Video card MOSFETs crushed... need to replace them?
+ More Options
Posts
  • Trevor
    • Apr 2006
    • 7
    Hoping that this is the correct category to put this in.
    I had an account on here quite some time ago, only for lurking... apparentally it got pruned or something along those lines, so I re-registered [Galvanized pointed me over here several months ago.]
    Lots of fascinating stuff over here, though quite a bit of it is over my head.
    Anyway, onto the problem..
    Someone I know [[and yes, it really is someone I know No way I'd buy this card..]] purchased an X1900XTX, with the intent of overclocking it, and also bought a full coverage waterblock.
    In the process of mounting the full coverage waterblock he crushed two MOSFETs, indicated below:
    [[This is not the actual picture of the card, but a higher-quality one of the exact same card for the sake of seeing detail.]]
    The actual card:
    So, the questions are:
    1) Is the card fixable?
    2) How to remove the current MOSFETs--he's already tried, with limited success [[see the second picture.]]
    3) How to go about getting new MOSFETs-- VT1103SF and VT233TF.
    E-mail has already been sent to Volterra, but highly doubtful they'll respond for quantities of one.
    Possibly try ATi?
    Or is a scrapped card the only option?
    4) How to put the NEW MOSFETs in?
    Solder?
    etc.
    Thanks for the time guys, it's much appreciated.
    --Trevor
  • tiresias
    • Feb 2006
    • 489
    Re: Video card MOSFETs crushed... need to replace them?
    Welcome Trevor,
    I'm afraid those two crushed components are not MOSFETs... at least, they don't looks like FETs, and the PCB lists them as Uxxx, as opposed to Qxxx which is what would expect from a transistor.
    The U usually implies "microchip" of some kind - are you sure it's not an IC with a BGA grid underneath? That would be difficult to repair. You might want to check that and get back to us.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Multi-Phase Synchronous Buck Voltage Regulator Chipset
      • Trevor
        • Apr 2006
        • 7
        VT1000 Family: Multi-Phase, Synchronous Buck Voltage Regulator Chipsets
        I saw Voltage Regulator, and assumed transistor... but maybe it isn't?
        Photobucket downsized the other image for whatever reason.
        Here it is, slightly cropped [to allow for forum restrictions], but visible now.
        Looking at it, you're right, there seems to be a grid underneath.
        [[Not attaching itself. Darn. Imageshack isn't working either. Let me find somewhere that'll take it.]]
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          It is possible to solder them, without a solder reflow station
          Get a oven and a thermistor, carefully set the oven to about 210-220°C
          Place the new BGA device you want to solder as carefully as you can ontop of the solder pads, you do not need to get it 100% perfect, because it will "float" to the nearest solder balls when they melt, but that also means you must make sure that it does not flow to one of the other "grids"... Anyway, leave it in the oven for about 3 minutes. That is the theory anyway, search google for BGA and Oven and you should find more info on it, good luck mate ;-)
          EDIT; here is one; http://www.instructables.com/ex/i/EA...E506/?ALLSTEPS
          • Trevor
            • Apr 2006
            • 7
            Got it!
            Can't quite tell, but those might be little pins. Uh-oh.
            Thanks again for the help guys.
            --Trevor
            Edit:
            Per, I like the suggestion, but 100C is a bit high for some of the components on the video card, isn't it? If not, that sounds perfect ... but what about acquiring the chips?
            --Trevor
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              looks like bga .
              hopefully the pads arent boogered up from the prying.
              i use hot air to rework those type chips.
              • arneson
                • Sep 2005
                • 1267
                I would not get hopes up for a repair on that.
                Jim
                • WeStSiDePLaYa
                  • Mar 2006
                  • 63
                  since its toast anyways. i would say dont use an oven, but use a heat gun.
                  ive used a heat gun to remove chipsets from old mobos.
                  Specs
                  DFI AM2 LANPARTY UT NF590 SLI-M2R/G
                  X2 3800+EE AM2
                  2x1GB OCZ PC2-6400 Platinum XTC
                  XFX 7900GS
                  Maxtor 6L250S0
                  Maxtor 6V300F0
                  Western Digital WD2500JS
                  Mushkin HP-550(Cap/Filter Modded)
                  Cooling
                  Swiftech Apogee
                  Swiftech MCW-60
                  Swiftech MCP-600
                  HardwareLabes Black Ice Extreme 2
                  • japlytic
                    • Oct 2005
                    • 2086
                    Talking about BGA chips, there are some Sky Digiboxes with bad solder joints on the BGA chips, and one Topfield TF5000PVRt box had been found at a junkyard; one possible reason could be bad solder joints on the BGA chip. There are very few, if any, service centres in Australia capable of working with such packages.
                    Hope this card is not brand new; the package in the pictures needs precise positioning as well... good luck
                    • Galvanized
                      • Mar 2006
                      • 468
                      If your thinking of repairing this for a friend...I'd have second thoughts. If this was given to you=another story. Give it a go. If you have a junk board, of any type, practice on it. I like the heat gun idea myself. Only once have I used a heat gun to preheat a CPU HS for removal. (Never used one on a pcb.) A cardboard dam was used to keep heat off surrounding componets.
                      If your practice on a junk pcb, remember that lead free solder has a higher melting temp (read it here). A decent dam could be used to concentrate the heat on the board's backside. Good luck OP.
                      • Trevor
                        • Apr 2006
                        • 7
                        Card of an accquantince. I was considering buying it from him for the experience of fixing it, but after reading here, you've changed my mind. Not worth throwing the ~100 dollars out, when I can invest that in a good PSU instead
                        Thanks guys. Keep this thread going, if you'd like. I'd still be interested in any pointers/tips for reference later on.
                        --Trevor
                        Edit:
                        Japlytic, the card was brand new I feel bad for the guy; ~550ish [actually more than that, because he lives in the UK] down the drain.
                        --Trevor
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          well he might as well stick it in the for sale section. there is a few that could do that repair.
                          any broke stuff you see send em here.
                          nope, they probably cooked it at 230oC before he bought it. plastics would be the first thing to go.
                          • creidiki
                            • May 2006
                            • 3
                            G'day o/
                            I'm the guy who crushed the card
                            I'm not sure what to do with it at this point, tbh. There's someone on XS offering me a hundred bucks for it, but if someone is able to repair it, I'll split the profits with him... otherwise i guess ill stick it in the sales section as you say
                            In any case I need to figure out what to do with it within reasonable time, because my bank account is bleeding.
                            Open to suggestions here.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              well i damaged traces on a brand new P4C800-E Deluxe during pre-emptive recapping. i guess we all have bad days.
                              did you power up the board after the damage? (i am not saying to try, it would be a bad idea)
                              there is a few here who could do that repair, problem would be to find those vrms
                              • Trevor
                                • Apr 2006
                                • 7
                                My guess was to get it from another guy who'd toasted his board, too.
                                --Trevor
                                • creidiki
                                  • May 2006
                                  • 3
                                  Yeah, the PC powered up fine, but no video output.
                                  I did damage the vrms while attempting to remove them - as per someone's suggestions - but they were pretty crushed to begin with.
                                  • Trevor
                                    • Apr 2006
                                    • 7
                                    Oops. I was under the impression they were just pins. Didn't think you'd take a knife to them and try to scrape them off.
                                    Heh.
                                    Both at fault.
                                    • PR373ND3R
                                      • Oct 2006
                                      • 4
                                      Hi, I've the same problem!! I also broke those 2 little chips.
                                      Can anyone tell me where to get those VT1000 Family: Multi-Phase, Synchronous Buck Voltage Regulator Chipsets.
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        its not something you willl find easy. best idea would be to find another card with the same problem and salvage the chips or try to obtain sample from a distributor.
                                        • Öğretmen27
                                          Can a 17IPS62 power card have 50ZFP mosfets instead of 80R1K2P?
                                          by Öğretmen27
                                          17Mosfet short circuit on IPS62 power card. Mosfet 80r1k2p mosfet 850v 4.5 A. I have a 50ZFP mosfet. 500V 7.2A. The voltage of 50ZFP is 500 V. There is already 400 v in that hot area. Is there any problem?
                                          01-05-2025, 11:04 PM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                          09-06-2024, 08:30 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • benwaterson
                                          Gigabyte Aorus 1080ti - card not initialising
                                          by benwaterson
                                          Hi there.
                                          Have searched various forums but haven't come across the exact issue I am having.
                                          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                                          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                                          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                                          02-05-2022, 11:42 AM
