Samsung 59" Plasma 3D Blank Screen
  • graham01
    • Oct 2011
    • 92
    Hi everyone, I have a Samsung PS59D550 and the screen has died, when its turns on there is a quick flicker of white on the screen and then it just goes blank, also it cannot be turned off once it is on. The buttons on the TV can be used to turn it on but then there is no response from them once on, and the red light flashes to signal it is picking up the remote signal but it doesn't have any effect never mind how long you keep the power button pressed for.. any ideas please? Would really appreciate any help!
    Regards,
    Graham
    Re: Samsung 59" Plasma 3D Blank Screen
    That sounds a lot like a bad Z-sustain. You'll have to open up the TV and take pictures so everyone here knows what they are dealing with.
    • graham01
      • Oct 2011
      • 92
      Hi there, thank you for your reply but I think I just identified the problem to be a faulty tuner board (the buttons not responding gave it away) but I just tore apart my PS51C7000, put them back to back, connected the LVDS from the Tuner BD in the 51 to the 59, turned them both on and wollah! got an image on the 59
      I don't really recommend this to anyone though.. it was dangerous and scary!
        Strange - the LED flashing would usually eliminate the tuner board, but maybe the LED flashing is controlled by the button board? Anyway, it looks like you have found your problem. LVDS would not always be compatible especially for 3D TV as the refresh rate is higher.
        • graham01
          • Oct 2011
          • 92
          It is almost like the tuner board is stuck trying to turn on.. when the TV is turned on (either by the remote or tv buttons), the LED flashes but just keeps flashing until something else is pressed. The TV buttons are unresponsive, but pressing the remote buttons, although not doing anything, makes the LED flash. The only way to turn the TV off is to unplug it from the mains. Is there a way to hard reset the board? I have tried holding the exit button for 10 seconds, pressing left, then enter, which should be the correct steps to perform a hard reset although obviously I can't see the options on the screen. I am aware old models, the R8 and M8 series, if the eeprom gets corrupt it can be reset by shorting out some pins on it, but by the looks of it there is no eeprom on the newer models..
          I am slightly worried as i am having trouble sourcing a new tuner board, I have found a few for sale in america, but I am assuming TV areal are a bit different to UK? Looking at the pictures, the big silver block on the areal socket is smaller than the one on mine, so is it a different adapter?
          Many thanks for your help,
          Regards
            Regards
            eBay is a good source for boards.
            Try MUTE-MENU-POWER to get to a service menu.
            • graham01
              • Oct 2011
              • 92
              Hi again, yes I have just tried that - no use. The board just doesn't seem to exist anywhere in the UK, it is a BN41-01605A. After a bit of revision it seems I can use an adapter to connect the american threaded coaxial to ours, but what about the software? Will it have Freeview HD??
              Regards
              • retiredcaps
                • Apr 2010
                • 9271
                Not under warranty?
                --- begin sig file ---
                --- end sig file ---
                • graham01
                  • Oct 2011
                  • 92
                  Probably not any more lol
                    Regards
                    Most Samsungs I have seen can be configured to have different settings like Freeview (HD) - but maybe the connector is for satellite? In which case it won't work. Also, the case of the TV may not fit.
                    It might be possible to repair the board.
                    • graham01
                      • Oct 2011
                      • 92
                      Hi Tom, thanks, how do you think I can repair it?
                      Regards
                        Regards
                        Post a close up picture of the board; I'll highlight some places to make tests.
                        • graham01
                          • Oct 2011
                          • 92
                          hope this is okay
                          regards
                            I need one looking from the top. It's difficult to locate components side-on.
                            • graham01
                              • Oct 2011
                              • 92
                              Thanks Tom, it would be great if I could repair it
                                It would be nice to get a higher resolution (2000x1500 ), but here are some basic tests.
                                RED circled regulators: Check the voltage on each pin (except the middle pin) relative to the metal case of the TV. Do this while TV is trying to turn on. Record the voltages and the part number on each regulator.
                                Heatsinked processor: Does it get warm? (leave to warm up for 10 minutes)
                                Processor with metal pad: Does it get warm? (leave to warm up for 10 minutes)
                                If I had a higher resolution, I would be able to highlight other potential failed components, such as diodes.
                                • graham01
                                  • Oct 2011
                                  • 92
                                  tom, thank you very much for your help, I will do this now.. I apologize for the poor image quality, it is strange, on the image I took you can even zoom in and read the part numbers on the board.. how should I upload it?
                                  Regards
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    The site resizes so you have to compensate by starting with a bigger pic.
                                    Closer would be good too if you can keep it in focus.
                                    Go Advanced [down below] then under the text box in the next screen there is an app [Manage Attachments] you can use to upload it as an attachment.
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • graham01
                                      • Oct 2011
                                      • 92
                                      Thanks, I tried to attach but not sure if it has worked.. Anyway the voltage regulators as you have circled;
                                      Top Left: IC707_3V3 - 17-33Z 1105AG
                                      Left Pin: 5.34V
                                      Right Pin: 0V
                                      Top Right: IC203 - N055 950T45
                                      Left Pin: 2.50V
                                      Right Pin: 3.30V
                                      Bottom: IC708_1V6 - 17-18Z 1022BG
                                      Left Pin: 3.30V
                                      Right Pin: 0V
                                      Both processors are luke warm after 5 minutes.
                                      My eyes may have deceived me when taking the model numbers..
                                      Regards
                                      • graham01
                                        • Oct 2011
                                        • 92
                                        the upload failed twice, I think maybe because its 3.6MB.. You can find the image below;
                                        http://postimage.org/image/odnwgcpb5/
                                        Regards
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
