26 lg lcd tv no audio no video
lg tv
Tags: None
Re: lg tv
I can only guess that you have posted this in error and it has lost the detail.
or you have scored an own goal.
If you expect any sort of help you need to read the forum rules and I suggest you
read some of the existing threads to see the detail you will have to provide to get
some assistance.
Based on what you have given
1 Do you have power
2 Is the set plugged in
3 Have you checked the power fuse
4Was the set working for you previouslyPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
by bpjlHi,
We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...03-16-2025, 09:26 AM -
by NicktronicOk, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
So, backlights, no video, go! 🙂...06-03-2024, 03:21 PM -
by battery.12vHello guys, Asus G512LI, came with 3.3V drop down immediately .... 5V was stable ... after search and work found that +3VSUS_MUX is the issue (caused by U4701A TUSB1146RNQR) , left off the ic .. 3.3V came up again stable ... after power on laptop turn on for 3 seconds and power off ... VCCcore raise 0.9V for 1.5 seconds and drop down all other voltages do same thing ... Ram voltage , Gpu voltages, concerning VCCGT 0V all the time05-03-2024, 03:43 AM
by EBWWestinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...10-27-2022, 06:32 PM
by SevilleHello all!
Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next.... - Loading...
