Samsung LE40A656A1F - Possible T-con fault?
  • senndogg
    • Dec 2011
    • 383
    • Albania
    #41
    Re: Samsung LE40A656A1F - Possible T-con fault?
    its the second case in one month, that a Samsung panel suffers a bad ribbon/flex. the strange thing is that i played with the ribbons a lot before swapping the t-con. only after removing one ribbon it started working.
    anyway, this fix will somehow extend the life of this full HD panel. lets hope.
    • prols
      • Jul 2012
      Hi everyone. I'm new to this forum.
      I have a Samsung LE40A656A1F to fix with some weird clouding effect.
      Searching on the web led me to the following video:
      http://www.youtube.com/watch?v=rcGSStFgjeA
      Look at top left screen @ 1'25" to 1'35" and spot the time it takes for the white line to disappear, very slow reacting LCD screen.
      This suggest that the problem could be a common one.
      Caps on the PSU board are fine, so are the voltages and the ripples.
      T-Con pcb and ribbon cables seem ok.
      Does anyone have experience with this problem?
      • senndogg
        • Dec 2011
        • 383
        • Albania
        #43
        mine began "clouding" again. now i have an official faulty LCD panel. now it is similar to the one in the video.
        @prols: the slow refresh rate might be because a bad tab bond. if you can strip it you can try pressing them and see if there is any difference.
          Shame about the bad panel issue. Seems all too common with Samsung LCD panels.
          • senndogg
            • Dec 2011
            • 383
            • Albania
            #45
            the slow refresh rate in my case was in a Samsung but Chungwa panel. it was fixed, but the issue on this 40" Samsung seems permanent.
              I thought this TV used a Sammy panel?
              • senndogg
                • Dec 2011
                • 383
                • Albania
                #47
                sorry, i was not very clear. its in an another thread, a LE37S86BD i repaired 2 weeks ago, had a bad ribbon which caused a slow refresh rate, that was a Chungwa HD ready panel and had completely a different design.
                Yes, the LE40A656A1F uses a Samsung Full HD panel.
                  Crappy Chungwha panels... Hate 'em with a passion. Have one now with hideous mura...
                  • prols
                    • Jul 2012
                    Thanks senndogg.
                    Played with the T-Con board, seems fine to me.
                    I am trying to establish where the problem lies, inside the LCD panel or outside.
                    The fault affects the whole panel...?
                    Can LCD panel be opened and fixed?
                    • senndogg
                      • Dec 2011
                      • 383
                      • Albania
                      #50
                      your only contact with the LCD panel are tab bonds. you can press them and see if the picture gets better. to do that, you should take the display and the entire structure out of the front bezel. than put it in a huge table backside down. you have to do 10-15 screws to remove the thin metallic front structure which secures the lcd panel. now you have access to them.
                      in my case, i desperately stripped it again. nothing doubtful. searched for a failed cap, everything ok. now im thinking where to throw it.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        One retiredcaps bonus point for a picture of your multimeter.
                        I see the Uni-T UT61E is quite popular in outside North America.
                        --- begin sig file ---
                        --- end sig file ---
                        • senndogg
                          • Dec 2011
                          • 383
                          • Albania
                          #52
                          OFF topic: i watched many reviews on youtube but was still not convinced either for a second hand Fluke or for a new from any other (Amprobe, Vichy, Unitrend etc). since shipping was a bit costy from the US, i followed mariushm advice. he had written a detailed review of his UT61E. i had this in my hands for 60$.
                          as for the Sammy, the owner collected it from my store from second time. he is desperate as no other technician in the area has not gone so far in troubleshooting. he confessed me last time. if he ever decides to throw it, i will make him a small offer.
                          • im_at_a_loss
                            • Aug 2012
                            • England
                            #53
                            Hi Sorry to hijack your thread, new to the site and wasnt sure where to go. i Have the same problem with a friends samsung same model by the looks of it. I have changed the t-con board and the t-con cable which has resolved the issue it came to me with. My friends now tells me that the problem it now has ( Red vertical lines and some other colours now and then ) is the original problem until it stopped showing any picture at all other than the lines.
                            I was wondering if that the problem was originally with the main board and because he kept using it, he then has blown the t-con board and cable ( tested all and the original board and cable show no picture new board and cable show picture bit with lines ).
                            Just after your thoughts before i tell him we need a new main board.
                            Many thanks.
                              Sounds like a panel failure to me. Certain Samsung TVs of this generation are very prone to it. Do you have a picture of the fault?
                              • im_at_a_loss
                                • Aug 2012
                                • England
                                #55
                                Here are the pics, taken 2 in menu as it is a little more visible. these are with the new t-con board and cable. As i said the old board and cable will not show any picture at all.
                                Cheers
                                  Possibly bad T-con? I saw the same fault on an LE40A656 on eBay going for £86 (for parts.)
                                  • im_at_a_loss
                                    • Aug 2012
                                    • England
                                    #57
                                    these pics are using a new t-con board from a known ( so they say ) working screen, it had a cracked screen, bought from ebay.
                                    What Dd you think? this poss another faulty board?
                                      Yes, quite possibly - you could have seen same lines with cracked screen & think T-con is good.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #59
                                        Check that your cables are cleaned and well seated.
                                        • im_at_a_loss
                                          • Aug 2012
                                          • England
                                          #60
                                          @ tom66 - I only bought the board not the whole tv. i guess they could of bought it with a cracked screen and assumed the boards are good, seems a bit amature but you never know.
                                          Guess i could give the cables and connectors a clean. its worth a try.
                                          cheers
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
