hitachi CMP4202E
  • simplytrini
    • Jul 2011
    • 73
    hitachi CMP4202E
    can anyone help? I an trying to get the part number for two diodes in this model hitachi. I need p/n for d110 and d156 or replacement p/n's. Thanks in advance.
  • selldoor
    Slow Learner
    • 7870
    Re: hitachi CMP4202E
    Post a good clear picture of the board they are on and a close up of the area
    where they are and a close up of the two items
    • S2udio
      • Feb 2012
      • 16
      service manual here with psu schemo
      http://www.eserviceinfo.com/download..._CMP4202E.html
      Most of the time things ain't what they seem to be
      • simplytrini
        • Jul 2011
        • 73
        Finally got this set to work. After many hours of troubleshooting, it turned out to be bad caps everwhere! Y sustain, Z sustain, powersupply and Logic boards. Installed some good caps and this tv is now working really well. Thanks again for all the great help!!!
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Fontana
          BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
          by Fontana
          1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
          2. if
          12-18-2023, 05:45 AM
        • Nikolai Danylchyk
          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
          by Nikolai Danylchyk
          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
          Thanks in advance!...
          05-08-2025, 06:18 AM
        • massimomax
          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
          by massimomax
          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
          spero che qualcuno può averlo per riprogrammare eprom. grazie
          Post in English !!!
          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
          02-28-2025, 07:27 AM
        • DjKrish
          Zener diodes component equivalents
          by DjKrish
          Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
          1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
          2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
          3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
          These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
          08-15-2021, 11:06 PM
