Sylvania LC320SS9 Flashing Green LED
Re: Sylvania LC320SS9 Flashing Green LED
any ideas anybody? anybody had success fixing this poorly designed p.o.s?Comment
That would be great!!! will be very grateful, Having a heck to a time with it i will keep tinkering as well. Please do let me know what you find thanks...Comment
OK
1) the transformer resistance reading, it will show real high resistance because you are reading the lamp terminals not at the transformer terminals, the blue ballast caps are connected between the transformer output winding and the lamp, the cap is an open circuit device, you need to read at the transformer's terminals.
2) Do get DC reading on the Cathode side of the three Diode you replace? Black probe on the chassis, red probe on the Banded (Cathode) side of the Diode.
3) You need to check the sub-power supply on the main board also, you can see a bunch of black body diodes by the switching transformer.Never stop learning
the three diodes are fine in this set unsoldered and tested and shows readings one way and not the other all three of them...at the ccfl connectors, only way i can get a reading is set my dmm to 20m ohms and readings are starting from top transformer 1 to 5 5 being bottom
1. 9.0
2. 7.89
3. 6.5
4. 8.9
5. 5.65
thing is it never stays put it has fluctuations from 15.0 to 5.6 all over on pretty much all 5... its weird....but that's pretty low resistance anyhow.Comment
i only have 4 diodes that read both ways on who knows what board you call it not the inverter circuit but the power board i would imagine.Comment
The big board to the right of the inverter board as shown in Bill post 1, it has Tuner and input jacks on that board, as you can see, it is sub- power supply/Main board. You can see a yellow transformer and a bunch of Diodes, If any one of them read both ways, then you should lift one leg off the board and take reading again, common Diode failure on this board also, beside the bad inverter/power board.
Unless your TV is not the same as shown by Bill.Never stop learning
Unless your TV is not the same as shown by Bill.Comment
heavy,bill,bud> Still making no headway with this poor design. Following you guys for direction. I get a couple green blinks and can hear H.V shut down on secondary power board at transformer. This one is driving me nuts. It's got to be something simple. This T.V looks like it's new inside. We'll get her. Thanks guys for all info,and postsComment
okay update tested all diodes on inverter board and all tested good, checked the bulbs are ok they light up, does have signs of age but still good and its the u type... now checking power/tuner board will report back....Comment
also it took me good portion of the day to test these crazy amounts of diodes on this set. and all solder joints are good.....Comment
Can I get good pictures of both sides of the inverter board, the whole board both sides, then 1/4 shot of board (both sides) so I can see the traces to figure out how it works.Never stop learning
by shelby5041hi
ive got a modern digital clock radio approx 15yrs old
my question is how long can a clock radio or a simple radio last ss farcas operating hours?
since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
it uses very little power just a few watts i would imagine that may have something... -
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by beetle1303Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
The main PD connector:
PD-1 (PNL12V) : 0.02V
PD-2 (PNL12V) : 0.02V (fluctuating)
PD-3 (SGRN) : 0V
PD-4 (SGRN) : 0V
PD-5 (UR13.2V) : 0.05V (fluctuating)
PD-6 (UR13.2V) : 0.05V (fluctuating)... -
by UserXPDear all,
I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
My question is, do you know of this brand of capacitors and how bad are...-
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... - Loading...
