Acoustic solutions LCD26761HDF no backlight
Re: Acoustic solutions LCD26761HDF no backlight
On the schematics ive attached that IC802 is a IRF7314 but i dont know owt about schematics..thxLast edited by sienoki; 03-02-2012, 05:55 PM.Comment
Im still stumped for getting my hands on a decent camera for now..i came across another forum while googling this model faults & 1 suggestion was to replace C802 & C934 the 2 block reddish caps which markings are 105K 450MFF & IC802 which is underneath them 2 caps ic marking E131 FAN7529..can any1 shed any light on this..thx
My pics wont upload can i show them with another method..thxLast edited by sienoki; 03-03-2012, 02:44 PM.Comment
http://i1068.photobucket.com/albums/...P1000796-1.jpg
hope its ok for now using this method..thxComment
http://i1068.photobucket.com/albums/...5/P1000810.jpg
http://i1068.photobucket.com/albums/...5/P1000812.jpg
http://i1068.photobucket.com/albums/...5/P1000813.jpg
http://i1068.photobucket.com/albums/...5/P1000814.jpg
http://i1068.photobucket.com/albums/...5/P1000816.jpg
http://i1068.photobucket.com/albums/...5/P1000817.jpg
http://i1068.photobucket.com/albums/...5/P1000820.jpg
http://i1068.photobucket.com/albums/...5/P1000818.jpg
http://i1068.photobucket.com/albums/...5/P1000819.jpg
Any help plz to where i can start testing..thxComment
What is the voltage across the big main cap in operation and when in standby?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Am i black probe to ground screw and red to + leg of big cap..thx
http://i1068.photobucket.com/albums/...5/P1000822.jpg
heres my borrowed multimeter..thxLast edited by sienoki; 03-03-2012, 05:14 PM.Comment
Your wanting me to get blown up lol..how am i testing this safely..thx
Red lead on one terminal black on the other.
Nothing touching ground and don't touch the cap yourself or you'll find out that it hurts a lot.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Rubber gloves and wellies!!
Set your meter on 600volts DC - Red positive lead on positive leg of capacitor and black negative lead on negative leg of capacitor. Put the meter where you can easily see it without moving.
Just looked at your meter DC is the Flat bar with 3 dots under it and the V. Take care as I notice the
probes are broken and possibly cracked? For this voltage Id tape them up a bit.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
standby .946VDC
tv on 2.874VDC
.045 VAC &1.380 VAC from OL the readings werent steady they were up & down
Forgot i had this buried in cupboard..it read 400V in standny & tv on..thx
http://i1068.photobucket.com/albums/...5/P1000823.jpg
Should i recap all the psu caps with panasonics as they are all different named brands..or just hang on for now..thxLast edited by sienoki; 03-03-2012, 06:22 PM.Comment
That was scary but no permed hair lol
standby .946VDC
tv on 2.874VDC
Should i recap all the psu caps with panasonics as they are all different named brands..or just hang on for now..thxComment
I am confused, what DC voltage do you get on that large cap when TV is plugged in but not turn on, what is it when the TV is turn on?Never stop learning
Getting 391DC when program button pressed as it must be on then & blue led is standby by..thx
So the cap is 450v is close to 400v enough?Last edited by sienoki; 03-04-2012, 02:26 AM.Comment
391V is okay, PFC is working.
Got a pic of the controller for the 24V (on the bottom of the board usually?)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
When i mentioned about ariel in & having no signal display on screen..on the back cover of the tv next to the antenna it says 5vdc..am i right assuming that the antenna needs 5v if so thats not working aswell cos my ariel on my house roof is in perfect order with 100% signal on my nearly fixed lg 42"Comment
5VDC is probably for powered antennas... don't worry about it should be fine.
Near the power MOSFET for the 24V there should be an IC what is the name/number on it and a photo would be helpful can't make out much from your pics.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hi tom..is the controller on any of the pics ive already posted..thx
Please look at the PDF, I need that P/N of the IC830 FOR THE 24VDC SMPS SECTION.
At this point the PS_ON is OK, the power supply with PFC controlled will use the same signal to turn on the PFC circuits and the 24VDC power supply section at the same time.Attached FilesNever stop learning
Thx budm its been a very loooong day..the IC830 is FAN7711 VJ28..thxComment
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by jimbofzHi this oldie had no backlight .after replacing caps on 24v rail ,
still no b/l this uses inverter type:1315 B1-16A,
im sure ive come across the same inverter in a samsung possibly le32r88bd ?
all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
this allows protect to be temporary overridden.
b/l now comes on
but the left hand side of pic is gradually darker than the right side
i have the cct for the tv
but it does not have inverter cct.
i opened it up to inspect the ccfl tubes
and they dont have any... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... - Loading...
