Samsung PS-42C455 no picture
Re: Samsung PS-42C455 no picture
Ok, so that's not an indication of a corrupt mainboard? Oh well.
Pins 5 & 6 on the EEPROMS is the SDA and SCL lines, does the mainboard processor check if those are shorted during start-up and IF they are, the EEPROM contents is initialyzed?Comment
No, I believe doing so causes it to think the EEPROM is empty, so when it starts booting up it rewrites the memory.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I appreciate your ultrafast response Tom!
I'm the kind of guy who don't like to wait - so that suits me brill!Comment
Well, bad news, I don't succeed to write new eeprom data by shorting SDA and SCL during start-up, tried XX times with different timing.
There are 3 EEPROM's across the board, one is marked MAIN EE, SUB EE, and the third is close to the VGA and HDMI inputs. This one I didn't touch.
But I tried shorting SDA and SCL on both MAIN EE and SUB EE (not at the same time though) without any luck. The short was made with a switch so shorting is guaranteed.
Then I replaced the MAIN EE. First start-up the set behaved little different, it shut off by itself after ten seconds which I thought was a result of it's own powercycle and reset, but no.
Everything is the same... BAH!!Comment
I might be troubleshooting the wrong board. Most things indicates that main board actually is alright, but what the H**L could this be else.
Read through two different service manuals for this panel (Samsung F71A) without getting something useful.
The manual refer to a control led on the logic board. This led is blinking slowly, at a rate around 0,3Hz. The service manual doesn't tell if this is correct or not, it just tell that this led should be checked for normal operation.Comment
If there was a problem with the LVDS output from mainboard, would this perhaps automatically turn off VA and VS in order to protect the panel from possible burn-in problems?Comment
I now disconnect the LVDS cable going to logic board. The LED on the logic board blinks in exactly the same way as with the cable connected.
- Either there is no LVDS from mainboard
- Either the logic board is faulty
- Either the LED does not indicate LVDS statusComment
Maybe flashing LED indicates fault? Does it blink a number of times, then stop, then blink again...? The only way you could know if there is LVDS is check with a scope.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It's terrible how bad the service manuals are for those plasmas. They can't even tell what LED indicates
It's blinking continously at a rate about 0.3Hz
I will hook up the scope and check the LVDS.
There is a signal from mainboard to logic board which is called "PDP GO", which I would assume means that panel boards should be turned on.
This signal goes high when set is turned on, and is on until set is turned off by remote.
Then, from logic board to power supply there is a signal "VS ON" which actually turns on VA and VS supplies.
So in other words, it seems like when the logic board recieve "PDP ON" from mainboard it starts up VA and VS.Comment
If anyone of you out there has a Samsung plasma in the PS42C450 model range, could you perhaps see if it's possible to see the led on the logic board through a ventilation slot, if it's blinking, continously on or off during operation. This would be great help!Comment
I had a C450 a couple of months ago and I seem to remember the light didn't blink - but don't trust my memory!!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The service manual does only tell: Check if LED on logic board is normally operating. Something tells me that a normally operating led doesn't blink, right?
Here is where I fixed my TV.... maybe there is something useful here
https://www.badcaps.net/forum/showth...hlight=samsungPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Great, but this failure is not like mine in any way.Here is where I fixed my TV.... maybe there is something useful here
Since the VA and VS supplies is shutting down after one second I don't get even a faint picture (of course). Measured across both Y and Z without finding any abnormal readings in the power sections.Comment
Yeah, I know - but I've got a video up.
http://www.youtube.com/watch?v=Bmu12mCOKcU
The LED flashes on that one but it's quite fast. (Right near the beginning.)
If so maybe the 0.3 Hz flashing indicates a fault? My set was still "working" other than the picture was screwed due to Z-sus fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Aha! You're right. You're led is blinking much faster. Thanks!
The moment VA and VS supplies is turned off match the first time LED go off.Comment
That was with a faulty Z-sus but I don't think there was any feedback to the PDP control board. I can't remember if it behaved the same after being fixed, but I suspect it would.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by DodgethisHello all,
This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...5 Photos - Loading...
