A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
Re: A guide to fixing/troubleshooting some common plasma TV problems
It is most likely a loose X-driver connector, or, sometimes the panel is bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I have a 47 inch Panasonic Plasma TV that has lost the Yellow in the picture. I tried to adjust the color but I can not restore the Yellow. Have you heard about this problem and is there a quick fix? The TV is 7 years old. with no other problems. Thanks!Comment
47 inch is not a plasma, sounds like DLP or LCoS, maybe LCD... but not heard of that before. How about creating a new thread with the model number, detailed problem description, and pictures of the set's guts and one of the problem itself.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Thanks Tom, this is by far the best plasma troubleshooting guide I have found online.
I have a 60" LG Plasma (60pv250), a few months out of the 1-year warranty, and about 50% of the time I turn the unit on it boots up with no picture only sound, and it responds normally to the remote. I have tried hitting the back of the TV with no effect. But often turning it off and back on once or twice regains the picture. The picture never cuts out once its on.
From what I read in your guide these symptoms would be the Y-sus? The only thing that throws me off is the intermittent factor to this issue. It would obviously be the board acting up if this was the case and the fuse must be fine. I haven't pulled the back of the TV off yet but just wanted to be sure I should look at the Y-sus board.
Any help appreciated!
PS. I apologize if this question has already been asked, I did read through the entire forum.Comment
You'd be best starting your own thread, but it sounds more like a main or control board problem. Check in a dark room if the screen glows slightly (it may be quite dim) when it is malfunctioning.
If you are persistent with LG though they will often repair if a few months out of warranty.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hi Tom, got a Panasonic TC-P65S2 that developed a full height 3" vert. bar about 1/3 of the way in from right edge. Bar characteristics are difficult to describe, but suffice it to say that it's most visible on a black screen, say when changing inputs when screen momentarily black. During normal operation most of the bar is fairly unnoticable except for a slight change in color values, the exception being the far right edge of the bar which is a quite noticeably 1-2 mm thin stripe, usually reddish but changes depending upon what's dispalyed on the screen, sometimes nearly invisible. Most noticeable when displaying a darker object (Face, car, etc.) near the bar when the background is light (sky, white room, etc.) Upon close inspection the majority of the bar's distortion is caused by very, very thin dark lines evenly spaced at 1-3 mm. Only other characteristic is that there seems to be a horizontal component to the bar in that at times (depending on what's being displayed at any given moment) the bar seems to be comprised of a series of rectangles of maybe 1.25-1.5" in height, so it looks like a stack of blocks. Again, these "blocks," like the entire bar, it only really discernible as a value distortion, or "difference" from the rest of the display. Does that make any sense? Pretty sure it's the PDP (seems to be the concensus) Read thru forum and found some similar, but not identical, threads. Thought I'd run it past you. Thanx for your time and patience Tom.
PS. Sent a PM regarding SM (EDIT: apparently I didn't as I can't find a PM function yet. Am I too new? Anyway, love it if you'd PM me so I can reply)Last edited by snaxforgandhi; 04-10-2013, 10:27 AM.Comment
I'd recommend you post a new thread, and supply pictures of the defect. I've heard of this problem before, it often turns out to be a loose connector. I would be surprised if it is the panel (tab driver) with that kind of defect, as the tab driver itself only deals with digital data. It can't make pixels vary in brightness, unless some of the data it receives is wrong or corrupt.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I'll do that Tom. Thanx so much. Still like to PM you about an SM for this unit when I am able.Comment
Problems with an LG DU-60PY10
Just found this forum and hoping for advice/help. Our LG plasma has seemingly lost the ability to render subtle color variations when they are located close together. The effect is some what like a solarized photo, and I have included several Iphone photos which hopefully will illustrate the problem. Any assistance/advice is most appreciated.Comment
Looks like there may be a loose LVDS cable or a main board/control board malfunction.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: LG DU-60PY10 problems.
I unplugged the unit and and essentially did a reboot, which seems to have corrected the problem for the time being. I'm assuming that is and of itself indicative of what the problem might be.Comment
Really a good guide, while searching solutions on my Samsung plasma TV problem, google directed me here.:-)
Just started a new thread on my 50" Samsung Plasma TV issue and hope to get any help here. Thanks.Comment
LG 50pg25 power on and off after a couple of seconds.
This is best troubleshooting thread on line.
Tom,
I have lg 50pg25 will shut off from a couple of seconds to a couple of minutes after turn on. Every thing looks great when is on. What could be the problem?
Thanks in advance.Comment
Your problem is quite likely a cold solder joint on the power supply somewhere.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Looks just like flux to me -- not a fault.
What you need to do is find out where the fault is as it is heat related (as set warms up the fault occurs.)
So use a hairdryer or other heat-producing device and heat up parts one by one, and see if you can make the problem occur much quicker.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by stecosHi everyone!
For my passion for technology I'm now collecting several... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
