Samsung 42" plasma fault
  • the79bomb
    • Dec 2011
    • 11
    I have model pn42a400c2dxza
    It comes on for just over a second and the relay cuts off power (Still have 5v on standby pin). For that 1 second the screen looks off (see screenshot)
    Unplugging the power cable to all of the boards has no effect except when unplugging the board with a/v inputs (main board) in which case it does not turn on at all.
    It appears there is an overload somewhere. The cable from the central board to the board with the a/v inputs (main board) was damaged when I got the unit so some of the pins might have shorted. I have repaired the cable but this has not resolved the issue. It might be that there was originally 1 thing wrong with the tv (off picture) but while messing around someone damaged the aforementioned cable and caused the 2nd problem (power overload).
    Would anyone be able to instruct me how to diagnose for sure which components need replacing?
    thanks for any help.
    Re: Samsung 42" plasma fault
    Looks like a power connector isn't plugged in.
    Failing that... unplug X-main, does problem remain? Then plug X-main back in and unplug Y-main? Does problem remain?
    • the79bomb
      • Dec 2011
      • 11
      Thanks for the reply. I have tried unplugging each board. both x & y mains as well and the problem remains. the only change is when I unplug the main board and then nothing happens. I just hate to pay for a main board and have that not be the problem or not be the only problem. That is why I wanted to be sure.
      Thanks, Tim
        Thanks, Tim
        Can you post a close up picture of the power connector going from the power supply to the logic card?
        • the79bomb
          • Dec 2011
          • 11
          Thanks for the response. I have attached a better picture of the connector to the main logic board from the power supply as well as a clearer picture of the overall system with enough res to zoom in. I have tried starting the system with virtually every combination of power cables plugged in/unplugged with no change - system clicks off after 1 second unless the main board is unplugged in which case nothing.
          Thanks, Tim
            Can you post a clearer picture so I can read the legends on those connectors?
            • the79bomb
              • Dec 2011
              • 11
              my camera will not focus closer. no macro mode on my camera for taking close up shots. The codes on the connectors are as follows from left to right:
              stby,vs-on,n c,ps-on,rtn,5. 3v, rtn, rtn,5.3v,5.3v
              all "5.3v" pins have 5v for the 1 second but then 0 after the relay clicks off. "Stby" has 5v throughout. However ps-on has 0v with relay closed and then 3.3 when it clicks open. This is with the connector unplugged as pictured meaning that something on the main board is causing the relay to open as it is the only board plugged in to the power supply board - see picture.
              Thanks, Tim
                5V, or 5.3V? Many of these Samsungs depend on that 0.3V.
                • the79bomb
                  • Dec 2011
                  • 11
                  I read 5v but now I'll double check it and let you know.
                  • the79bomb
                    • Dec 2011
                    • 11
                    The standby pin has 5 volts and the 5.3 do indeed have 5.3 volts for a second. My volt meter takes a second to get the reading so it was hard to get a stable reading but it is 5.3 volts.
                      Okay. Disconnect Y and X sustains as well as their control connectors, then try again. You should get no picture but if it stays on you have a problem with a sustain board.
                      • the79bomb
                        • Dec 2011
                        • 11
                        there is no picture but the power still clicks off after 1 second
                          Do you have a pin-out for the power connector. Is there a pin called PSON or ON/OFF?
                          • the79bomb
                            • Dec 2011
                            • 11
                            There are no pins on the power board. It seems to me that there is some overload in the main board causing power to shut off after 1 second. I was unable to find any jumper pins on the main board either. The main logic has 4 but there is no jumper present but it cannot be the source of the problem as it is unplugged.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Miscommunication. The second picture in your first post shows an over-all view of the TV. A cable runs from a connector in the lower right corner of the power supply to the main board. Frequently the manufacturer will identify the function of each pin of that connector. That information is very useful when troubleshooting.
                              PlainBill
                              • the79bomb
                                • Dec 2011
                                • 11
                                Thank you for clearing that up. The pins are as follows:
                                Fan On (0V)- NC
                                D13v(.3v) - D13v(.3v)
                                D13v(.3v) - RTN
                                RTN - RTN
                                5.3 (0v) - 5.3 (0v)
                                5.3 (0v) - 5.3 (0v)
                                RTN - RTN
                                RTN - RTN
                                13 VAMP (.3V) - 13 VAMP (.3V)
                                RTN - RTN
                                STDBY (5V) - RTN
                                PSON (4.1V) - NC
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Hi- I have located a wiring diagram? for BN44-00206A which I believe is the power board for this tv. It has detail of the connectors.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Whoops missed the edit cut off so its a new line sorry.
                                    I have also found a trouble shooting guide which may help at some point.
                                    Though I expect you already have it?
                                    FORGET THAT - Wrong Model though possibly same power supply
                                    • ohren
                                      by ohren
                                      09-08-2023, 05:24 PM
                                    • Rictech
                                      Panasonic SA-MAX770PU SMPSU board fault....
                                      by Rictech
                                      Hello everyone. 😀
                                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                      There are no devices that have exploded or otherwise show signs...
                                      08-26-2024, 01:05 AM
                                      09-07-2024, 05:50 AM
                                    • Nicktronic
                                      Samsung Power Supply Board BN44-00874F
                                      by Nicktronic
                                      Hey everyone,
                                      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                      Anybody...
                                      03-17-2025, 06:20 AM
                                    • spleenharvester
                                      Tower T548006 battery, fault on BMS board
                                      by spleenharvester
                                      I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
                                      10-04-2025, 06:33 AM
