Philips 42PFL5432D/37 I May Have Made my Problem Worse
  • m1dp
    • Feb 2012
    • 16
    Hello this is my first post on BadCaps but not my first visit. About 2 months ago i would go to power on my tv it would stay on for seconds then turn off, (red led turn to green back to flashing then solid red and was also squealing before this occurred) searched and found this site to help me with the bad caps on power board. The bad caps were 3 capXon 1500uF35v c951, c952, c953 and capXon 2200uF16v c955. I replaced them with the panasonic equals from thread "Philips LCD 42PFL5432D/37 - Bad PSU"
    http://search.digikey.com/scripts/Dk...name=P12409-ND
    Ordered, soldered and tv started right up. the other day i was watching and whole tv powered down and there was no led red nor green so i opened it up there were no bloated caps on power board or burn marks. So I opened the scaler board case, which i didn't do last time, and found c218, c812, and c807 all capXon 1000uF25v bloated spewing black gunk, c113 capXon 220uF25v, c131 capXon 470 uF25v bloated as well. c830 is same as c113 but not bloated but also replaced.
    Here is where i may have messed up instead of coming here i got on digikey and searched here is what i ordered
    3 of http://search.digikey.com/scripts/Dk...ords=P11223-ND
    1 of http://search.digikey.com/scripts/Dk...ords=P10275-ND
    2 of http://search.digikey.com/scripts/Dk...ords=P12383-ND
    they are all bigger than the original ones that need replacing. i did order
    these all 3000hr at temp instead of 2000. Thinking that it was just the lifetime of the part that made it bigger i installed them connected everything and plugged it in, nothing changed. so i checked the fuse http://search.digikey.com/us/en/prod...2666-ND/777438 and it is bad. My questions are, did i order and install wrong parts causing the fuse to go bad? Are the parts good parts and fuse just went out? If that what caused the fuse to go bad in the first place? i was in the middle of a show when tv went off, no power out, or surge just, off. sorry no camera now but trying. Pictures on https://www.badcaps.net/forum/showth...2PFL5432D%2F37 seem identical. checked inverter boards and they don't have bloated caps. i don't know what else to look for but i went to the local electronic shop took the power board to see if they had any fuses asked him if anything else looked bad to him and he said no that everything looked fine to him but the fuse was definitely bad and he didn't have none. Here now with my order on hold thinking that i might need more parts. Can any body help me? Here is the type of multimeter i have just in case. Velleman Dvm-850Bl 3 1/2 DMM 10A Digital Multimeter
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Philips 42PFL5432D/37 I May Have Made my Problem Worse
    1) My own opionion on this particular model is that there are multiple problems with it. I don't have this model, but helped enough people to know the problems.
    i) The first is obviously all the Capxon crap quality caps on both the power and main/logic board that die under heat.
    ii) This TV runs temperature hot.
    iii) The zener diodes are prone to dying causing the SMPS power supply not to come on. You can check them as per instructions on the other multiple threads.
    2) I would order 2 or 3 fuses just in case.
    3) The cap replacements you chose are fine.
    4) Sometime fuses go open due to heat, stress, and/or fatigue.
    --- begin sig file ---
    --- end sig file ---
    • m1dp
      • Feb 2012
      • 16
      thanks for the reply! i lost my debit card so i haven't ordered the parts yet but i am just going to order the diodes you said with the fuse and just replace i will post with the results later
      • m1dp
        • Feb 2012
        • 16
        fuse popped as soon as power was turned on to surge protector. i have two more replacements and no ideas, will somebody help me? there is one mofset chip that is not giving me signs of continutiy on any of the 3 pins is there a way to test these?
        • retiredcaps
          • Apr 2010
          • 9271
          Post clear focused top down view pictures of all your boards (both sides) following the instructions in my sig file in post #2 EXACTLY.
            Chassis number of this TV so we can look up the service manual for it?
            • selldoor
              Slow Learner
              • 7870
              This set has featured on here before service manual is here:
              • m1dp
                • Feb 2012
                • 16
                got pics!
                • m1dp
                  • Feb 2012
                  • 16
                  more
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    1) Circled in red is what I think is your power mosfet. Circled in blue is your bridge rectifier. Check both of them for shorts.
                    2) For the power mosfet, number the pins 1, 2, and 3. Measure the resistance between pins 1-2, 1-3, and 2-3. Any reading under 30 ohms suggests a short and must be desoldered and retested out of circuit.
                    3) For the bridge rectifier, number the pins 1, 2, 3, and 4. Measure the resistance between pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. Any reading under 30 ohms suggests a short and must be desoldered and retested out of circuit.
                    4) I noticed you didn't replace ALL the electrolytic caps on the power board. I see green Lelon and possible more small Capxon caps.
                    • Lobo
                      • May 2010
                      • 59
                      I really didn't want to start yet another thread on this bunk TV, so I figured I'd post here on the most recent and closely related. Regarding the power supply.
                      So I have the exact same TV and I've been looking over the service manual. All the caps I compared to the service manual's Recommended/replacement parts list, and the ones one the actual board seem to match up correctly as far as uf, V, and size are concerned...except one. It's a big fat Lelon.
                      On the actual PSU board it's
                      Lelon LSG
                      220uf
                      450V
                      D 35mm x H 30mm
                      In the service manual, the spare part list says it should be
                      180uf
                      450 V
                      D 30mm x H 31mm
                      Besides the fact that it's a Lelon cap, could this be the root of all our problems?
                      • selldoor
                        Slow Learner
                        • 7870
                        @Lobo - I wouldnt have thought so- in any case there may have been revisions since the schematic was produced. - Was the Lelon in from new?
                        You could change it and see if it helps?
                        • Lobo
                          • May 2010
                          • 59
                          The cap is the one that was originally on the board. It's the only one I haven't replaced yet. I've tested it and it seems good to me. At least I think I'm reading the Lelon datasheet right. (google translator doesn't really do a good job with their website) It's just that the size and uF don't match up with what's on the schematic.
                          • m1dp
                            • Feb 2012
                            • 16
                            the power mosfet you circled is 4 pins, the bridge rectifier is two pins.
                            will you please tell me what setting to use for ohms? i am only getting results from the continuty beep setting. also notice the smudge on the big brown lelon does it look bad to you and can that be the fuse popper?
                              I think the one in RED circle is the Bridge rectifier (4 pins), and the blue with 2 pins is the AC line filter cap.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Arrgh, let's try this again. It is hard to tell from the angle of the photo and I can't read the pcb designations.
                                1) In purple, I think that is the bridge rectifier.
                                2) In green, I think that is the power mosfet.
                                3) Set your multimeter to 200 (two hundred) ohms.
                                See the section on multimeter below
                                https://www.badcaps.net/forum/showpo...4&postcount=19
                                and mistakes
                                https://www.badcaps.net/forum/showpo...2&postcount=31
                                • m1dp
                                  • Feb 2012
                                  • 16
                                  i removed the power mosfet you circled in green and was getting jumpy readings with the 200 ohms setting. I noticed on the pcb in front of the chip is a voltage drop sign so i adjusted to the 2k ohms with voltage drop setting and got no change one way and a reading of .454 ohms the other.
                                  • m1dp
                                    • Feb 2012
                                    • 16
                                    I now removed the bridge rectifier and like the mosfet am getting jumpy readings do thes indicate shorts?
                                    i've tried every pin combination. some do stay at, 1. ,with no change and others jump high then back to 1. on the 200 ohms setting. the only results i am getting that stay steady on are when i change the meter to 2k voltage drop. anyway you can clear this up for me so i can get the proper results you need
                                    https://cdn.badcaps-static.com/pdfs/...8a934e8c25.pdf
                                    • Mr Bill
                                      • Nov 2011
                                      • 648
                                      http://www.youtube.com/watch?v=dqkT6hF0O3E Here is a link on how to check a bridge rectifier. Your multimeter needs to be in the diode function (picture below).
                                      The ??mosfet?? you removed actaully looks like a diode (marking on board) The mosfets might be the 2 chips behind that one with the 2 bands clipped on them. Can you get a photo of the 2 chips?
                                      Also, I circled a chip on the backside of the power supply, can you make out the numbers on it. Its a real pain but sometimes you get lucky, a magnifying glass helps.
                                      • Lobo
                                        • May 2010
                                        • 59
                                        I have the exact same TV and PSU and the best I can make out on the chip is
                                        SG6961S7
                                        B1AG2897728E
                                        Hard to tell if the first digit in the second row is a "B" or an "8", I just guessed B.
                                        Also, the "mosfet" is actually a diode.
                                        STTH8L06FP
                                        GK0G7 VU
                                        CHN 725
                                        The chip behind it in the picture is a mosfet.
                                        W26NM60
                                        CC126 V3
                                        MAR 719
                                        The one next to it (not in the pic)
                                        W18NK80Z
                                        CC099 VW
                                        MAR Z25
                                        Hope that helps
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          11-22-2025, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • Ifixstuff9
                                          Philips 42PFL5432D/37 power supply issue no 12v
                                          by Ifixstuff9
                                          I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                          After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                          05-02-2021, 09:29 PM
                                        • Justin_D33
                                          You know what pisses me off? Finding CapXon in the wild.
                                          by Justin_D33
                                          It doesn't matter the series - GL, KF, LX, PD, I don't care. If I see CapXon in anything, my instinct is always "get it out of there". Even if it "looks fine". They should be ashamed of themselves. CapXon = CrapXon (rightfully memed).
                                          11-25-2025, 09:27 PM
