skyworth led tv shows white screen only when turned on
  • g.i. jane
    • Jan 2012
    what seems to be the problem ... please help
    Re: skyworth led tv shows white screen only when turned on
    Model number?
    Pictures?
    Sounds like T-con fault, possibly a fuse. But, bad capacitors caused this problem on an LCD monitor I had.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      White screen only tells you the back-light is working and the video isn't.
      There are dozens of faults that could do that.
      Mann-Made Global Warming.
      - Dr Seuss
      • truep
        • Aug 2010
        • 373
        Does it have sound?
        will it show the menu?
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • EazyBone
          Sharp LC-65Q620U White Screen
          by EazyBone
          Another TV topic!!
          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
          08-21-2024, 12:56 PM
        • hcinne
          Dell G15 ryzen edition black screen 2 amber 1 white
          by hcinne
          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
          07-23-2024, 07:56 AM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
