples are here
                                          http://www.westfloridacomponents.com...ierDiodes.html
                                          Can you make out any part numbers on them?
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
