LG 60PY3DF shuts off
    Re: LG 60PY3DF shuts off
    What I'm trying to see here is if the CPU gets a signal from the fan will it then behave and will the TV turn on and stay on? One issue is this does not fit with your friend's description of slowing getting worse, lasting less and less time. I would expect it to just fail one day. Unless it were a cold solder joint for one of those connectors on the fan or a loose fan connector.
    • brentkhack
      • Mar 2012
      • 57
      • US
      #102
      nevermind, I know what you mean now. Let me put it back together and find out.
      • brentkhack
        • Mar 2012
        • 57
        • US
        #103
        I bridged by using those resistor from earlier in this post and one fan worked. Would I need a regular piece of wire instead?
          Yeah, the resistor will not allow enough current. 100mA typical - voltage drop 22V... from a 12V supply, that's not going to work.
          • brentkhack
            • Mar 2012
            • 57
            • US
            #105
            Well i use 3 paperclips to connect the working connector from main board to both fans. After a few seconds both fans did spin but then the tv shut down like it always has.
            • Lonnie4242
              I have the same problem with my LG 60PY3DF.
              It's turns off after 3-5 seconds
              Was the problem fix?
              • brentkhack
                • Mar 2012
                • 57
                • US
                #107
                Putting the tv at the end of the street. I wasn't wasting anymore time or money on this.
                • Lonnie4242
                  I had the same problem with my LG LG 60PY3DF-UA turning itself off.
                  The problem was the 2 fans. One worked and the other did not. I replaced one $20.00 fan and the tv is fixed. It stays on.
                  • janmyung
                    • Oct 2012
                    • 3
                    Same tv, same problem. My friend gave the tv for me to work on. They use it with the back cover off. I can watch for hours but last few days just a few minutes then a few seconds. Both fans work. I tried most of the suggestions here that I can understand. There doesn't seem to be any caps bulging. There seems to be a buzzing sound which I am not sure is normal or not. Any other suggestions? There are too many boards to replace this tv.
                    • janmyung
                      • Oct 2012
                      • 3
                      Just an update. I wedged a resistor on the ac-on and and stby5v and seems to have done the trick. Will update if anything happens.
                      Can I get an explanation about the fix? Thanks
                      • janmyung
                        • Oct 2012
                        • 3
                        It died after an hour and when you turn it on, shuts after 5-7 secs.
                        • huzo
                          HP Omen shuts down when loading OS
                          by huzo
                          The model is 15ec-1061nm
                          Board number is DAG3EDMB8D0​
                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                          10-29-2024, 12:05 AM
                        • brav1ez
                          ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                          by brav1ez
                          I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                          I’ve tried:
                          - CMOS reset
                          - Removing the SSD/HDD
                          - Reseating RAM (removing each stick individually stops boot completely)
                          - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                          With...
                          09-07-2025, 10:47 AM
                        • chaos-theory
                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                          by chaos-theory
                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                          03-14-2025, 05:37 PM
                        • baglaivlad
                          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                          by baglaivlad
                          Hello everybody!
                          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                          11-20-2024, 08:14 AM
                        • samuelphirik
                          Dell inspiron 15 7567 sudden shuts down
                          by samuelphirik
                          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                          Now I've noticed that laptop...
                          07-02-2023, 05:45 AM
