Panasonic Plasma TH-50PZ800U power supply light 2 blinks
    Re: Panasonic Plasma TH-50PZ800U power supply light 2 blinks
    MC201 causes 2 blinks
    MC301 causes 10 blinks
    However, it is a good idea to repair both - if one has failed it's probably only a matter of time till the other goes.
    • AWTVs
      • Jun 2014
      • 27
      • US
      #42
      Ok thank you all for your responses. Your knowledge and willingness to help others is awesome. I'll attempt this repair tonight. Can't wait!
      • AWTVs
        • Jun 2014
        • 27
        • US
        #43
        Well I tried... unsuccessfully. I decided the skill needed doesn't reside in me at the moment. However, the information and directions in this thread was spot on. I found a guy on eBay that repairs MC201 and MC301's. I felt his service was fairly priced and it was a very quick turnaround. Received these back, put them in and all is well again in the world... until my next tv is opened that is. Thanks to all that responded, your guidance will be sought again.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          #44
          May I ask what he charged you? Did he replace only the caps or also the IC's.
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • AWTVs
            • Jun 2014
            • 27
            • US
            #45
            It was $30. I believe he replaced both but am not positive. oleg_yj was the seller.
            • arobin
              • Sep 2014
              I am new to the forum so I apologize if I should be starting a new thread instead of posting a reply- couldnt figure that out.
              I have a TH-50PZ800 purchased back in 2008 that was originally from the east coast where it was working perfectly. We moved it to hawaii in a container and shortly after moving it, a single pixel vertical black line appeared on the left side (when viewing the screen). This went away about 6 months later (about a year ago). About 1 month ago we had 3 episodes where the left half (exactly half) of the screen went black and the right half of the image had a fair amount of static/interference. Turning the TV off and waiting a bit seemed to do the trick. NOW, we have the 2 red lights flashing BUT this only happens if you turn the tv off after watching and then go and try to turn it back on. It will generally turn on in the morning and when it does, its a perfect image.
              My question is this- do you think the three issues are related? Were the first two problems loose wire type problems? Does it seem likely that I am now dealing with a MC201 issue? I know this is an old thread but I hope someone sees this and shares their thoughts. Thanks!
                MC201 would cause 2 blinks.
                Your other fault is very common, it is due to a loose LVDS cable. I had a 46" with the same issue.
                https://www.youtube.com/watch?v=4gL_8VeS5-c
                • dog
                  • Nov 2014
                  • 14
                  • cheshire
                  #48
                  Thanks tw2005, the tv is a panasonic th-50pz800u 10 blinks pb. Etx2mm704mg -h - npx7o4mg-1 i bought the tv craig list, the guy tryied the mc201/301 the kit from ebay 2 ic 2 transistor ,i reinstalled it all mc201/301 new 2 1uf 50v 105 eletrolytic still ng .my prodlem is i cant get the service manual or schematic . To get the ac&dc volts ps i have 2 pb thanks again john
                  • dog
                    • Nov 2014
                    • 14
                    • cheshire
                    #49
                    • tw2005
                      • Oct 2011
                      • 6458
                      . Not sure if this one has a thermal fuse hidden in a transformer that goes can cause 10 blink
                      you can get 2 downloads a day here
                        Maybe worth trying the "white screen" test by unplugging appropriate connectors?
                        (All cables from A->P, and A->D board)
                        • dog
                          • Nov 2014
                          • 14
                          • cheshire
                          #52
                          thanks tw2005 ,i do have a themal fues ,i de soiler the the piNs IT checks ok .thank again tw 2005 ,
                          • dog
                            • Nov 2014
                            • 14
                            • cheshire
                            #53
                            THANKS TOM66 THAT WAS 1 THING I DID NG PB NO POWER ON CLICKS !!!!!!!!!! THANK TOM66 DOG.
                            • dog
                              • Nov 2014
                              • 14
                              • cheshire
                              #54
                              MY NEXTTHING IS TO DO IS , GET THAT ZENER DIODE FROM AC PB I WAS GETTING 7VAC NOW I GET 1.85 VAC ,AFTER LIFTING 1 LEG TO TEST IT YES I MESS UP . PB# D504 ,IT IS MARKED T3D81 . SCHEMATIC VXT3T3D82BL3 NO CROSS R. AND I HAVE I BIG CAP NO THE DC PB LIITLE BULGE 200V 900UF - I GET A TESTER FROM CHINA 12864 LCD Transistor Tester Diode Triode Capacitance ESR resistance Meter MOS PNP NPNROM CHINA $22.00 .DONT LAUGH YOUTUBE GOOD REVIEWS. I WELL LET YOU GUYS KNOW HOW IT WORKS, IN ABOUT 10 DAYS .WILL MY WIFE IS TAKEN MY WORK BENCH -.THANKSGIVING -THANKS DOG
                              • tw2005
                                • Oct 2011
                                • 6458
                                From memory in cct that diode will show short, out it will show open. ST03D82 I feel will be the correct part as part of that number is contained in what you listed
                                • dog
                                  • Nov 2014
                                  • 14
                                  • cheshire
                                  #56
                                  thanks tw2005 and have a good THANKGIVING TO ALL DOG !
                                  • dog
                                    • Nov 2014
                                    • 14
                                    • cheshire
                                    #57
                                    MY WORK BENCH IS BACK ,I GOT THE MEATER NOT BAD ,LOOK,FISH8840 Component Tester: Ham Nation 174, NOW I WILL CHECK THE CAPS ,THANKS DOG.
                                    • dog
                                      • Nov 2014
                                      • 14
                                      • cheshire
                                      #58
                                      or http://twit.tv/show/ham-nation/174 thanks
                                      • pswanson@pacbell.net
                                        • May 2015
                                        I want to thank all on this forum for saving me lots of money and perhaps my marriage. My Panasonic TH50PZ80U was showing the dreaded two blinks, at first intermittently and finally all the time. I looked at MC 201 and MC 301 in the power supply as suggested. By cooling the tiny capacitor on MC 201 the set would turn on normally for a few minutes before the cap warmed up. This was very consistent. For about $10 I bought two 1 mfd, 50V capacitors from Frys along with a new, very small, soldering tip. With a strong magnifier and various jigs and tweezers I was able to replace the capacitor with the power supply on the bench but with the circuit board MC201still in place. Thank you all again.
                                        Paul
                                        • Terryfictv
                                          • Mar 2011
                                          • 124
                                          As an option, I have simply removed the defective capacitor(s)
                                          from MC201 and MC301. I did not install new caps and I have had no recalls on
                                          any of the half dozen I fixed.I was able to remove the capacitor with the power supply on the bench but with the circuit board MC201 and MC301 still in place. KISS
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                            03-31-2024, 02:12 PM
