Polaroid TLX-04244B
    Re: Polaroid TLX-04244B
    0 ohms is good for a fuse.
    Originally posted by 2011srg
    Is there any chance that the power supply isn't giving enough power to the inverters, if so how can I check.
    Yes, that's a possibility, although less likely. Set your meter to the 200V DC range and probe the pins corresponding to the red and black wires on the connector, while turning the set on. I think you should measure about 24V +/- 1V either way.
    Could also be a bad bulb, but it looks like the bulbs will be a real bugger to replace.
    • 2011srg
      • Nov 2011
      • 46
      #42
      Yea i do get 24v, is there anything I can do to test the bulbs
      • 2011srg
        • Nov 2011
        • 46
        #43
        So I think i'm going to go ahead and buy a new master inverter, and see what happens the buzzing is worse on there than the slave
        • 2011srg
          • Nov 2011
          • 46
          #44
          So I went ahead and order the parts from RetechTV.com, it cost $94 for both inverter boards. If this isn't it I think i'm going to try getting a new power supply. And if anybody could help me find a Manual and a disassembly guide that would be appreciated.
          • cadiman
            • Mar 2010
            • 397
            #45
            That is most likely an au-optronics panel. It consists of a master and slave inverter.
            Mosfets on the slave short out and can be caused by one or two bad ccfls.
            Very common on this type of panel.
            Do not replace the inverters until you inspect the ccfls.
            • 2011srg
              • Nov 2011
              • 46
              #46
              Ok so I got to the lights looks like 1,3,8,9 needs replaced, does anyone know were I can buy these bulbs at?
              • 2011srg
                • Nov 2011
                • 46
                #47
                Will these lights work?
                http://www.lcdparts.net/ccfldetail.aspx?ProductID=3669
                • 2011srg
                  • Nov 2011
                  • 46
                  #48
                  Ok so I found a deal on ccfls, do you think these will work on this t.v, Please let me know ASAP! Thank You
                  http://www.ebay.com/itm/Aoc-42-W-LCD...#ht_1794wt_895
                  • 2011srg
                    • Nov 2011
                    • 46
                    #49
                    Oh yea also do this mean I would also have to replace the slave as cadiman said (Mosfets on the slave short out) does this mean the slave is DONE?
                    • 2011srg
                      • Nov 2011
                      • 46
                      #50
                      So you were right it has 4 bad bulbs out of 18. Do you know anywhere I can buy these?
                      • 2011srg
                        • Nov 2011
                        • 46
                        #51
                        The part number on the bulbs are FM14 but I have no clue were to get them
                        • 2011srg
                          • Nov 2011
                          • 46
                          #52
                          I called the company and they were no help. I'm sure its the bulbs there 955mm long I haven't found the diameter yet.
                            I'm not convinced that four bulbs have failed. These inverters shut off when one bulb dies so no further failures should happen.
                            There's a simple test for this, though.
                            With power off, carefully swap a "faulty" CCFL for a working one. See if the CCFL in that position lights up. Do not change them around when the set is on as you will get a nasty shock (~3,500V) although as this is AC it dissipates almost instantly so no harm once unplugged.
                            • 2011srg
                              • Nov 2011
                              • 46
                              #54
                              I did what you said and there's only 3 out I thought i seen four but it is flicking. But the same three are out after I moved them. They also have black spots on them. I'm having trouble still trying to find replacements. I think i'm going to put the AOC or Sony ones in after i fond out the diameter of the bulbs.
                              See early I was messing around with the bulbs and put them back in there was a little light and the t.v stayed on longer than it has been at least a min or longer. But now there no light what so ever in the three bulbs.
                              __________________________________________________________________________
                              How much wood could a woodchuck, chuck if a wood chuck could chuck wood?
                                Well, I'm surprised. I've never heard of three bulbs simultaneously failing. Have you tried measuring their diameter?
                                • 2011srg
                                  • Nov 2011
                                  • 46
                                  #56
                                  Yea I not sure how, I also was told that it will let two go out before it shut them down, not sure if thats true? The diameter is about 3.40 on the bulb and on the end (solder point) 3.4 I did't know what one it would be. So the bulb is 955mm (long) - 3.40mm (diameter)
                                  • cadiman
                                    • Mar 2010
                                    • 397
                                    #57
                                    I have replaced the ccfls from another of the same size (42 or 32 etc).
                                    I soldered mine in because the ends were smaller.
                                    I replaced all of them from another panel. (even light)
                                    You can do the same. Some are plug in and some are soldered.
                                    Any ccfls with dark spots are bad.
                                    • 2011srg
                                      • Nov 2011
                                      • 46
                                      #58
                                      So I got home today and truned on the t.v so I could see the bad bulbs and it truned on but the light slowly shut off from right to the left and I started smelling something like electrical components burning. I immediately unplugged the t.v and inspected it and found this. So do you think the master board is bad now or what could have caused this, i;m kinda scared to plug it back.
                                      • 2011srg
                                        • Nov 2011
                                        • 46
                                        #59
                                        Ok so i'm talking to this ebay seller that sells cccfl's and eefl's. He said I should put eefl's in. But how do I know for sure what I have now? I posted a picture of the eefl he sent me. And the other picture is what I have now.
                                        Here the EEFL it would't upload here. http://s1212.photobucket.com/albums/...nt=TheEEFL.jpg
                                          You might have a bit of conductive dirt where the connector is. I don't think the board is damaged. Use a needle or small pin to scrape off the carbon residue and clean the "wound" and plug it in again. It won't start a fire.
                                          Use CCFLs. EEFL might not be compatible.
                                          • Chivo77
                                            DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                            by Chivo77
                                            hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                            1- After receiving power SIO_SLP_S0# goes high and never changes.
                                            2-every...
                                            07-03-2025, 09:20 AM
                                          • Chrissygizmo
                                            Polaroid p49fn0038k backlights flashing split second
                                            by Chrissygizmo
                                            Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                                            When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                                            Any help would be greatly appreciated
                                            Thanks in advance
                                            11-10-2022, 10:30 AM
                                          • crazycavan
                                            polaroid TQLHD24PR004 no power
                                            by crazycavan
                                            hi, my tv no longer starts like dead, no standby led
                                            motherboard : MS36639-ZC01-01
                                            panel : V236BJ1-P01
                                            flash spi: GD25Q64
                                            need usb firmware or to reprogram​
                                            05-05-2024, 08:40 AM
                                          • snimmits
                                            Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                                            by snimmits
                                            Good afternoon,
                                            I have a Polaroid P43D300.
                                            It shipped with WiFi and Bluetooth.
                                            Two weeks ago, I ran through the first time installation.
                                            This did a full reset and went through the first time setup.
                                            Once complete, I went to settings > sound.
                                            selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                                            search completes and doesn't find any devices.
                                            I have tried everything I can think of.
                                            Can someone provide...
                                            03-01-2024, 09:26 AM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
