Vizio VW42LHDTV10A horizontal lines on the left side
  • tibimakai
    • Jan 2012
    • 3680
    Sorry its a VW46LFDTV10a.
    I have just picked up this TV in the rain and I haven't had time to really look at it, the screen has some scratches, but that it's another issue. By the way there is a method of reducing the visibility of scratches on a screen?
    I was told that it takes like 30 minutes until I see a picture, but when I have tried it at home it just started right away and it showed some horizontal likes mostly on the left side and with video signal it looks like it's very slow that side and I believe that it's called ghosting when do you see a trail of a moving object.
    It could be a bad T-con board?
  • cashkennedy
    • Aug 2011
    • 666
    Re: Vizio VW42LHDTV10A horizontal lines on the left side
    3 things that might be the cause
    1) bad t-con
    2) loose / dirty / missaligned ribbon cables from the t-con to the panel, im sure someone has a guide on how to clean them with a pencil eraser on this site
    3) tab bonding on the screen, try placing light pressure every 3 inches or so around the edge of the screen and see if any of them change the picture (this is least likely based on what the pics show)
    you might want to also test the output voltages from the power supply just for the hell of it, since thats really easy.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    • tibimakai
      • Jan 2012
      • 3680
      The 3.1V, 5V and 12V are all there. The 24V I haven't found it yet because there are two inverter transformers build into the power supply(there are a bunch of small ones on the master and on the slave boards).
      Thank you for helping. To get to the panel's connector, I have to take the whole TV apart, very bad design.
      I have never heard about cleaning the connector pins, could you elaborate on that please?
      • cashkennedy
        • Aug 2011
        • 666
        Ive never seen a dirty ribbon cable, but the commonly recomended trick is to use a pencil eraser to erase / clean the metal pads at the end of the cable. Not really any trick to it, but just be soft, and make sure all the eraser lint is off before reinserting. Im not sure why a pencil eraser is recomended over rubbing alcohol and a cotton swab.
        Having the cable ever so slightly missaligned can easily screw up the picture though, sometimes ive had to retry inserting the cable 3 times to get them to work properly. Usually half the screen is handled by 1 cable, and the other half by the other cable, so usually when you dont have them in properly only half the screen is affected.
        In your pictures theres 2 effects that are noticeable, but i think one might just be from your camera angle. Is the tv just having the black lines that end around the middle of the screen, or are you also getting a curvy set of lines through out the middle (cause that might be just from the camera angle).
        • tibimakai
          • Jan 2012
          • 3680
          This one has four cables.
          I will give it a try tomorrow and I will report back.
            I use Detoxit for cleaning the connectors between the panel and the T-CON, works real well.
            • tibimakai
              • Jan 2012
              • 3680
              this one?
              http://www.radioshack.com/product/in...ductId=2104746
              or this one?
              http://www.amazon.com/DeOxit-Cleanin.../dp/B0002BBV4G
                The one from AMAZON. D5
                • tibimakai
                  • Jan 2012
                  • 3680
                  After having the mishap with the flex cable, replaced the blown fuse F2 and the TV is back.
                  I have watched the TV with signal and the screen shows all kinds of things.
                  What do you see in my first post clears out, center has a darker spot which stays. Picture becomes horizontally sliced in like three, some of these freezing the image, some flicker.
                  Some times I have very good picture, specially the right side, the left is darker and the moving image is very slow.
                  If I restart the TV after a while the screen is mostly green, but it's keep changing.
                  I'm still waiting on that cleaner spray, I should have it by Tuesday.
                  I have a filling that the T-con is bad.
                  Tomorrow I will take some measurement on the regulators.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    After I have used if for a couple of minutes this is what I'm getting, sometimes the whole screen it's green, sometimes I have good picture, but the left sides it's darker and it's very slow.
                    http://img42.*************/img42/6748/smy.mp4
                      In addition to the ribbons going to the T-con, there are usually ribbons going from T-con to the LCD. See if you can get access to them and reseat them.
                      The characteristic glowing and blurring of the screen "looks" like a T-con issue, but the loss of the vertical sync makes me think main board problem! Does the sound go when it freezes? The fact that it gets worse as it warms up seems to me like a BGA problem - you can thank lead free solder for that. Try applying some light pressure to each of the large processors on the main board and T-con. If that fails to change the results, use a hairdryer to heat up the boards until the fault occurs, then shut down the TV (leave it to cool down), then when it powers up heat the component again and see if the fault occurs immediately.
                      To reduce the appearance scratches on the screen you can try cleaning it with a soft moist cloth but mostly it's not repairable.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Actually I haven't tried the LVDS cable yet, just the four ribbon ones.
                        I'm waiting on a D5 cleaner.
                        Thanks for the great ideas, I will try them out.
                        Sound stays the same, not changing at all.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          When I had the picture on the screen it looked very much like in this video, but had the moving object like a mouse trail in Windows, not sure how is called.
                          So on one side the screen the brightness is normal and on the other side it's dark.
                          I'm wondering if I don't have the same issue as in this video, tab bonding issue:
                          http://www.youtube.com/watch?v=vCExl...layer_embedded
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Here is another video, maybe it's better then the previous one:
                            http://img837.*************/img837/6362/l78.mp4
                              That's what it reminded me of. It's worth trying if you can get access to the LCD panel. Sometimes it's difficult.
                              It could also be T-con, since a missing waveform causes both problems, but with tab bonding issues it is because the tab physically separates but T-con simply doesn't send the data, so the effect is similar. The digital noise and jumping on the other hand doesn't look like tab bonding.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I hope I don't have two issues here.
                                I'm uploading another video as I write this.
                                I will have to make a shorter video, it was to big.
                                  Not sure if you had read this yet:
                                  https://www.badcaps.net/forum/showthread.php?t=19852
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Found it yesterday, but I didn't have time to read it all.
                                    Thank you for those links.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I have cleaned all the connections at the T-con board and it got a little bit better, but what made the difference is when I have grabbed the whole TV's frame and twisted it a bit. I had a perfect picture, so it looks like I have a tab issue at the panel itself.
                                      • cashkennedy
                                        • Aug 2011
                                        • 666
                                        YEP!!! if twisting helped you probably have bad tabs, welcome to the family lol! now figure out if that 10w resistor trick to a side tab works, cause i dont want to spend 3 dollars on some 10w resistors from radio shack unless it works lol!
                                        But it would be a good idea to take your tv apart all the way down till the flimsy lcd screen is loose so you can see the tabs and apply pressure to them. If you can get pressure on 1 to consistently fix it, then id just use some foam, put it back together and sell it cheap.
                                        • x_orange90_x
                                          Vizio V585-J01 dancing lines and image doubling
                                          by x_orange90_x
                                          I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                          Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                          Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                          I swapped...
                                          06-12-2024, 07:57 AM
                                        • Stephen
                                          A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                          by Stephen
                                          Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                          05-29-2025, 10:35 AM
                                        • Pinky Deepak
                                          Vizio M60-C3 Left Edge problem
                                          by Pinky Deepak
                                          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                          09-27-2024, 05:11 PM
                                        • WillHoh
                                          Slight flickering and horizontal stripes on the right side - VX24AH Asus
                                          by WillHoh
                                          Hi, I have an Asus VX24AH monitor that suddenly went black and didn't display a logo when I switched it on. After extensive research (also thanks to this forum) I was able to get it to show a picture by disconnecting the STV (VSTB1). Unfortunately, the right side now shows horizontal stripes and it looks like every 2nd pixel row is missing.
                                          Can anyone help me with this? Can it still be saved? I would also appreciate links and references to literature or other information.
                                          Before disconnecting, the test point of VSTA1 and VSTB1 only measured 30 ohms. I therefore disconnected...
                                          08-26-2024, 06:45 AM
                                        • Gjackson
                                          SMEG induction cooker error EA on both left hand side cooktops
                                          by Gjackson
                                          I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                                          07-09-2024, 01:46 PM
