Sharp Aquos LC-46D64U stand by with new boards!
  • miketamm
    • Mar 2018
    • canada
    #121
    Re: Sharp Aquos LC-46D64U stand by with new boards!
    Hey Jdlowvoltage1 Im at the same point you are but havent jumpered the 3v yet. So what pins exactly did you jumper? Maybe you can take a photo?
    Im guessing mine maybe be one of the lamps.
    Did you jumper Von and Err? pins 1 and 3?
    • bbgun123
      • Mar 2018
      Originally posted by tristan7zavier
      Hi everyone I think i can shed some light on this issue. I was having the same problem with this tv as the op, I changed the powersupply tried all the resets yada yada. I noticed that i was not getting any voltage readings from the pin marked as panel power, from neither powersupply or signal board. I run a small shop that does bga rework for laptops game consoles ect ect.. As a last ditch effort I decided to reflow a chip on the signal board the one under the big heat sink marked broadcom so i put it on the achi ir pro ran my laptop lead free profile. After it cooled I re installed it an plugged it in i heard a relay click once i hit the power button an the set came to life! This is the 2nd sharp aquos tv I have had to reflow. It seems like this is becoming a more common issue with the changing technology.
      This solution work!
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • jonah1024
        Sharp Aquos LC-40UG7252E LCD TV burn in?
        by jonah1024
        Hello!
        I'm a few days old into this TV screens repair universe so please bear with me.
        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
        - I did a factory reset as well...
        07-16-2024, 04:23 AM
      • klassic
        Sharp Aquos LC-60LE635E three blinks
        by klassic
        Hi community,
        I will describe my problem with a TV in those short following terms to be the most precise :
        What i have :
        power board DPS-162KP-1
        main logic board QPWBXF733WJN2
        symptoms :
        white led light logo at startup,
        after 2 minutes, blinking 3 times a row, repeating
        no backlight (and apparently no picture, checked panel with flashlight)
        no startup sound
        powerboard investigations :
        1-2 PNL : 0v
        3-4 GND
        5-6-7-8 UR : 13.15v
        9-10-11-12...
        10-24-2023, 01:39 PM
      • foxyUK
        Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
        by foxyUK
        Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
        The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
        There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
        10-22-2024, 10:27 AM
