Panasonic Plasma TH-50PZ800U power supply light 2 blinks
  • kilo6490
    • Sep 2013
    Re: Panasonic Plasma TH-50PZ800U power supply light 2 blinks
    also, i just checked the cap on 301 and on avg im getting 100ohm through it then my meter goes to 1.
    • stahlgrau
      • Jun 2013
      I have a TH-50PZ85U that had the two-blink problem and thanks to everyone on this thread my plasma is now fixed!!! I took the PS board off, took off the surface mount cap, used two wires to my 50V 1uf cap as suggested, and everything powers up like normal. It took me 2-3 hours because my soldering skills suck and I had never taken off a surface mount component before. If novice solderers are going to try this here are some tips -- take the PS board off the TV and be careful with the screws (there's still one sitting somewhere in the bottom of my tv...), get a very small tip for your soldering iron (mine was medium sized and much too large), get non-flux core solder (mine was flux core and too fat). Thanks again to the folks on this board and the excellent pictures they posted! I couldn't have done this without them!
      • Ph03nix
        • Oct 2013
        Hi, new here, thank goodness I found you... I've purchased the electrolytic caps but haven't been able to find which way round to connect them. I'd be very grateful if someone could tell me which pad to connect the positive leg to and which the negative one.
        Thanks in advance..
        Jim G.
          Norcal715's video shows which way
          http://www.youtube.com/watch?v=LjpGKaBt8hg
          Both modules are the same.
          • Ph03nix
            • Oct 2013
            Brilliant. Thanks so much...
            I'm going in.... ;o)
            Jim G.
            • Ph03nix
              • Oct 2013
              #26
              Oh well it was worth a try. I successfully changed the caps but still have the dreaded 10 blink sequence. Off to the shops tomorrow for a new tv (not a Panasonic!).
              Thanks for the help.
              Jim G.
              • Bafury
                • Jul 2012
                • 55
                I have a repair kit on Ebay that fixes this issue.. Check it out
                http://www.ebay.com/itm/190964930298...84.m1558.l2649
                • RodentNoir
                  • Jan 2014
                  With what I've read here on badcaps, and with the help of norcal715's video (http://youtu.be/LjpGKaBt8hg) I've successfully fixed my TH-50PZ80B. If it's of any use to anyone, I was getting 2 blinks (not the common 10 blinks that go with it). I selectively froze the MC201 and MC301 boards to identify which one was the problem. Then replaced only the bad cap on that one board. I didnlt change the IC. I was able to do it in situ, but it was awkward! Thanks to everyone for the info in this thread.
                  • chanpo
                    • Feb 2014
                    Originally posted by Sevenqi
                    Finally I fixed it.
                    I only cool the ceramic capacitor on the power supply boards MC201, it could power up, so that cap is bad cap.
                    I bought 10 common 1uf 50v capacitors for 1 dollar, and use 1 to replace the bad cap. It's hard to sold because it's too small, I almost damaged the curcuit, so I use two soft / small wires to link to the new cap as show in the photo, and it works fine !
                    Can you please tell me what caps I need to buy and where I can buy to fix this issue? I have the TC-50PZ800U plasma, and my problem sounds identical to Sevenqi, the original poster of this thread. Thanks!
                    • hornhill
                      • Apr 2014
                      • au
                      #30
                      thankyou so much! I fixed my tv.
                      th-50pz800a melbourne
                      2-blink
                      Cool the ceramic capacitor on the power supply boards MC201, it power up
                      Solder a 1uf 50v BIpolar capacitor to replace the bad cap. very hard
                      I did it. thanks again.
                      • satinser
                        • Oct 2012
                        • 214
                        • uk
                        #31
                        I too am getting the 2 blink code only without the 10 blinks. I have tried freeze spraying both sub boards but still tv will not start. Is this still likely to be down to a faulty smd capacitor on one of the sub boards? Or does the the lack of effect of freeze spray point to a fault on D board?
                        The training manual states to check for short circuit on pin1 of P7 to ground. Which in this particular case there isnt. It then states that if 15v is not present on pin1 of P7 on start up to replace p board if it is present to replace the D board. In this particular case 15v is present briefly before shutting down with 2 blink code. Is this still likely to be down to a faulty sub board cap even with lack of effect of freeze spray?
                        All comments appreciated.
                        • satinser
                          • Oct 2012
                          • 214
                          • uk
                          #32
                          To those that may be interested found out from further tests that on this occasion the 2 blink code was caused by a short on the SC board.
                            That's only the second bad SC board I've ever heard of on a PZ80 out of hundreds. They are pretty reliable. Glad to hear it's fixed thanks for the update.
                            • AWTVs
                              • Jun 2014
                              • 27
                              • US
                              #34
                              I have the Panasonic TH-50PZ80U with the 2 blink error. I believe the repair is likely the same as listed here. I have attempted to replace the capacitor on the MC 201 but as my soldering skills are somewhat newly obtained I believe I may have ruined the board. It resembles a charred mess as I can't see both posts any longer. I will post a picture of the board and hopefully someone can advise next steps. If its done-for, please advise how to find a replacement MC 201 as I can't seem to find one or am looking by the wrong numbers. I am able to reseat the P25 connector (prior to my seelf made issue) and the tv would power on and work fine until I power cycled it again.
                              • Sevenqi
                                • Jul 2011
                                • 292
                                #35
                                Search ebay, there are some repair service for MC201. If you didn't ruin the PCB, try the board MC201 without that bad cap to see if this works.
                                If the PCB was ruined, then try to download the datasheet TEA1611T and fix it or go for reapir service.
                                  You have caused some damage to the board, but it is repairable. I know this because I did the same on my first repair (on one pad.)
                                  You just need to put the capacitor across the pins 11 and 13 of the TEA1611T chip. This is easier if you glue the capacitor to the top of the chip first. The negative side of the capacitor goes to pin 11.
                                  I do recommend you have a professional try it though unless you feel confident.
                                  • AWTVs
                                    • Jun 2014
                                    • 27
                                    • US
                                    #37
                                    Thanks guys for your knowledgeable input.
                                    I want to verify your direction prior to trying this. Attached is a diagram of what I believe you are suggesting I do to remedy this problem I created. If I understand correctly, I should solder my cap onto the top of pins 11 & 13 which are already soldered in and that will circumvent the cap and connections I damaged? I drew on the diagram attached what I believe this will look like. (please no comments on the poor artistry) HAHA
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      #38
                                      That is correct......negative lead from cap goes to pin 11....
                                      As Tom66 suggested,glue cap on top of IC first,then you can easily bend the legs to pin 11&13 and solder them on,double check that you don't have a solder bridge between any of the IC legs...
                                      Proud owner of dozens of broken TV's and many,many,many boards.
                                      Our website and passion:http://hollenhundshepherds.com/
                                      • AWTVs
                                        • Jun 2014
                                        • 27
                                        • US
                                        #39
                                        Ok thanks! I will verify but I did not replace the ic so hopefully they were good from the factory. I assume it is okay to do this same capacitor replacement method on the MC301 while I have the pcb removed? In the event that MC301 is the culprit for my issues.
                                        • martino
                                          Not so "senior"
                                          • Aug 2013
                                          • 997
                                          • canada
                                          #40
                                          Yes,I would do both......
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                            03-31-2024, 02:12 PM
