Was It a Mistake to Buy a Vizio P4 for $10?
    It says May 2003 on the back, so it's clearly an older model.
    I figured there was a slim chance this was an easy cap and
    fuse fixer-upper, and if not, I could sell the parts on Ebay. But
    the problem is I didn't see many listings for the Vizio P4, but that
    could mean simply less competition when I do list the boards. I'm
    not sure what the market demand for this model is, but there wasn't
    too much info on the archives here or anywhere else on the internet,
    so I figure I may have blown $10. OTOH, as soon as I sell just one
    board off this guy, I'll think it was worth it! The Ebay market DOES
    amaze me sometimes!
    Ok, here are some pics:
    At first, the relays clicked when turned on, and the LED on
    the main board turned on and stayed on with the relay click.
    But totally black picture, and no sound from speakers.
    The 2nd pic is the Y-sustain, and I measured:
    Vcc = 5V
    Vf = 14-15V
    VW = 0.3 V
    Vs = 4 V
    And the same on the X-board, but
    with:
    Vxg = 0
    The panel says: VsSET=173, VxgSET=160, so it
    looks like the Vs and Vxg are totally off.
    Then, after playing around for a few minutes, the
    LED on the main and the relay began to shut off automatically
    after about 3 seconds. During the 3 seconds, there
    is sometimes a faint arcing noise, and the lights
    in my house dim just barely, so it's clearly
    some sort of crowbar, current-limiting protection
    scheme that shuts off the relay. Also, the relay
    will turn off even when the Y-sus and X-main
    main cables are disconnected from the power supply.
    But it's intermittent, and sometimes I can get
    the LED and relays to stay on.
    So it looks like a bad power supply to me, but
    I'd like to know what you guys think. Like how
    should I test to make sure that the buffers and
    Y-sustain and X-main are still good?
    I found this one:
    http://www.ebay.com/itm/Gateway-GTW-...item1e69ec5498
    And added it to my watch list.....
    Thanks for any advice.....
    Re: Was It a Mistake to Buy a Vizio P4 for $10?
    It's a WVGA panel - 852x480 pixels - not even HD. You'd be lucky if it sells for more than $30 working.
      Obviously I should have done some more research on this one.
      I got desperate to crack open a tv, ANY tv!
      Do you think the parts are worth anything on Ebay? Or is this mainly
      scrape metal?
        scrape metal?
        Maybe, list them for 99p plus shipping, it's free. Or keep it as a test TV. Try to get it working, then play with the setup/setdn timing and Vs/Va/Vset/etc. voltages, to see what it does - it should do similar things to other newer TVs so useful for testing ideas on. Try probing the drive waveform with a scope (10X probe & 400V rated only, though.)
          Ok, so based on the info in my first post, do you
          agree that this may be a power supply issue?
          On the Magnavox 42MF231D/37, when the Y-sus
          was disconnected (no-load), the Vs was still
          +200 V or so. Shouldn't Vs=+173V and Vxg=+160V
          in this case?
          There aren't any obvious bulged caps or burned components
          on the top of the PS, but as everyone knows, looks can be deceiving.
          This stuff is addictive, no doubt.....
            What about other supply voltages? The Vs/Va are switched, they don't come up in standby mode.
              Again, for the other voltages I measured:
              Vcc = 5V
              Vf = 14-15V
              VW = 0.3 V
              Not sure what the VW is, but it's certainly appears too low.
              On the Magnavox 42MF231D/37, the Vs and Va were there
              pretty much all the time. Don't you need these voltages
              just to put the menu on the screen?
              Additionally, there is a 2 pronged connector labeled DC
              with the (-) side labeled VAUX. The (+) measures
              around +250V, and the (-) side measures -65V or so.
              These go to the skinny audio board at the top of
              the first picture. Don't know if these are the
              normal voltages.....but doesn't +250V seem high
              for an audio board?
                Vcc = 5V
                Vf = 14-15V
                VW = 0.3 V
                for an audio board?
                Check for bad diodes in the Vs/Va supply; check the PFC is working and also check the auxillary rails (e.g. 5V, 3.3V) are there - the ones going to the main board.
                  And if you're really bored...
                  http://www.youtube.com/watch?v=HxNd97PIar0
