LG Z50PT320 (PU14K) Plasma no brightness
  • ac4aq
    • Dec 2010
    • 5
    Friends,
    I am an audio technician, fixing mostly large amplifiers from QSC, Crown Audio, Samson, etc. who needs to repair a Zenith/LG plasma which we installed.
    It has no brightness and apprently no audio, tho' it might if it were on a source with audio supplied. It turns on, the red LED blinks several times, the Y-sus board makes a normal sound. Va=55 VDC, Vs=205, +5 is OK, +3.3 is OK but +15 = 18.3 VDC. Power consumption is low, jumping between 50 and 90 watts. The system control is active, it will switch between various source and if left on it shuts down due to no signal after 15 minutes. If the lower Y-drive board is removed a distorted image appears lower half of screen consisting of red and blue pixels which change as it is switched thru sources.
    Action taken so far: while it playing, an IC on the upper Y-drive board spontaneously smoked. Replaced both Y-drive boards and Y-sus board and got back to square one.
    I think it has corrupted firmware, not a hardware problem at this point. I can't find a troubleshooting flowchart for the PDP50T3 plasma panel. Any suggestions would be much appreciated.
    jeff/ jHh
  • ac4aq
    • Dec 2010
    • 5
    Re: LG Z50PT320 (PU14K) Plasma no brightness
    Since then I have replaced R2, R16 and R17 on the Z-sus board, they were all open. Made no difference in the symptoms, Z-sus heat sinks remain cold. Also I've yet to find a download of MStar v4.1.8 so I can communicate with the SysCon.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
