Viewsonic vp2013b flickering screen
  • belippy
    • Apr 2012
    • 50
    • canada
    I have already tried to change a few caps on the main board, but the problem is still there.
    Will the problem be the main board or the power board?
    Is there a way to find out this kind of problem?
    Re: Viewsonic vp2013b flickering screen
    It looks more like a T-con board problem. On smaller LCDs this is not replacable, yours might be an exception. The T-con is attached directly to the LCD panel and is usually at the top of the display.
    • belippy
      • Apr 2012
      • 50
      • canada
      Can a t-con board be replaced?
        Just to be sure, check the voltages on the 3-pin regulator IC's (I see 3 on the board) on the signal processing board (the board where you plug in the VGA cable) also. Also try heating up the T-CON board and the signal baord with hair dryer to see if the symptom changed.
        • belippy
          • Apr 2012
          • 50
          • canada
          I have tried to heat up the both board with a hair dryer and result stayed the same.
          Checked the 3 regulators with following result:
          Part number 1084-0544AL (located at u20 on the signal board)
          pin 3 = 4.92
          pin 2 = 1.81
          pin 1 = 0.56
          Part number 1084-0544AL (located at u16 on the signal board)
          Pin 3 = 4.92
          pin 2 = 3.33
          pin 1 = 2.07
          Part number LD1117-c550 (Located top center on signal board)
          Pin 3 = 4.94
          Pin 2 = 2.51
          Pin 1 = 1.26
          power was on when I test them.
            OK, the regulators outputs are good.
            • belippy
              • Apr 2012
              • 50
              • canada
              Last thing will be the T-con board.
              • belippy
                • Apr 2012
                • 50
                • canada
                One thing i'm confused. The two regulators (u16 & u20) have the same model.
                But their output are so different!
                  They may be adjustable regulators, the output voltage is set by the resistor network on one of the pin.
                  • t.j.
                    • Apr 2010
                    • 383
                    • canada
                    have you tries a differ monitor on comp to make sure it not vid card?
                    • belippy
                      • Apr 2012
                      • 50
                      • canada
                      I have 3 of the same monitor, only this one acting like this!
                      • belippy
                        • Apr 2012
                        • 50
                        • canada
                        Thanks, budm.
                        Are there anything I should check before I buy a new T-con board?
                        • t.j.
                          • Apr 2010
                          • 383
                          • canada
                          had to ask!
                          peace
                          • belippy
                            • Apr 2012
                            • 50
                            • canada
                            had to ask!
                            peace
                            sorry t.j.
                            not meant to make you mad
                            problem with my english and my communication's skill....
                            I should have said it in a better manner, I will pay more attention in the future. sorry again!
                            • t.j.
                              • Apr 2010
                              • 383
                              • canada
                              not mad! all good! have to check everything! good luck!
                              peace
                              • belippy
                                • Apr 2012
                                • 50
                                • canada
                                I tried to reflow the chip on the T-con, but the screen has same distorted graphic.
                                sorry about the quality of an iphone!
                                • belippy
                                  • Apr 2012
                                  • 50
                                  • canada
                                  ok, I already bought 2 new T-con boards. Nothing has improved.
                                  After I install the first T-con, it's even worst.
                                  And recently I've order a new one from some where else. Not much of a difference.
                                  What else could it be?
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • ygorsan
                                    by ygorsan
                                    🧩 Problem Summary:
                                    • I
                                    Yesterday, 08:34 AM
                                  • jb_Bak
                                    by jb_Bak
                                    CN6401
                                    Pin 01 NC
                                    Pin 02 NC
                                    Pin 03 "BL_ON": 0V
                                    Pin 04 "N/C"
                                    Pin 05 "STBY 3.3V": 3.5V
                                    Pin 06 "GND": N/C
                                    Pin 07 "AC_OFF"...
                                    09-27-2021, 04:52 PM
                                  • JDC
                                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                    by JDC
                                    ONN 100012588
                                    Issue: No Power, Then Rebooting After Main Board Change
                                    Short answer: replace main board and power board
                                    Technical answer: replace main board and Q306 & Q307 on power board.
                                    Long answer:
                                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                    07-15-2022, 07:39 AM
                                  • advant
                                    by advant
                                    02-03-2020, 12:25 AM
