Acoustic solutions LCD26761HDF no backlight
  • sienoki
    sienoki
    • Jan 2012
    • 314
    #41
    Re: Acoustic solutions LCD26761HDF no backlight
    Heres a pic..thx
    http://i1068.photobucket.com/albums/...5/P1000843.jpg
      OK, the next step is to find out if the PIN 1 (VDD) of the FAN7711 is getting the voltage feeding it, I have a hard time tracing out where it goes to in the pictures.
      • sienoki
        sienoki
        • Jan 2012
        • 314
        #43
        Does this pic help..thx
        http://i1068.photobucket.com/albums/...5/P1000846.jpg
          I saw that picture but not sure if pin 1 is connected to R976, JUMPER J152 and then goes down some where in the bottom right of the picture, we just need to verify if we do have DC power feeding the VDD PIN1 of the IC or not.
          • sienoki
            sienoki
            • Jan 2012
            • 314
            #45
            How am i testing pin1..tv on black probe ground screw red pin1..thx
            Im getting 14.96vdc with tv on
              Black lead to the ground pin4 (GND) of the IC, Red probe to pin 1 (VDD), just do not touch ANY METAL PART OF THE PROBE OR CHASSIS DURING THIS MEASUREMENT IN CASE YOU SLIP SINCE WE ARE WORKING ON THE AC PRIMARY SIDE OF THE CIRCUIT!
              • sienoki
                sienoki
                • Jan 2012
                • 314
                #47
                It measures 15.00vdc
                  And It is not there when you turn off the power switch? The 15vdc is correct since there is 15V Zener inside the IC.
                  At this point, it can be the IC is bad since it has the voltage but not sending out the drive signals (PIN 5, 7) to the two Gates of the MOSFET's. One thing I am not sure what those components on the left top corner are for yet. If you do have the 400Vdc feeding the MOSFET's, then I would try new IC.
                  • sienoki
                    sienoki
                    • Jan 2012
                    • 314
                    #49
                    Thx for your time & being patient with me..im getting 392vdc measured with fluke..theres this repair kit..do i need it all?
                    http://www.chsinteractive.co.uk/elec...3-q814-s-c.htm
                    I cant find the IC830 FAN7711 in my farnells catolouge..thx
                      eBay: http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        #51
                        Thx tom..should i recap all the board or just try this IC first..ive been reading about the 4 block caps 2 red & 2 grey..thx
                          Try that for now as it will eliminate a possible cause.
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            #53
                            Thx fella..ordered the IC will get back to you guys when installed..thx
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              #54
                              IC came today still no backlight..where to next?..thx
                                Any big resistors connected to the source pin of the MOSFET? Can't see them from your pic. Might be O/C.
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  #56
                                  Hi tom..do these pics help..thx
                                  http://i1068.photobucket.com/albums/...5/P1000867.jpg
                                  http://i1068.photobucket.com/albums/...5/P1000872.jpg
                                  http://i1068.photobucket.com/albums/...5/P1000871.jpg
                                  http://i1068.photobucket.com/albums/...5/P1000873.jpg
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    #57
                                    Is it the 2 smd resistors 103 & 330 if so they measure Q813-103=10.2 & 330=33.7 in circuit
                                    Q814-103=10.03 & 330=34.0
                                    The big resistor R971-red-red-silver-gold which is 0.22 only measures 00.8 thats in circuit shall i pull 1 leg..thx
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      #58
                                      Do i need the other items in this kit..thx
                                      http://www.ohmsupplies.co.uk/17PW26-...-Q813/Q814-S/C
                                      R971 1 leg pulled reads 02.4 is this O/C..thx
                                        Probably not the SMDs, R971 is likely the sense resistor. Don't worry about pulling it for now, what does you meter read when the leads are touched?
                                        Also check the two diodes for s/c looks like it's a two-switch forward converter. Big improvement on the old half-bridge Vestel designs which had huge reliability problems.
                                        C878 could also be faulty but unlikely just looks like a snubber.
                                        • sienoki
                                          sienoki
                                          • Jan 2012
                                          • 314
                                          #60
                                          Tom ive come across this what do you think..the 3 resistors in parallel r817-818-819..ive got 3 new same value from another kit that i didnt need...
                                          When it mensions D861-Q841 & C904 they are print side right alongside the 24vpin out & thatD861 marking AP has readings both ways as i mentioned earlier in this thread..thx
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • Comp_Pro
                                            No Backlight Macbook A1990 820-01041
                                            by Comp_Pro
                                            Hello all,
                                            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                            Tests performed:
                                            There is no backlight even with a good screen.
                                            Backlight IC is receiving the correct support voltages.
                                            Fuse F8400 ok
                                            Current sense resistor R8400 ok
                                            Backlight IC is receiving 3.3V on enable pin.
                                            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                            Backlight IC receiving 5V from PP5V_G3S
                                            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                            05-06-2024, 10:23 PM
                                          • jimbofz
                                            lg 32LC46 backlight inverter board fault
                                            by jimbofz
                                            Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                            still no b/l this uses inverter type:1315 B1-16A,
                                            im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                            all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                            this allows protect to be temporary overridden.
                                            b/l now comes on
                                            but the left hand side of pic is gradually darker than the right side
                                            i have the cct for the tv
                                            but it does not have inverter cct.
                                            i opened it up to inspect the ccfl tubes
                                            and they dont have any...
                                            12-19-2021, 06:58 AM
                                          • cheebster
                                            iPad Pro 12.9 5th Gen Backlight Issue
                                            by cheebster
                                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                            Anyone...
                                            05-20-2025, 09:17 AM
