Vizio VW42LHDTV10A horizontal lines on the left side
+ More Options
Posts
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio VW42LHDTV10A horizontal lines on the left side
    Could you please point me to that resistor solution?
    I have seen something like this on Youtube, but if I remember well it was for a Sony.
    It would be nice to have a resistor fix, then using some rubber in there.
    • cadiman
      • Mar 2010
      • 397
      You have a bad panel and the foam tape will work sometimes but It won`t last.
      I have had a few of these and they worked with the foam pending temp, humidity, and every other Thursday.
      Suddenly older plasma tvs look good again and still my favorite for picture quality and depth.
        I sure like to know about the 10Watts resistor trick since the T-CON board itself uses less than 10 watts of power, where would that 10 Watts be coming from. Something does not sound right.
        • cashkennedy
          • Aug 2011
          • 666
          I dont endorse or know this method works.
          On the thread where tibi was considering buying a 40 inch sony i showed him a video of what a bad panel ghosting would look like, then i also said
          "This video shows a fix for 32" models that i though was fake when i was looking at the videos 6 months ago, but now theres like 10 videos showing the same fix, and giving all the info (the original video wanted you to pay 5 dollars for the secret info...)
          http://www.youtube.com/watch?v=9UrTV...eature=related "
          Basically there was a youtube video that showed a soldered wire running from the top lcd panel strip / board to 1 of the tabs on the side, and in the comments in really bad english it asked for you to pay 5 dollars for this secret trick to fix it. So I figured this was bullshit.
          6 months later from when i saw the original video there are now like 10 videos on youtube with people showing exactly what to do for free, and saying it fixed their tv.
          Im at work so i cant watch the video here, but maybe its a 10 ohm resistor and not a 10 watt resistor (i probably just misspoke). But it seems reasonable that while traveling through the panel 10 ohms of resistance might be created. And it also seems reasonable that whatever connection comes loose with these tab bonding issues, it is probably something like a power source for clearing the pixels that is common to everywhere on the screen, but since the ghosting seems to fade from 1 side to the other, this voltage is fed to the screen in multiple places but decreases across the screen from the resistance that prevents it from traveling to the other side. perhaps the panel has connections for this voltage source in multiple places. So finding the closest place to the disconnected area that you can easily solder a wire to feed this voltage to the screen seems like it might possibly work to fix the problem.
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          • tibimakai
            • Jan 2012
            • 3680
            http://www.youtube.com/watch?feature...&v=9UrTVEC5LkA
            who will try this?
            • cashkennedy
              • Aug 2011
              • 666
              Yeah thats the one i meant to link, but aparently i screwed up the link. The music is obnoxious lol.
              http://www.youtube.com/watch?feature...cQ2PQpyKQ&NR=1 is another one about the same fix
              http://www.youtube.com/watch?v=rVsv3...eature=related i think this is the original video i saw months ago where someone was selling the instructions
              • cashkennedy
                • Aug 2011
                • 666
                EUREKA IT WORKED! I CANT BELIEVE IT IT WORKED!
                BUT BUT BUT, this is insanely hard to do, and im not sure ill be able to solder any of it well enough to last ...
                http://youtu.be/JGM3jJQ6J-Q is a link to a unlisted video i made on youtube that shows what testing of the fix i could do. I dont have time tonight to try to actually finish soldering it.
                But i believe you have 2 attempts to solder vON, (1 on each side), (i destroyed the first trace while attempting to solder a too large wire). And you have 8 tabs on the sides, and im pretty sure they all have the proper place to try to solder / peirce the tab .(I destroyed 1 tab slightly by making the peirced hole to big...)
                I honestly have no clue how so many people were successful with the 32" models, as this is extremely hard soldering ...
                BTW bellow is a picture of my testing area, to prove i really took that video, i have no reason to lie to yall. Its also more to make tibi jealous of the amount of space i have to lay out tv's.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Cool. I will do it too, I don't have a choice. This way it's possible to sell the TV right?
                  This fix is the same for every TV?
                  You really have space there and you have only that many TVs
                  I have six TVs in my garage(2x 46", 1x42", 2x37", 1x40") and I had to let go to another one today because I don't have room. It was a 40" Sam sung plasma which popped and lost the video, for $50. Actually yesterday I hd seven TVs, I sold a 40" Sony smart TV for $450(yes!!).
                  After this I will have to take apart that 40" Sony's panel and check for bad ccfl tube.
                  • cashkennedy
                    • Aug 2011
                    • 666
                    The 46 and 52" ones that have tab bonding issues are made by samsung's panel factory. They usually only have ghosting towards 1 side.
                    The 32" that this repair was originally show for and my 40" have this slightly different issue where the whole screen ghosts and so might be made by a different manufacturer.
                    http://www.ebay.com/itm/SONY-KDL-40S...item256e429342 is the tcon for my model, i think only 1 brand uses etron tech and view-wise cpu's ... Im not sure who makes this panel, but i have a feeling it might not be the samsung factory, but something cheaper.
                    Yours since it responds to flex might be more related to the issue with 42" and 52" samsung panels.
                    Can you identify what brand of panel is in your vizio?
                    BTW i didnt use a 10ohm resistor when testing the fix on mine, because i didnt have one around and its 2am. I just used 30feet of 28 ohm wire , which equals roughly 2 ohms of resistance. So the resistance cant be too precise, but probably better to be safer with a higher ohm resistor.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I will have to check on the LCD model number when I get home.
                      On mine I have darker left with ghosting and a darker center section.
                      If I let it run for a couple of minutes the picture disappears and colorful(more green then others) vertical lines appear, it looks like a t-con board failure.
                      Basically where do you solder that resistor on the ribbon cable there shouldn't be any voltage and if there is then my problem is different?
                      Or when I flex the TV the voltage should come on and off on that point?
                      • cashkennedy
                        • Aug 2011
                        • 666
                        There is the long thin boards that run at the top of the LCD panel (for simplicity lets call it the lcd panel board).
                        Assuming you have made a good connection to the tcon / and have cleaned the ribbon cables, then their should be a lot of various voltages present on the thin lcd panel board. On mine and the 32" they are marked fairly clearly, with a bunch of other voltage test points around the same place. Voff was around 7 volts, and vON was around 20.3 volts on mine (19v on the 32" model in the how to video).
                        The thin lcd panel board then has antistropic conductive film connected to it which runs through out the lcd. (the antistropic conductive film is the technical term for tabs). Thery are just glued onto the thin lcd panel board at the top. You can apply pressure to them and see if that reconects the fauly glue.
                        The fix requires you run a 10ohm resistor from the v0N (~ 19v) to a dot on a tab on the side. It is the upper dot thats closest to the screen. The video clearly shows which dot. If you look closely at the tab, the outer most trace that runs all the way around the tab is ground. The next trace is the v0N which leads to the first test point.
                        When i tried reading the voltage of just the tab where i peirced it, there was no reading, but its very hard to get the pin to make good contact.
                        • cashkennedy
                          • Aug 2011
                          • 666
                          I finally got it soldered together... It tooks 3 tabs before i got a good lasting connecting between 1 of the tabs and the wire running to the resistor.
                          The tabs have copper (maybe...) traces inside of some sort of plastic. The plastic is really high temp proof/ temp resistant, cause the soldering iron could be left it contact with it for very long amounts of time. Trying to shave off the plastic coating to get to the traces with a razor blade didnt work at all for me. And if you stuck a needle through you didnt get great lasting contact, and there would be no where for the needle to go once the tv was assembled. But the needle was good for peircing the tab, so that I could try to pick the trace out of the plastic, and eventually i just made a hole, stuck the 28 guage wire through the hole and a lot of flux, and then tryed like hell to get the solder to stick to anything.
                          I used foam tape to hold the 2 soldered wires firmly in place so i wouldnt jar them while reassembling. then i put it all back together and covered the resistor with electrical tape. (My wires were already insulated so i only needed to insulate the resistor.
                          Once back together it still worked ... just have to find some way to live with the extremly dark scenese (an issue with the firmware and design of the TV, not a broken part)... The firmware update i applied was suposed to fix that, but it still is a horrible horrible picture on any show that isnt super bright. Kids shows look amazing on it. Court room shows are so dark you cant see anything but peoples eyes and teeth. (exageration)... (this is probably only a problem with some of the more feature rich sony models specifically my kdl-40s5100) they sell this worthless feature as dynamic scene contrast or something.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Thank you for sharing. I may try it in the next couple of days, it's just that I have other TVs with less issues which could go out of the door much faster.
                            I have another question, do you think that it would be possible to remove the glare layer from a 46" TV? I have read some laptop forums where people did this, but those screens are small to work with and there is a high chance of messing up the screen. I'm thinking that it's probably even bigger chances with this huge screen.
                            I have some scratches in two spots and it would be a lot easier to sell the TV without scratches.
                            • cashkennedy
                              • Aug 2011
                              • 666
                              http://www.febalcdrepair.com/?title=...ment&menuid=12
                              I wish this place actually existed ... lol it sounds to good to be true.
                              Ive never tried to remove or replace the polarizer, but Id assume it is very hard to get off without some serious chemicals. Then again maybe it just scrapes right off with a razorblade? but then youd probably end up scratching the lcd panel that is under the polarizer...
                              Ive not had a failed tv repair yet (now that i got this sony working ) , but maybe if you have a broken screen tv you could try it on that without risking a good tv.
                              Maybe one day topcat will hire us all, and we can line up like the picture of the testing area at this company
                              http://www.febalcdrepair.com/?title=location&menuid=5 < picture at top of site
                              • tibimakai
                                • Jan 2012
                                • 3680
                                That is what we need, but I'm sure it wouldn't be cheap a repair like this, plus shipping to Turkey and back.
                                I see that retiredcaps has the same issue as us, so the crowd it's growing.
                                I have another Sony in which most likely I have to replace at least a ccfl tube(s). A Toshiba which pops and a Vizio which it seams that I'm unable to fix the power supply. So I have a lot of "fun".
                                • cashkennedy
                                  • Aug 2011
                                  • 666
                                  Yep, you are flying through tv's. Im lucky if i see 3 a month on craigslist here.
                                  I did have a incredibly easy 24" samsung tv/monitor that just had a loose lvds cable. The lady had it listed for free, and even delivered it to me, she wanted to get rid of it lol. Ill probably post pics of the samsung one day when im bored as it took me 1 hr just to get it open, but the repair was like 5 minutes of testing lol. Nothing in the set was screwed down, the whole set had like 4 screws total. ... I wonder why the lvds cable was able to come loose....
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Los Angeles is big, so there are a lot of broken TVs here.
                                    There are weeks when I can't find anything though.
                                    I'm willing to drive far sometimes, like 60-70 miles away.
                                    I have sold nine TVs in two months-since I started repairing TVs- and I have kept two more for myself. I have five more to repair.
                                    From now on I have to select which one I pick up and which one I will let go. I will try to avoid plasmas, they tend to be expensive to repair, older TVs then 2007 and cheap brands. Course the size matters too, from 32" and up, at least for now.
                                    Sometimes we are in bidding war, who gives more for the seller gets the TV.
                                    I had one 42" Philips plasma which it listed in the free section and I ended up paying $20 for it just so that I will get it.
                                    Same with this problematic Vizio. If I have known this panel issues...
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Ok, I have taken the panel apart and found the left upper tab(if you look at the TV from the front of the TV) changes the screen if I touch it.
                                      I took a couple of pictures.
                                      I haven't taken the whole TV apart to check the model of the panel yet.
                                      The thin LCD board looks different then in the video.
                                      Next time I will take some measurements.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Anybody has any input where should I solder the wire+resistor on the PCB and the tab?
                                          I myself still trying to understand how someone figure out the function of the side tab of the SONY screen, and what why that tab and that pad but not the other tab/pad. The side tabs are for the Gate drive IC for the TFT on each pixel/sub pixel on the LCD panel. If we understand how that works then it can be applied to non-SONY screen?
                                          • x_orange90_x
                                            Vizio V585-J01 dancing lines and image doubling
                                            by x_orange90_x
                                            I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                            Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                            Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                            I swapped...
                                            06-12-2024, 07:57 AM
                                          • Stephen
                                            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                            by Stephen
                                            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                            05-29-2025, 10:35 AM
                                          • Pinky Deepak
                                            Vizio M60-C3 Left Edge problem
                                            by Pinky Deepak
                                            I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                            Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                            09-27-2024, 05:11 PM
                                          • WillHoh
                                            Slight flickering and horizontal stripes on the right side - VX24AH Asus
                                            by WillHoh
                                            Hi, I have an Asus VX24AH monitor that suddenly went black and didn't display a logo when I switched it on. After extensive research (also thanks to this forum) I was able to get it to show a picture by disconnecting the STV (VSTB1). Unfortunately, the right side now shows horizontal stripes and it looks like every 2nd pixel row is missing.
                                            Can anyone help me with this? Can it still be saved? I would also appreciate links and references to literature or other information.
                                            Before disconnecting, the test point of VSTA1 and VSTB1 only measured 30 ohms. I therefore disconnected...
                                            08-26-2024, 06:45 AM
                                          • Gjackson
                                            SMEG induction cooker error EA on both left hand side cooktops
                                            by Gjackson
                                            I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                                            07-09-2024, 01:46 PM
