Samsung PS-42C455 no picture
  • PowerAmpFreak
    • 977
    • Sweden
    Got a 42" Samsung plasma model PS-42C455 manufactured in december 2010 which does not display a picture. The sound appears to be good though.
    (The start-up melody can be heard)
    Measured powersupply voltages OK. The set tries for about one second, during this time there are proper Y-sustain and X-main waveforms. The green led on the logic board flash slowly which should be an OK sign of getting proper LVDS.
    According to owner the set operated only for about 3 hours from new. He got the set from a shop going bankrupt so warranty is out.
    All "power parts" of the set "seems" to work properly. Any advice?
    EDIT: Has done the usual troubleshooting by disconnecting power boards, without any difference...
    Re: Samsung PS-42C455 no picture
    Is there an AC detect pin on the PSU?
    • PowerAmpFreak
      • 977
      • Sweden
      Let's see, if there is an AC detect pin on the powersupply?
      Could you specify what you mean?
      The powersupply fires up, PFC comes up, VA and VS on for a second, then shuts down, just like when overloaded and protection kicks in.
      But there seems to be no overload issue.
      The P/N of the psu is BN44-00329A.
        I had an LG plasma with the same problem. Fired up, Vs/Va came up, waveforms on both boards appeared, then "CLICK" (from relays) and it went off. Mine repeated the cycle every 5 seconds or so. I found the AC Detect line (which tells the main board the power is still plugged in and to continue operating the TV) was collapsing after a couple of seconds - never entirely figured out why - but I just bridged the optocouplers responsible for the signal and it fixed it.
        The pin may be marked "AC-DETECT", "ACD", "AC-ON", "LINE-DETECT", etc... It will go to the main board.
        • PowerAmpFreak
          • 977
          • Sweden
          Well, if this was the problem in my case I don't see why the audio still works...
          The service manual doesn't give any better advice then replacing complete boards.
            It depends, I've only serviced one Samsung plasma and that had a Z-sustain board problem.
            Just check the ACD voltage if there is one.
            • PowerAmpFreak
              • 977
              • Sweden
              There are no ACD or other kind of LINE DETECT signals going out from the powersupply. It doesn't matter if all powerboards are disconnected. The set behaves exactly the same.
              At power up - a signal called "PS ON" (powersupply on) goes high. Relay clicks, PFC comes up. Then a signal called "VS ON" goes high, starting up VS and VA converters. VA and VS reach correct levels. Output waveforms from driveboards comes on, a second later, signal "VS ON" goes low.
              Just like if a voltage level detector cannot confirm the VS has reach sufficent level.
              Signal "PS ON" is high after this and the set is on producing only audio.
                Try pulling VS ON high permanently with a 1k resistor. See if TV stays on. If so could be corrupted EEPROM or detecting a fault? Strange there is no AC detect as most Samsungs have it.
                • PowerAmpFreak
                  • 977
                  • Sweden
                  Thought about that, but it may result in more trouble if VS shuts down for a reason. I've checked the Y-SUS and Z-SUS very closely and there are no abnormal readings in the power sections of the boards. I like this set, because there are are no hybrid IPM. Everything's built discrete.
                  All labeled voltages I can find measure according to spec, so obviously it seems safe to pull VS high by external circuitry and see if the picture looks ok or not.
                  This could aswell be a way to reset the mainboard through service menu, as soon as I get a picture to look at. I thought about corrupted EEPROM aswell, but I don't know how to refresh the data. On other Samsung's I've been forced to replace the EEPROM, then a factory reset begins and store new data at first startup.
                    If you get the set to boot up and show a picture, turn it off, and while off press Info-Menu-Mute then Power to get to the service menu. Then locate the factory reset and activate that.
                    • PowerAmpFreak
                      • 977
                      • Sweden
                      Yes, that would be nice. I hope this set also has that famous remote sequence to get into the service menu.
                        Every Samsung from an CRT RPTV to 6 month old plasma I have seen has had that sequence to enter the service mode.
                        • selldoor
                          Slow Learner
                          • 7870
                          If I have the right schematic on page 4 1c0802 PIC16F882 has AC Detect on pin 21?
                          • PowerAmpFreak
                            • 977
                            • Sweden
                            Thanks a lot for the PSU schematics. I tried to find this, without any luck.
                            Now I can verify if there are any control signals that doesn't reach the PIC processor.
                            The VS and VA detect inputs at pins 3 & 4 is interesting. Perhaps one of those signals doesn't reach the PIC.
                            Again, THANKS!!
                              Nice - Proprietary schematics... where'd you get those?
                              • selldoor
                                Slow Learner
                                • 7870
                                One i drew earlier.......
                                Just searched through 4 pages of Yahoo on the ps board number and
                                the usual Electrotanya came up trumps. Unusual for a Samsung search.
                                Only wish i understood them
                                • PowerAmpFreak
                                  • 977
                                  • Sweden
                                  Grrrrrrrrreat!!
                                  • PowerAmpFreak
                                    • 977
                                    • Sweden
                                    I forced the VS ON signal constantly on while monitoring Y-SUS drive waveform. This makes then VA and VS up and running, unfortunately the drive pulses is shut down the same time as VS ON goes low, so I will get no picture.
                                    This sure looks like a corrupt mainboard. Wonder if it's possible to make a factory reset without looking at the screen. I remember on a Samsung LE40R86 I changed the EEPROM IC1803 to repair corrupt data, and during first start-up the EEPROM was filled with correct data.
                                    Wonder if it's possible to make the same procedure on this mainboard.
                                    The TV also features upgradeable firmware through USB. I downloaded the new firmware from Samsung's website, stored it on USB stick, and insert in the TV.
                                    The USB stick begin to flash as the mainboard is searching for media (probably), but it's probably necessary to go through a bunch of menu's to really get the TV to update firmware.
                                      It may be possible to short pins 5 + 6 of the EEPROM to reset it, like on some R and M- Samsung LCDs.
                                      • PowerAmpFreak
                                        • 977
                                        • Sweden
                                        I already tried this, but there are several EEPROM's on the mainboard, so don't know if I made at the correct one.
                                        It sure looks like there are some hokus pokus with the mainboard, in some cases when set is turned on, the standby led is on, and when in standby led is off. Should be other way around.
                                        I want this bastard to be reset now !!!
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
