42inch Touch Screen wont power on
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: 42inch Touch Screen wont power on
    Originally posted by tom66
    Yes, the white stuff is the thermal paste. If the paste isn't smudged, then you might not need some more paste, but I'd recommend it anyway. Here is something that will work: http://www.ebay.co.uk/itm/CPU-Therma...item3f10fcf53e
    Get two or three, as one of those tubes doesn't last long.
    2x 1g http://cgi.ebay.co.uk/120816306484
    5x 1g http://cgi.ebay.co.uk/110558339447
    ^ both from the UK instead of china. saves time.
    edit: uhm.. i don't know where epicfatigue is from, so ignore this if it isn't UK.
    • epicfatigue
      • Dec 2011
      • 68
      #62
      Hey guys sorry i should say alittle about myself
      I am From Australia, hence my funny hours.
      I am a AMI Security Administrator for the Smart Meter Grid (so dont hate me lol)
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        Originally posted by epicfatigue
        open .0L closed 0 volts ? is that right shouldnt it read the voltage of the battery?
        and yes lol it is .0L i am reading sorry guys
        0V is 0.0 (zero point zero).
        0L is "out of range", "infinity".
        The two are polar opposites.
        --- begin sig file ---
        --- end sig file ---
        • epicfatigue
          • Dec 2011
          • 68
          #64
          checked all the diodes, they all worked they tested .194v however one tested .094 across both pins, could this be the problem?
          Where should i check now?
            Remove the one that tested .094 across both pins and re-test it; if it still tests .094 across both pins you've found a faulty diode . A faulty diode will prevent the power supply's primary side from starting properly.
            • epicfatigue
              • Dec 2011
              • 68
              #66
              awesome gunna go get one in a hour or so, now these generally die from overvoltage ? could i have a possible bad resistor or could it be that when they all died a power surge caused this to overvolt?
              Just wondering if i should check otherthings incase it blows another?
                These diodes die from temperature and sustained load. If the TV is, for example, mounted on a wall and used 24/7, the diode will succumb to the high temperatures (was it used in a business environment, for example as an advertisement display?) I wouldn't think any other component could cause the problem, but get two or three just in case. If it blows again, we'll need to look at the power supply more closely.
                • epicfatigue
                  • Dec 2011
                  • 68
                  #68
                  Well i turned it on hoped for the best and same clicking noise from relay no power where now?
                  • epicfatigue
                    • Dec 2011
                    • 68
                    #69
                    i replaced the under preforming diode and still the same problem presists
                    However i checked the part i was sold and they are different,
                    Original was 60v 30amps
                    Replacement is 100V 20Amps
                    Guessing the problem could still be the diode ?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #70
                      1) Did you test the diode BEFORE putting on the board?
                      2) Does it test shorted on the board?
                      3) Remeasure all the diodes on the board to see if any are shorted since the installation?
                      • epicfatigue
                        • Dec 2011
                        • 68
                        #71
                        Yes i did before i put it in, it measured a higher voltage .264 compared to the others....
                        in highns sight i shouldnt have whacked it in but the guy told me there was no diffirence and since he had a double degree i believed him.
                        I will test all the diodes and see which one failed if one did.
                        If they all test fine should i try and find the same voltage / ampage diode ? and where should we go next if they all test fine?
                        So i can do more then 1 step.
                        Thanks again for your presistance
                          The diode you used as a replacement should be okay, I doubt any rail is drawing more than 20A on that power supply.
                          .264 both ways, or just one way? This is important. If it measures both ways, then the diode has failed.
                          • epicfatigue
                            • Dec 2011
                            • 68
                            #73
                            they both measure 0.255 from either side but the block how they should i got 2 of them they operate like that.
                            the originals put out .192 execpt for one that was .099
                            is it possible they are all faulty?
                              All faulty would be very rare. Let's be sure you are testing them the right way. What mode do you have your multimeter on? Post a picture of it in that range.
                              • epicfatigue
                                • Dec 2011
                                • 68
                                #75
                                They all tested fine whats next?
                                red to pin 1 black to pin 2 .2XX
                                black to pin 1 red to pin to nothing
                                as diode only lets its pass one way its okay i am checking them right,
                                whats cahnces of it being the transformer?
                                  Transformer would be rare. Did you test the failed diode you removed?
                                  • epicfatigue
                                    • Dec 2011
                                    • 68
                                    #77
                                    Yes as stated above it till functioned as the others but in diode test it pased a much lower voltage it pasted .099 where the others passed as stated above in post #73
                                    the method of testing is done as follows
                                    1-2 Voltage (Red Pin 1 Black Pin 2)
                                    2-1 OL (Black Pin 1 Red Pin 2)
                                    2-3 OL (Red Pin 2 Black Pin 3)
                                    3-2 Voltage (Black Pin 2 Red Pin 3)
                                    3-1 OL
                                    1-3 OL
                                      3-1 OL
                                      1-3 OL
                                      That is the correct way to test it. That's a very strange diode though - .099 would be extremely efficient. What is the part # on it?
                                      • epicfatigue
                                        • Dec 2011
                                        • 68
                                        #79
                                        New Part 838 MBR20100CT .225 (i got 2 of these both tested the same)
                                        ORIGINAL B156N F30FC6 (the .099 one) Most were ranged between .198 - .178
                                          Okay, let's take a different angle of attack. Replace the diode with the new one. Post a picture of the connector going from the PSU to the main board.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. šŸ˜…
                                            05-29-2024, 02:01 PM
                                          • AJ847.63e
                                            HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
                                            by AJ847.63e
                                            Hi All,
                                            We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
                                            Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
                                            I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
                                            04-04-2024, 05:29 PM
                                          • hotgly
                                            Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
                                            by hotgly
                                            After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
                                            The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
                                            I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
                                            Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
                                            Serial number: 0F00S2Y22353BF
                                            Intel(R) ME Code Versions:
                                            BIOS Version 12.200.143
                                            MEI Driver...
                                            05-15-2024, 02:20 PM
                                          • Yehuda170
                                            ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                            by Yehuda170
                                            original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                            replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                            now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                            with original broken screen i can see in device manager touch screen in human interfaces
                                            but with the new screen it's not showing in device manager
                                            is it lenovo blocking it? is it driver missing?
                                            I²C is a headache
                                            07-14-2023, 01:29 AM
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
