Sharp Aquos LC-32D40U - no image
--- begin sig file ---
--- end sig file --- -
Re: Sharp Aquos LC-32D40U - no image
I would suggest to replace memory dump properly, for Sharp lcd tv, the memory dump compromise is a typical failure, Success, from Romania, Cluj, only better!Comment
Find the part number and datasheets for the following components on the t-con board: U300, Q302, and U5. My guess is it will be one of the first 2 that does DC-DC conversion?--- begin sig file ---
--- end sig file ---Comment
List them and we will have a look. Selldoor is pretty good at finding them.--- begin sig file ---
VDD, VGL, and VGH should always be there when Vcc is there.
VDD is usually something like 15-20V, VGL around -5 to -10V, and VGH 20 to 35V.
U300 should be the power controller for the t-con. See if you can read the numbers on top and post them here.Comment
This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
Help keep these from the landfillsComment
U300 - 16 pin chip, numbers as they appear:
3687V
1H05N08
Q302 - 8 pin chip, numbers as they appear:
4422
8E5519
U5 - 8 pin chip, numbers as they appear:
ATMEL602
25F512AN
Q303 - 6 pin chip, numbers as they appear:
D5CD IF
Q301 - 6 pin chip, numbers as they appear:
D13D 1LLast edited by ahickman; 07-05-2012, 04:48 AM.Comment
Originally posted by ahickmanAnyone?
U300 is the t-con power supply controller. It likely controls VDD, VGH, and VGL.
Perhaps I should have written it more clearly in my last post, but you really *should* double-check those voltages I mentioned because it just seems like the TV was off when you tried to measure them. Either that, or somehow you didn't measure them correctly. Check your multimeter and make sure you're measuring with respect to ground.
Also, a few more clear pictures of the t-con would be helpful.Comment
With rain pretty much all of June and some sun finally in July, I would much rather be outside enjoying the little summer we have in Canada rather than searching for part numbers all day.--- begin sig file ---
Momaka,
Sorry, it is just so very rewarding to make progress on these sets and I am very dependent on the knowledge of this forum. It has been VERY hot here in VA and I find myself looking for such projects during the heat of the day.
I have snapped a few close-ups of the t-con board. Had to take sequential pictures in order to get decent resolution.
I retested the 3V pad and several others using one of the screws going to chassis as GND. Got the exact same voltages. I also used a heat sink on the secondary side of the PS as GND. No changes in voltages.
While I could blindly order the t-con board from ShopJimmy, I would rather have the satisfaction of learning more about troubleshooting the t-con. All help/guidance is greatly appreciated and I will try to be more patient
aaronComment
2) The very first search result for
3687V
leads to
http://www.alldatasheet.com/datashee...I/FA3687V.html
3) pin 6 = VCC and pin 11 is GND. What is the DC voltage on pin 6?
4) pin 13 is regulated output voltage. What is the DC voltage on pin 13?--- begin sig file ---
Depending on the accuracy of your multimeter and whether it is within calibration limits, this IC could be bad. According to page 7 of the datasheet, the regulated voltage (pin 13) should be 2.200V DC +/- 1% (between 2.178 and 2.222).
At 2.31V, it is 5% out. Is this enough to stop the t-con from working? I'm not 100% sure. If this were a "jellybean" 1117 voltage regulator, I would confidently say it is definitely bad at 5% out.--- begin sig file ---
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
by klassicHi community,
I will describe my problem with a TV in those short following terms to be the most precise :
What i have :
Sharp Aquos LC-60LE635E
power board DPS-162KP-1
main logic board QPWBXF733WJN2
symptoms :
white led light logo at startup,
after 2 minutes, blinking 3 times a row, repeating
no backlight (and apparently no picture, checked panel with flashlight)
no startup sound
powerboard investigations :
1-2 PNL : 0v
3-4 GND
5-6-7-8 UR : 13.15v
9-10-11-12... -
This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-06-2024, 10:56 AM
This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 10:56 AM
- Loading...
