Sharp Aquos LC-46D64U stand by with new boards!
  • cashkennedy
    • Aug 2011
    • 668
    Re: Sharp Aquos LC-46D64U stand by with new boards!
    Haha i really doubt he knew to set the model id plug. I mean id never have ever guessed they would have such a crazy system. Its not even jumpers like anyone sane would use ... why is it some bizzare plug system that requires 9 x 2 positions ????
    Also when you replaced the heatsink on the new main board after it came in, did you use the existing goop / heat pad / thermal interface material? Did you clean it off?
    (im talking about the white or pink paste that is between the heatsink and main board.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      I Know! it looks like they spend more money on the jumpers and plugs than spending money to make the set more reliable.
        @cashkennedy, at post 46, what do you use to convert the PDF page into JPG format? Thanks.
        • Jasgriff
          • Feb 2012
          • 578
          Bud do you have windows 7?
          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
          How to resize your pictures guide click HERE
          Retiredcaps Ideal post example click HERE
            I still use XP PRO.
            I was doing by using ACROBAT "camera" function then paste it into Paint, then save it as JPG format, but it does not come out very clean.
            • cashkennedy
              • Aug 2011
              • 668
              I zoomed in then used print screen , copied it into mspaint, moved the pdf then print screen again and peiced the 2 together in mspaint.
              So not exactly the easiest process. You might try print to pdf if you have acrobat or nitro pdf (thats what i originally meant to use, but my pdf reader crashed for some reason when i tried it)
              • Jasgriff
                • Feb 2012
                • 578
                OK.
                U can print screen then load paint and paste it into paint. Cut out the part of the image that you want select new and then paste again.
                • Jasgriff
                  • Feb 2012
                  • 578
                  I was toooooooooooo late lol
                  Do you have windows 7kenny?
                    Thanks, Let me try that with the same page from the service manual to see if it comes out better.
                    • cashkennedy
                      • Aug 2011
                      • 668
                      I have windows 7 on my of my computers yeah. are you calling me 7kenny?
                      • eTanium
                        • Mar 2012
                        • 65
                        Originally posted by budm
                        Yes, it may have failed seftest.
                        By the way, when you got the new board, did you check to make sure the Model ID plug setting is correct per page 3-14?
                        Nope, I was not aware that the jumpers would come different based on version. I did need to change one of the jumpers, but it is still booting up with errors just as it has previously.
                        Is there some why that I need to clear any errors during the initial boot up after the install of a new main board?
                        I actually had some thermal paste prior to this TV issue, for when I build out computers (which is why I thought I could work on this TV with no problem, haha).
                        But, no I didn't replace it in this situation; there actually was a huge block of the stuff, more of a heat pad than anything. It was about a half inch think and is connected to the heatsink and makes contact with the processor. It didn't seem like it needed replacing, and if it did, I didn't have an extra about.
                        Also, again, I am a graphic designer/web programer by trade, and I have access to adobe photoshop. I can take care of pages of the service manual for us and turn them into .jpg's - just let me know the page.
                        • Jasgriff
                          • Feb 2012
                          • 578
                          I'm writing this on a stupid touch pad so it would let me wife cashkenny at first.
                          Windows 7 has the snipping tool. Its much easier tan using paint give that a try.
                          • eTanium
                            • Mar 2012
                            • 65
                            One possibility for why the error occurs when its is off is that possibly after a reboot it has to complete 1 full boot , and if it failed to finish the boot and is powered off then it triggers a failed boot error.
                            IDK what would be causing the boot to basically freeze in the middle (that appears to be the case, as normally if the boot was detecting an error it should start flashing the error lights), but it would probably be either a bad main board / mismatch with the tuner, or bad eeprom, or main board not getting proper power. From other sharps that have been worked on it seems that it wouldnt not be the inverter boards that would cause it to freeze in the boot because it completes the boot, then turns them on as well as the tcon at the same time and monitors for an error. And from my experience with most TV's they usually dont care if the tcon isnt connected.
                            Well, we know it's not the main board, because that's new, and has the correct jumper settings for the model in question. What would be the best way to test the tuner board and the eeprom (which is a new term for me - please clarify if you could)?
                            Thanks.
                            • cashkennedy
                              • Aug 2011
                              • 668
                              The eeprom is the flash memory that stores the settings / boot method for the TV. Computers and TV's have this (on computers its where the bios is stored).
                              In the old days and on some really oddly designed new tvs its a 12 or so pin chip that fits into a socket (so that if it goes bad it can be swapped out). Usually now its just a very small smd chip.
                              When you update the firmware it is saving to this chip, so if the firmware was damaged it wouldnt be able to boot, because of errors on that chip.
                              The eeprom on the block diagram says its marked on the main board as ic2004 and is a br24l08f chip. If you can get us a close up picture of that chip we might be able to tell you if its removable.
                              I cant remember, but when you replaced the power supply and used your old main board, did you get exactly the same problem? or was it a slightly different problem?
                              • eTanium
                                • Mar 2012
                                • 65
                                With a new power supply (which I have since returned), and a new main board, I got the exact same results, which leads me to believe that the eeprom isn't the issue. No? Unless the new chip was also effected by an error in the boot some place?
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  If you tested both mainboards with the same power supply and got the same result then your problem is probably not the eeprom, it could only be the mainboard if there was a very very common failure point for these tvs.
                                  Also this problem is the same problem as it had before you even took the tv appart to begin with?
                                  Are you able to disconect the tunner board (unscrew it / disconect the bridge), and then test the tv without the tuner board connected at all?
                                  • eTanium
                                    • Mar 2012
                                    • 65
                                    Yes, I can do that very easily. Do you think that the error code may change? If it doesn't change, do you propose that the Tuner board would then be proven as the issue?
                                    • cashkennedy
                                      • Aug 2011
                                      • 668
                                      if it works / gets closer to working with the tuner board removed then the tuner board is bad.
                                      If it doesnt work still then tuner may or may not be bad.
                                      I honestly dont know if it is able to boot with the tuner board missing, because the tunner board looks to have a media switch as well as the whole audio section of the tv. Both of which are fairly important for the tv to run.
                                      • eTanium
                                        • Mar 2012
                                        • 65
                                        Yep, same result (in both state A & B) with the tuner board removed (just unplugged).
                                        • roscoe13
                                          • Mar 2012
                                          I'm new to this forum and don't have a lot of experience but I'm working on the same model Sharp. I remember reading somewhere that if you replace the main board on this model that you have to flash the firmware with the Sharp firmware for your model or it will not work. Can't remember where I saw that to post a link or if it's true but just thought I'd put my 2 cents in if it helps in any way.
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • jonah1024
                                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                                            by jonah1024
                                            Hello!
                                            I'm a few days old into this TV screens repair universe so please bear with me.
                                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                            - I did a factory reset as well...
                                            07-16-2024, 04:23 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
