HP PL5060N Plasma cycling inputs randomly
  • angrydingo
    • Mar 2012
    • 18
    Hello all,
    I have an HP PL5060N 50 inch plasma TV that seems to cycle through it's inputs at random times, always after running for an amount of time. I've read that this could be due to the main board heating up, but there doesn't seem to be a clear cut "solution"
    Just wanted to see if I could get any opinions from any of the guys on this forum who have a lot of experience in fixing sets.
    Is there a "fix" for this or is it just best to go ahead and replace the board?
    Thanks all!
    Re: HP PL5060N Plasma cycling inputs randomly
    It might be the button board - the board which has the volume/input/power etc. buttons on it.
    You will need to disassemble the TV and unplug the button board. If that fixes it, try using some contact cleaner on the buttons...
    • angrydingo
      • Mar 2012
      • 18
      thanks a lot for the tip tom. i'll be sure to try this when I get the TV opened up. everything should function save the buttons if I remove this board correct? I have a remote to control the TV with.
        In most cases. Some* manufacturers put the IR receiver on the button board, so you wouldn't be able to just unplug it if you want to control the TV with just the remote. The contact cleaner worked a treat for my LCD TV though.
        *Samsung and LG do on some of their TVs.
        • high-tech
          Samsung UN55F7050AFXZA ver. TD01 power cycling
          by high-tech
          Hello everybody, I could use some help on this one... It's got me guessing...
          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
          9. ground (PWM2) 10. 0.9 volts cycling...
          09-15-2020, 03:39 PM
        • bcstedt
          Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
          by bcstedt
          Just starting to crack into this one and wanted to get the ball rolling.
          At power on (plug in), power light on, relays click, repeat (sometimes)
          After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
          Removed Y-Main for inspection and testing
          This pic from:
          PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
          12-15-2023, 10:30 AM
        • usbdevice
          Acer X223HQ (Version Bbd) on/off-power-cycling
          by usbdevice
          Hi all
          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
          https://www.badcaps.net/forum/showthread.php?t=50657
          https://www.badcaps.net/forum/showthread.php?t=40512
          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
          It's my dad's old monitor. He...
          08-05-2022, 02:21 AM
        • pcwhiz24
          Lenovo IdeaPad 3 14ADA05 NVME keeps randomly disconnecting
          by pcwhiz24
          This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
          Things I tried so far:
          - Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
          - BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
          - Tried multiple working NVME drives...
          04-08-2025, 06:59 PM
        • chopduel
          Bad mains power causing TV malfunctions?
          by chopduel
          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
          • TV would randomly turn off then back on.
          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
          12-29-2024, 03:20 AM
