Polaroid TLX-04244B Backlight turn on and says Polaroid then backlight goes off
  • 2011srg
    • Nov 2011
    • 46
    hi there i have a polaroid 42" TLX-04244B flat screen it turns on for a split sec and then goes black i hear a buzzing sound for a couple secs right before the screen goes black the power light stays blue so its gettin power, and if i hold a light up to it I can see picture, what is the problem plz help me fix this so i can have a tv again thanks
  • tctv
    • Dec 2012
    • 13
    • united states
    Re: Polaroid TLX-04244B Backlight turn on and says Polaroid then backlight goes off
    Have you received any info to actually fix this problem. I have the same TV with the same exact problem, seems like alot of us do.
    Thanks..
    • awyatt2
      • Feb 2012
      • 407
      • america
      have you looked at the service manual, or checked voltage going to the backlight? one voltage missing is all it takes to stop it. if you post a picture of the boaeds we might be able to tell you more. there are more than one voltage coming off the power supply.somewhere you are loosing backlights, buzzing sound may be xformer on inverter board.example on voltage, if you remove the main wire from the starter on your car, do you expect it to crank? everything else will work.
      • kevinm34232
        • May 2012
        • 1884
        Is the backlight inverter part of the power supply board on your model?
          Any good clear pictures of the boards?
          • tctv
            • Dec 2012
            • 13
            • united states
            looks like the power supply board feeds a master and slave inverter board. If both inverter boards are connected I get the initial LOGO and backlight and buzz like others with this problem. If I disconnect the slave I get the same results with no buzz. Im thinking the slave board may be bad. I'll try to post pic's
            • tctv
              • Dec 2012
              • 13
              • united states
              The power supply looks like it feeds a master and a slave invertor board
                As you can see, there are more than one version of this model, some use power supply/inverter combo board, some use power supply and master/slave inverter board.
                http://www.shopjimmy.com/catalogsear...oid+TLX-04244B
                • ptepe
                  • Oct 2010
                  • 10
                  The problem I found with this LCD tv is they installed CCFL lamps without soldering them. They just snap in and over time they start to arch. That's the buzzing sound you are hearing. The arching causes the inverter to shut down. I took the time to disassemble mine and carefully lifted each bulb out of their sockets and cleaned them. There are 18 bulbs in all. Be careful because these bulbs are extremely fragile. TV is back on and working.
                  • Vear01
                    • Jul 2017
                    Polaroid 42” LCD TV TLX-04244B , error codes: Flashing red light on Power/ backlight inverter board, 860-AZ0-IP0S250-P1H back sticker is 38-899-AZO-IPOS-PA2H on board LX-04244B TV-- 860-AZ0-IP0S250-P1H error codes
                    Power/ inverter board has red light that is flashing what error is it indicating
                    What are the error codes?
                    I know this an old thread but basically same issue.
                    TV turns on the screen flashes off, flashlight shows image, sound works, power light stays on, no obvious bad caps, red light flashes on PSU/inverter board. I suspect failed inverter, Although I have not check the CFL bulbs or the contact points. If Power/inverter board does need to be replaced and exact copy is unavailable--what do each part of mpn mean (11 vs 38)- (860 vs 899)-( AZO vs 24B vs ABO)- IPOS250- (PA2H vs PCH vs 2AH vs PAH vs T1H vs PH vs 2CH vs CH vs H)
                    1. what does the flashing red light on PSU/inverter board mean?
                    2. what do the different part numbers mean? What are the differences?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Need good clear straight on pictures of back of tv with cover off and each board.
                      • Austin's Electronics
                        • Aug 2018
                        I have a polaroid 50" tv that lights up the logo for a split second then goes black but i take a flashlight and there is still a picture there.
                          You need to start a new thread and put down the make and model of the TV on the header, then provide good clear pictures of the whole backside of the TV showing all the boards.
                          History of the TV?
                          Any Voltage measurement has been made, what are they?
                          The more details you provide the better help you will get, it is not easy doing long distant troubleshooting without having the set in from to f us to look at.
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
                          • DanPoka
                            by DanPoka
                            02-15-2025, 05:05 AM
                          • Comp_Pro
                            No Backlight Macbook A1990 820-01041
                            by Comp_Pro
                            Hello all,
                            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                            Tests performed:
                            There is no backlight even with a good screen.
                            Backlight IC is receiving the correct support voltages.
                            Fuse F8400 ok
                            Current sense resistor R8400 ok
                            Backlight IC is receiving 3.3V on enable pin.
                            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                            Backlight IC receiving 5V from PP5V_G3S
                            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                            05-06-2024, 10:23 PM
                          • cheebster
                            iPad Pro 12.9 5th Gen Backlight Issue
                            by cheebster
                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                            Anyone...
                            05-20-2025, 09:17 AM
                          • canadaboy25
                            LG Flatron 24EN33TA No Backlight When Cold
                            by canadaboy25
                            I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                            I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                            03-07-2023, 12:23 AM
