Why the Hell aren't LCDs Protected with thick Glass, Like Plasmas?
  • Paul678
    • Nov 2011
    • 402
    Excuse me for the newbie realization, but I just
    took apart the Komodo 42" LCD, and there was nothing
    between this ultra thin piece of LCD glass, and
    the wild, baseball throwing kids of the world! Same
    goes for the other LCD I worked on.
    And both the plasmas I've worked on had very thick glass
    over them, even the older one.
    Is it just cost reduction, or is it a weight issue, where
    the LCD makers are targeting people who mount them
    on the walls, or hang them from the ceiling?
    Or perhaps they WANT you to break them quickly, so
    you'll buy next year's model sooner! haha
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Why the Hell aren't LCDs Protected with thick Glass, Like Plasmas?
    These are all just guesses, but I think they just want to save money, also, maybe o,age quality gets worse, or brightness?
    • Paul678
      • Nov 2011
      • 402
      Perhaps a combo platter of all the above.
      Someone mentioned how you sometimes cannot really see a cracked
      screen. I didn't take it seriously, because the first cracked screen
      I got was very obviously smashed up. But after today, I'm thinking
      I got lucky the Insignia 32" I easily fixed wasn't cracked.
      So there's no real way to see these cracks if the lamps aren't lit?
      What about hair-lined-cracked plasmas, with all the gas leaked out? No
      way to tell if the buffers/y-sus aren't working, right?
      • Scenic
        o.O
        • Sep 2007
        • 2640
        It helps to inspect the panel with a really bright LED flashlight/torch close to it at a bit of an angle.
        Someone tried to scam me once saying it (32" LCD) just doesn't turn on anymore, but otherwise it was fine up to that point . Went hunting with the LED flashlight and found a diagonal crack in a top corner. You couldn't see it at all without the flashlight. Confronting him with that made him admit it fell over at some point. He probably "modified" it to get no AC power so the buyer couldn't check for cracks.. damn idiots
          Several reasons:
          - LCDs do not contain a gas so glass is not needed to maintain this pressure. (Plasma panels deal with 4 Torr, which is a huge amount of pressure, so the glass needs to be quite thick.)
          - Newer plasmas are foregoing this thicker glass to make thinner and lighter TVs. The picture is brighter as a result of this, but the glass is far more prone to cracking.
          - Glass is expensive.
          I *have* see one display with a second layer of glass over the main screen, on a Panasonic plasma. The screen was about 8mm back from the main glass, which was a good few mm thick. Panasonic directly marketed this glass as being replaceable if damaged by flying game controllers.
          • Paul678
            • Nov 2011
            • 402
            I'm not talking about the thickness of the panel itself, for which
            plasma would definitely be thicker than LCD for the reasons you have stated.
            I'm talking about the additional piece of glass that covers the actual
            panel. This additional piece of glass was there on 2 plasmas, and
            was missing on 2 LCDs.
            I think it's a combo of cost and weight....especially since the viewing
            areas are getting so large.....they have to do something to keep
            the weight down.....
              It's probably because if the main glass broke, it could easily shatter and hurt someone.
              Or because plasmas are not intended to be super thin TVs.
              Or because plasmas used to be very expensive, and still cost more than LCDs.
              • PlainBill
                • Feb 2009
                • 7034
                And to add two more reasons,
                1. A protective glass layer would provide two more surfaces to scatter light, get dirty, and cause double images. I believe it was in this forum someone had a problem with a plasma TV that had a blurry picture, but mainly in one area of the screen. He eventually discovered the TV had a second EMI absorbing layer of glass. Cigarette smoke residue had coated the surfaces. Fortunately, he was able to dismantle the TV, remove the front glass and clean both surfaces. But what a pain if that had to be done routinely!!
                2. Glass absorbs light, making the picture dimmer.
                PlainBill
                • Scenic
                  o.O
                  • Sep 2007
                  • 2640
                  why do I keep thinking of plexiglas now that I rethink the concept of having a protective whatever in front of the LCD.. ?
                  Wouldn't shatter into a million pieces, it's rather light and can be very sturdy.. hmm..
                  • PlainBill
                    • Feb 2009
                    • 7034
                    And attracts dust, and scuffs easily.
                    PlainBill
                    • Paul678
                      • Nov 2011
                      • 402
                      Yeah, most "plasma vs. LCD" websites give the
                      brightness advantage to LCD, so no doubt this
                      is one of the reasons.
                      But let me ask again: Is there a way to tell if a plasma
                      panel has an invisible crack, that has allowed the
                      gases to escape, when the Y sustain and/or buffers
                      are bad?
                      • rpgruss
                        • Jan 2012
                        • 124
                        Can't speak for all panels, but I have an LG panel here that has a glass bulb on the backside, if the panel is broken the bulb gets shattered. I can post up a picture if you want.
                        • Tvbob
                          tvbob
                          • 204
                          Back in the day, High end lcd's such as the Olevia (lt42hvi) have a removable anti glare glass panel in front of the lcd panel. Most of the newer stuff is cheap junk.
                          • cliff_hootarski
                            • Jul 2006
                            • 411
                            I have one of those Olevias. I has a very thick front glass panel. The 46" LCD tv weighs in at a slim 130 lbs!
                            • Paul678
                              • Nov 2011
                              • 402
                              I'm aware of the bulb on plasmas that you are talking about,
                              but I'm sure you could have a tiny crack on the front of the
                              panel, lose all your gas, and not affect this bulb.
                              And just like with LCDs, it could be very difficult to see this
                              crack if the panel doesn't light up......
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • tongshadow
                                Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
                                by tongshadow
                                I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
                                "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
                                Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
                                03-12-2023, 12:06 PM
                              • SarcasticOP
                                Replaced the glass IC on a Series X, Pin 13 in now OL.
                                by SarcasticOP
                                Hello!
                                I am replacing the booster IC (glass IC on the other side of the HDMI port) and I had to use a bypass chip I from Sourcely. I got everything set up and resolved the issue I was having from that (different line was OL) but now I am contending with this one. Is there something I can do to restore the signal?
                                Attached is a photo with the pad in question that is supposed to supply the signal to pin 13 on the HDMI port. Tweezers where I am pointing to.
                                12-18-2024, 02:29 PM
                              • Francesc V.
                                Technics SA-AX530 in protected mode. Overload message
                                by Francesc V.
                                I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                                I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                                I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                                (Pin 13 goes through...
                                11-18-2024, 12:39 AM
