Samsung 50" plasma blank screen
    replied
    Re: Samsung 50" plasma blank screen
    Originally posted by Tweek4
    I had similar thoughts. However the manual is a little confusing, as follows:
    The diagram in the manual(photo,actually), shows the cable from the smps board to the main board to be disconnected quite clearly, but the socket number given is the adjacent connection which goes to the logic-main board. I disconnected that one after reconnecting the main board and I read zero volts. So.......???
    Peter
    I'm not sure. But the fact that you have some kind of display (even if just dimly lit) probably means that the power supply is okay. I have no idea if the manual is correct but it doesn't seem right.
  • Tweek4
    replied
    Peter
    replied
    To elaborate on my previous post, the first step in the manual for troubleshooting no video with audio is to disconnect the cables going between the power supply board(smps)
    and y, x and main boards and check if Vs and Va are normal.
    First, I disconnected all three boards and Vs and Va measured zero.
    Then I reconnected the main board only and Vs and Va measured normal(207v and 56v).
    According to the manual the smps board needs to be changed.
    Does this sound reasonable
    No... The voltages are only present when the main board tells the power supply to switch on. As Vs/Va are present, SMPS is most likely okay.
  • Tweek4
    replied
  • Tweek4
    replied
    Thanks for the help.
    I read the manual linked in post#42 and started the checks for no picture, and after the first Vs and Va check, the result indicated to replace the power supply board, then the troubleshooting sequence continues(if not fixed by the new board) to check and replace (possibly) x, y, logic boards. Since I don't have the boards readily available, it could be very drawn out and expensive.
    The manual did indicate that the buffer boards E and F (the warped board) are removable, so I may remove them and do a component and solder joint check.
    Peter
    replied
    What are the symptoms of a failed buffer board- before I attempt to remove it?
    Peter
    An X buffer failure often leads to a loss of picture in certain columns or across the whole screen. Your symptoms do match a failed X buffer and finding a bent board seems to suggest this is a probable cause.
    However - the X buffers are most likely soldered to the panel ribbons. They are not removable because of this. Any repair you do can only really consist of touching up joints on these boards or replacing failed components, as they are not replaceable.
  • Tweek4
    replied
    Peter
    replied
    On most Samsungs, a failed X board means the panel is useless. It MAY be possible to repair it, more than likely you've just got a cold joint - but if some traces are broken internally, then it's pretty much impossible...
  • netdent
    replied
    Thanks. Ronnie
    There are quite a few boards on ebay - if I decide to go that route.
    I'm grasping at straws right now.
    I don't know if this pertinent, but one of the buffer boards is quite warped - see the attached pics and the components are touching the aluminum shield or heat sink.
    I noticed it when I removed the bracket that secures the stand.
    Peter
    Pictures wouldn't upload
    Hmm! if one of those is stuffed it's curtains, if I remember right the ribbons are permanantly attached to the plasma screen
  • Tweek4
    replied
    Thanks for the link - I'll check it out.
    Peter
  • Tweek4
    replied
    Peter
  • Tweek4
    replied
    Thanks. Ronnie
    Peter
  • rmoody
    replied
    Here's a good service manual that might help if you haven't read it yet. Kind of hard to see but you can upload another document and download a pdf of it for free.
    http://www.scribd.com/doc/34870662/S...sma-Pn42a450p1
  • netdent
    replied
    I think I scrapped one of these sets that had a bad panel, not damaged just had a black line otherwise it worked well, just in case you get stuck for a board
    thanks Ronnie
  • Tweek4
    replied
    Next step - I 'm thinking of trying another main board. Is that a likely or unlikely candidate for failure?
    Peter
  • Tweek4
    replied
    Replaced the logic-main board. No change.
    I am scrutinizing every board for a sign of overheating or poor connection. Nothing found.
    It's hard to believe that this failure occurred without making any snap, crackle or pop of any sort.
    Peter
  • Tweek4
    replied
    Tom66...
    Since you think the logic board may be faulty - that's the first place I will start.
    Board purchased. Will report back when installed.
    Peter
  • Tweek4
    replied
    5.34v both sides
    replied
    It checks OK in circuit
    What are the voltages on both sides of the fuse?
  • Tweek4
    replied
