Samsung 50" plasma blank screen
    replied
    Re: Samsung 50" plasma blank screen
    Originally posted by Tweek4
    I had similar thoughts. However the manual is a little confusing, as follows:
    The diagram in the manual(photo,actually), shows the cable from the smps board to the main board to be disconnected quite clearly, but the socket number given is the adjacent connection which goes to the logic-main board. I disconnected that one after reconnecting the main board and I read zero volts. So.......???
    Peter
    I'm not sure. But the fact that you have some kind of display (even if just dimly lit) probably means that the power supply is okay. I have no idea if the manual is correct but it doesn't seem right.
  • Tweek4
    replied
    Peter
    replied
    To elaborate on my previous post, the first step in the manual for troubleshooting no video with audio is to disconnect the cables going between the power supply board(smps)
    and y, x and main boards and check if Vs and Va are normal.
    First, I disconnected all three boards and Vs and Va measured zero.
    Then I reconnected the main board only and Vs and Va measured normal(207v and 56v).
    According to the manual the smps board needs to be changed.
    Does this sound reasonable
    No... The voltages are only present when the main board tells the power supply to switch on. As Vs/Va are present, SMPS is most likely okay.
  • Tweek4
    replied
  • Tweek4
    replied
    Thanks for the help.
    I read the manual linked in post#42 and started the checks for no picture, and after the first Vs and Va check, the result indicated to replace the power supply board, then the troubleshooting sequence continues(if not fixed by the new board) to check and replace (possibly) x, y, logic boards. Since I don't have the boards readily available, it could be very drawn out and expensive.
    The manual did indicate that the buffer boards E and F (the warped board) are removable, so I may remove them and do a component and solder joint check.
    Peter
    replied
    What are the symptoms of a failed buffer board- before I attempt to remove it?
    Peter
    An X buffer failure often leads to a loss of picture in certain columns or across the whole screen. Your symptoms do match a failed X buffer and finding a bent board seems to suggest this is a probable cause.
    However - the X buffers are most likely soldered to the panel ribbons. They are not removable because of this. Any repair you do can only really consist of touching up joints on these boards or replacing failed components, as they are not replaceable.
  • Tweek4
    replied
    Peter
    replied
    On most Samsungs, a failed X board means the panel is useless. It MAY be possible to repair it, more than likely you've just got a cold joint - but if some traces are broken internally, then it's pretty much impossible...
  • netdent
    replied
    Thanks. Ronnie
    There are quite a few boards on ebay - if I decide to go that route.
    I'm grasping at straws right now.
    I don't know if this pertinent, but one of the buffer boards is quite warped - see the attached pics and the components are touching the aluminum shield or heat sink.
    I noticed it when I removed the bracket that secures the stand.
    Peter
    Pictures wouldn't upload
    Hmm! if one of those is stuffed it's curtains, if I remember right the ribbons are permanantly attached to the plasma screen
  • Tweek4
    replied
    Thanks for the link - I'll check it out.
    Peter
  • Tweek4
    replied
    Peter
  • Tweek4
    replied
    Thanks. Ronnie
    Peter
  • rmoody
    replied
    Here's a good service manual that might help if you haven't read it yet. Kind of hard to see but you can upload another document and download a pdf of it for free.
    http://www.scribd.com/doc/34870662/S...sma-Pn42a450p1
  • netdent
    replied
    I think I scrapped one of these sets that had a bad panel, not damaged just had a black line otherwise it worked well, just in case you get stuck for a board
    thanks Ronnie
  • Tweek4
    replied
    Next step - I 'm thinking of trying another main board. Is that a likely or unlikely candidate for failure?
    Peter
  • Tweek4
    replied
    Replaced the logic-main board. No change.
    I am scrutinizing every board for a sign of overheating or poor connection. Nothing found.
    It's hard to believe that this failure occurred without making any snap, crackle or pop of any sort.
    Peter
  • Tweek4
    replied
    Tom66...
    Since you think the logic board may be faulty - that's the first place I will start.
    Board purchased. Will report back when installed.
    Peter
  • Tweek4
    replied
    5.34v both sides
    replied
    It checks OK in circuit
    What are the voltages on both sides of the fuse?
  • Tweek4
    replied
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
  • Chrissygizmo
    samsung galaxy ao2s very temperamental after screen replaced
    by Chrissygizmo
    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
    Ive eventually managed to get it on and working but it's very temperamental...
    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
    05-26-2024, 12:05 AM
  • Kiberge
    Samsung LH82QENELGC/EN Help needed - Static line on screen
    by Kiberge
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
    04-22-2024, 11:28 AM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
  • Bloopeta
    Samsung UE55JU6800K No Picture
    by Bloopeta
    Samsung UE55JU6800K with no image on screen.
    I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
    Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
    I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
    Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
    05-03-2024, 10:42 AM
