Jvc lt-24dk3bj
  • Rtech
    • Jul 2010
    • 1095
    Jvc lt-24dk3bj
    Play with PC Monitors more than Television,however I have recently had a number of requests for help.This Has the Blue Light coming on and thats it, no image,sound etc.Looking inside,there is 12v going to the Inverter but no BL-On voltage.Checking around I have 5V from a 78DO5, 2,3volts from one of the LDOs and no input and therefore no output from a 1117-18 LDO.Before we look to possibly change the latter, I have no idea what the component sitting in the middle of the Board is marked 110D,any help would be appreciated.
    Re: Jvc lt-24dk3bj
    I've seen a lot of these on eBay with the same fault, developing after 6-9 months. I think it's the same as the Bush LT24M3 I've got, which has a failed LDO on the main board. Can you post an overhead shot of the unit?
    • Rtech
      • Jul 2010
      • 1095
      Re: Jvc lt-24dk3bj
      Here you are, cables on the right go to the DVD.
        Re: Jvc lt-24dk3bj
        Okay, it's not the same as mine - sorry - wish it was that easy! But anyway, which LDO is outputting 2.3V? That's a strange voltage. What is the voltage between the output and adjust pins for that regulator?
        BTW, any clues as to who is the OEM on that one? The Bush I have is a Haier rebadge - even the model number is the same - Haier LT24M3...
        • Rtech
          • Jul 2010
          • 1095
          Re: Jvc lt-24dk3bj
          Sorry, 3.3v it should have read......made by Victor Company Of Japan Limited !!!
          Do you know what this '110D' is ???
            Re: Jvc lt-24dk3bj
            Is it really a genuine JVC? Or just a rebadged model? It would surprise me if JVC actually make this model.
            I do not know what "110D" is.
            Can you check the regulator which is outputting 2.3V as I instructed above? I suspect that is faulty.
            • selldoor
              Slow Learner
              • 7870
              Re: Jvc lt-24dk3bj
              Pictures are a bit grainy for troubleshooting - Mystery component - no idea but best guess a diode with the dot being the cathode end? Does it test as a diode?
                Re: Jvc lt-24dk3bj
                Oh I see the 110D. It is a resettable fuse. It should measure a short if okay.
                • Rtech
                  • Jul 2010
                  • 1095
                  Re: Jvc lt-24dk3bj
                  Does measure a short. so will change the 1117-18 tomorrow,amd hope that is the fault.
                    Re: Jvc lt-24dk3bj
                    Is the 1117-18 measuring 2.3V?
                    • Rtech
                      • Jul 2010
                      • 1095
                      Re: Jvc lt-24dk3bj
                      No It was a typing error the other LDO is 3.3,and fine.the '110D' thanks for that,is there any info anywhere showing them ? how they reset ?/etc.
                        Re: Jvc lt-24dk3bj
                        They are known as poly fuses.
                        When excessive current flows through them they increase rapidly in resistance.
                        When they cool down their resistance falls again and the let current through.
                        Under repeated cycling they can permanently fail open, they are designed to only open a few hundred times, so they can fail, for example, if the power supply draws a lot of current on start up.
                        http://en.wikipedia.org/wiki/Resettable_fuse
                        • borgil
                          820-00850 with shorted LDOs
                          by borgil
                          Hello all,
                          I am trying to repair one of my relative's dead 2018 MacBook Pro A1989. It stopped charging all of a sudden but was still working on battery until it was depleted.
                          It shows the following symtoms:
                          • Power on 3 of the USB-C ports cycles from 5V 0.25 A to approx. 1A
                          • On the 4th USB-C power stays at 5V 0.25A but if I flip the USB-C power plug the meter does not light up
                          UB300 is the CD3215 associated with the 4th port. There is no visible damage around UB300 or the port itself.
                          I checked PP20V_USBC_TA_VBUS and it is stable at 5V.
                          12-01-2022, 03:20 AM
                        • mkdj
                          MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                          by mkdj
                          About me, my goal and the equipment I (don't) have:
                          I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                          About my issue and my goal:
                          A friend of mine has a MacBook Air M1 A2337 that does not...
                          04-03-2025, 08:28 AM
                        • iMuhtaseb
                          A1706 - 5v due short 3.3v LDO
                          by iMuhtaseb
                          Board was OK but after keyboard replacement; we found short on 3.3 LDO on UB300 (CD3215).. I removed it and of course I tore off some pads because its undefiled.. pads are repaired successfully.. diode and continuity tests done Pads were USB_UPC_TA_F_P and TP_UPC_TA_SWD_DATA and UPC_TA_SPI_MISO..
                          After replacing UB300 the watts consumption lowered since short is gone but still is stuck @ 5v (0.06amps)
                          I noticed few balls around UB400 so I assumed it needed reball; reballed and replaced it; still 5v.. on both sides
                          While on the other wing U3200 and U3100...
                          11-18-2024, 07:01 AM
                        • flusher
                          A2485 MBP16 M1 820-02100 not charging
                          by flusher
                          Bought myself a project. Waterdamage to the left wing. Front side got damage on top up to SSD area. Back - near CD3218 both CD3217. Had to replace a lot of caps and resistors to make it perfect. No shorts. Didnt lift any chips yet but microscope shows good balls from sides. Anyway. It powers up and boots fine.
                          Right single usbc shows 20v on meter 0 amp
                          Left upper usbc shows 5v 0 amp
                          Left bottom usbc shows 20v 0 amp
                          magsafe shows orange but also does not charge
                          nothing produces beep from mac when on
                          when off - single usbc and magsafe produce beep but no beep...
                          08-27-2025, 08:25 PM
                        • Gueric
                          A2338 820-02020 5v 0.04A PP3V8_AON low
                          by Gueric
                          Hey mon, its me again (sorry) so after fixing my own Mac I’m back to try and fix another one.
                          I changed a CD3217 on this one. And it started bootlooping a few hours after the fix.
                          5v, 0.20-0.30A for the first few seconds then drops to 0.00-0.05A.
                          PPBUS_AON is 12v.
                          PP5V_S2 is present.
                          PP1V25_S2 is present.
                          PP3V3_S2 is present.
                          PP3V8_AON is 3.8v, but its diode mode was abnormally low (.150v instead .350v)
                          And to make it even worse I accidentally touched PPBUS and 3V8 with my meter and the resistance is now 100 ohms (don’t...
                          07-25-2025, 11:57 AM
