A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
+ More Options
Posts
  • Luke1147
    • Feb 2013
    #81
    Re: A guide to fixing/troubleshooting some common plasma TV problems
    Originally posted by tom66
    I've considered using the new 50" Panasonic to show how I diagnose a fault on a plasma. But I've covered most of the main faults with plasma TVs. Power supply faults belong in a more general thread (usually covering both plasma and LCD), but there are -so many- to list.
    Great guide Tom
    Have you had any problems with a 2-3 inch blurry/ grainy line down the left hand side of a pioneer tx-p50g10b.
    Any help would be much appreciated
      Originally posted by Luke1147
      Great guide Tom
      That would be a Panasonic.
      It is most likely a loose X-driver connector, or, sometimes the panel is bad.
      • Stacha
        • Feb 2013
        • US
        #83
        I have a 47 inch Panasonic Plasma TV that has lost the Yellow in the picture. I tried to adjust the color but I can not restore the Yellow. Have you heard about this problem and is there a quick fix? The TV is 7 years old. with no other problems. Thanks!
          47 inch is not a plasma, sounds like DLP or LCoS, maybe LCD... but not heard of that before. How about creating a new thread with the model number, detailed problem description, and pictures of the set's guts and one of the problem itself.
          • Rakanishu
            The Doombringer
            • Feb 2013
            Thanks Tom, this is by far the best plasma troubleshooting guide I have found online.
            I have a 60" LG Plasma (60pv250), a few months out of the 1-year warranty, and about 50% of the time I turn the unit on it boots up with no picture only sound, and it responds normally to the remote. I have tried hitting the back of the TV with no effect. But often turning it off and back on once or twice regains the picture. The picture never cuts out once its on.
            From what I read in your guide these symptoms would be the Y-sus? The only thing that throws me off is the intermittent factor to this issue. It would obviously be the board acting up if this was the case and the fuse must be fine. I haven't pulled the back of the TV off yet but just wanted to be sure I should look at the Y-sus board.
            Any help appreciated!
            PS. I apologize if this question has already been asked, I did read through the entire forum.
              You'd be best starting your own thread, but it sounds more like a main or control board problem. Check in a dark room if the screen glows slightly (it may be quite dim) when it is malfunctioning.
              If you are persistent with LG though they will often repair if a few months out of warranty.
              • snaxforgandhi
                • Apr 2013
                Hi Tom, got a Panasonic TC-P65S2 that developed a full height 3" vert. bar about 1/3 of the way in from right edge. Bar characteristics are difficult to describe, but suffice it to say that it's most visible on a black screen, say when changing inputs when screen momentarily black. During normal operation most of the bar is fairly unnoticable except for a slight change in color values, the exception being the far right edge of the bar which is a quite noticeably 1-2 mm thin stripe, usually reddish but changes depending upon what's dispalyed on the screen, sometimes nearly invisible. Most noticeable when displaying a darker object (Face, car, etc.) near the bar when the background is light (sky, white room, etc.) Upon close inspection the majority of the bar's distortion is caused by very, very thin dark lines evenly spaced at 1-3 mm. Only other characteristic is that there seems to be a horizontal component to the bar in that at times (depending on what's being displayed at any given moment) the bar seems to be comprised of a series of rectangles of maybe 1.25-1.5" in height, so it looks like a stack of blocks. Again, these "blocks," like the entire bar, it only really discernible as a value distortion, or "difference" from the rest of the display. Does that make any sense? Pretty sure it's the PDP (seems to be the concensus) Read thru forum and found some similar, but not identical, threads. Thought I'd run it past you. Thanx for your time and patience Tom.
                PS. Sent a PM regarding SM (EDIT: apparently I didn't as I can't find a PM function yet. Am I too new? Anyway, love it if you'd PM me so I can reply)
                  I'd recommend you post a new thread, and supply pictures of the defect. I've heard of this problem before, it often turns out to be a loose connector. I would be surprised if it is the panel (tab driver) with that kind of defect, as the tab driver itself only deals with digital data. It can't make pixels vary in brightness, unless some of the data it receives is wrong or corrupt.
                  • snaxforgandhi
                    • Apr 2013
                    I'll do that Tom. Thanx so much. Still like to PM you about an SM for this unit when I am able.
                    • Bluemoonfever
                      • Apr 2013
                      Problems with an LG DU-60PY10
                      Just found this forum and hoping for advice/help. Our LG plasma has seemingly lost the ability to render subtle color variations when they are located close together. The effect is some what like a solarized photo, and I have included several Iphone photos which hopefully will illustrate the problem. Any assistance/advice is most appreciated.
                      • Bluemoonfever
                        • Apr 2013
                        Re: LG DU-60PY10 problems.
                        This is a follow-up of my post regarding the faulty LG DU-60PY10. I inadvertantly posted the incorrect photos regarding the problem. These show the "solarized"effect I referred to. Thankyou.
                          Looks like there may be a loose LVDS cable or a main board/control board malfunction.
                          • Bluemoonfever
                            • Apr 2013
                            I unplugged the unit and and essentially did a reboot, which seems to have corrected the problem for the time being. I'm assuming that is and of itself indicative of what the problem might be.
                            • sangdy
                              • Apr 2013
                              • 34
                              Really a good guide, while searching solutions on my Samsung plasma TV problem, google directed me here.:-)
                              Just started a new thread on my 50" Samsung Plasma TV issue and hope to get any help here. Thanks.
                              • jimmyking
                                • Sep 2008
                                • 32
                                #95
                                LG 50pg25 power on and off after a couple of seconds.
                                This is best troubleshooting thread on line.
                                Tom,
                                I have lg 50pg25 will shut off from a couple of seconds to a couple of minutes after turn on. Every thing looks great when is on. What could be the problem?
                                Thanks in advance.
                                  Your problem is quite likely a cold solder joint on the power supply somewhere.
                                  • jimmyking
                                    • Sep 2008
                                    • 32
                                    #97
                                    Looks like these resistors have been burned. Can it be fixed? If so where can I buy them?
                                      Looks just like flux to me -- not a fault.
                                      What you need to do is find out where the fault is as it is heat related (as set warms up the fault occurs.)
                                      So use a hairdryer or other heat-producing device and heat up parts one by one, and see if you can make the problem occur much quicker.
                                      • jimmyking
                                        • Sep 2008
                                        • 32
                                        #99
                                        This is more clear picture.
                                        • jimmyking
                                          • Sep 2008
                                          • 32
                                          #100
                                          Here is front end. Those resistors are located between PC801 and U902 in the back. I really don't know much about this thing. Please help.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
